Homebridge no response
Posted: Saturday 28 March 2020 11:45
Start separate thread on my Homebridge issues, appreciate any help.
After Domoticz upgrade, including OS to Buster, Homebridge stopped working. Have tried upgrading and reinstalling but no difference. Can the below out put give any clues to resolution?
Thanks in advance
pi@domrasp:~ $ homebridge
[3/28/2020, 11:39:37 AM] Loaded config.json with 0 accessories and 1 platforms.
[3/28/2020, 11:39:37 AM] ---
[3/28/2020, 11:39:38 AM] Plugin /usr/lib/node_modules/homebridge-config-ui-x req uires Node version of >=8.15.1 which does not satisfy the current Node version o f v6.17.1. You may need to upgrade your installation of Node.
[3/28/2020, 11:39:38 AM] Loaded plugin: homebridge-config-ui-x
[3/28/2020, 11:39:38 AM] Registering platform 'homebridge-config-ui-x.config'
[3/28/2020, 11:39:38 AM] ---
[3/28/2020, 11:39:42 AM] Loaded plugin: homebridge-edomoticz
[3/28/2020, 11:39:42 AM] Registering platform 'homebridge-edomoticz.eDomoticz'
[3/28/2020, 11:39:42 AM] ---
[3/28/2020, 11:39:42 AM] Loading 1 platforms...
[3/28/2020, 11:39:42 AM] [Domoticz] Initializing eDomoticz platform...
[3/28/2020, 11:39:42 AM] Loading 0 accessories...
HAP Warning: Characteristic undefined not in required or optional characteristic s for service 24a8d81a-3d7b-4965-9086-7edc3ef4fab3. Adding anyway.
Setup Payload:
X-HM://0023ISYWY2FG0
Scan this code with your HomeKit app on your iOS device to pair with Homebridge:
[3/28/2020, 11:39:43 AM] [Domoticz] synchronizeAccessories in progress...
[3/28/2020, 11:39:43 AM] Homebridge is running on port 51826.
[3/28/2020, 11:39:45 AM] [Domoticz] Successfully connected to MQTT broker.
[3/28/2020, 11:39:46 AM] TypeError: "list" argument must be an Array of Buffers
at Function.Buffer.concat (buffer.js:314:13)
at Object.encode (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/l ib/util/tlv.js:26:35)
at Object.encode (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/l ib/util/tlv.js:51:39)
at HAPServer._handlePairVerifyStepOne (/usr/lib/node_modules/homebridge/node _modules/hap-nodejs/lib/HAPServer.js:543:21)
at HAPServer._handlePairVerify (/usr/lib/node_modules/homebridge/node_module s/hap-nodejs/lib/HAPServer.js:505:10)
at HAPServer.<anonymous> (/usr/lib/node_modules/homebridge/node_modules/hap- nodejs/lib/HAPServer.js:209:39)
at emitNone (events.js:86:13)
at IncomingMessage.emit (events.js:185:7)
at endReadableNT (_stream_readable.js:978:12)
at _combinedTickCallback (internal/process/next_tick.js:80:11)
[3/28/2020, 11:39:46 AM] Got SIGTERM, shutting down Homebridge...
pi@domrasp:~ $
Thanks in advance
Setup Payload:
pi@domrasp:~ $
