Domoticz-Google-Assistant (dzga) Topic is solved
Alexa, Google Home and Siri
DewGew
Domoticz version: V4.10618
Post by DewGew »
Control your Domoticz devices with Google Assistant
Standalone implementation for Domoticz. It means that you can put this server wherever you want, even on another machine. You need to setup a project in Actions on Google Console. You find instructions below.
Based on Pawcio's script at this forum thread
Required:
- public url
- python >= 3.5
- Make local deployment available trough HTTPS with valid certificate with one below:
  • Configure reverse proxy with valid certificate using Let's Encrypt
  • Use ngrok (included in dzga) for a secure SSL tunnel with valid public HTTPS URL
  • SSL with own domain or dynamic DNS, require ssl key and ssl certficate
Domoticz-Google-Assistant delivers:
- The oauth authorization and smarthome endpoint for the google assistant.
- Two-factor authentication domoticz protected devices. (limited language support)
- Arm Disarm Securitypanel. (limited language support)
- Stream surveillance camera to chromecast.
- Toggel Selector devices
- Thermostat modes
- Query battery level
- Switch Off timer
- Change device type
- Chromecast Notification
- and more..
Installation Raspberry Pi/Ubuntu:
Just run below in terminal
bash <(curl -s https://raw.githubusercontent.com/DewGew/dzga-installer/master/install.sh)
Installation Docker:
cd /home/${USER}
git clone https://github.com/DewGew/Domoticz-Google-Assistant -b docker --single-branch
docker-compose -f /home/${USER}/Domoticz-Google-Assistant/docker-compose.yaml up -d
You can access the interface via http://localhost:3030/settings. The default username is admin and the default password is admin.
Wiki:
https://github.com/DewGew/Domoticz-Goog ... stant/wiki
Sourcecode:
Please feel free to modify it, extend and improve!
DewGew
Re: Domoticz-Google-Assistant (dzga)
Post by DewGew »
Functions on latest V1.7.2
There is new function to change device type, icon and some behavior depending on the device (e.g open/close instead of on/off).
For fully control you can remove Image_Override from config.
To change device type, add to discription for your device in domoticz:
<voicecontrol>
  devicetype = oven
</voicecontrol>
or in Device_Config in config.yaml:
Device_Config:
   212:
     devicetype: 'oven'
Light Device types to choose from is:
light, ac_unit, bathtub, coffemaker, dishwasher, dryer, fan, heater, kettle, media, microwave, outlet, oven, speaker, switch, vacuum, washer, waterheater, window, gate, garage.
For heater, kettle, waterheater, oven you can also use merge_thermo_idx to merge thermostat to control temperature.
<voicecontrol>
  devicetype = oven
  merge_thermo_idx = 432
</voicecontrol>
Door Contact devices can choose window, gate or garage
Selector devices can choose only vacuum
Feedback is appreciated
Minglarn
Domoticz version: v3.8153
Post by Minglarn »
Sorry for the dumb question, but this is only valid för ASSISTANT and not Google Home devices?
DewGew
Post by DewGew »
Minglarn wrote: Friday 27 March 2020 8:50 Sorry for the dumb question, but this is only valid för ASSISTANT and not Google Home devices?
Works with everything that has Google Assistant e.g. Google Assistant app, Google Home, Google Nest Hub, Andoid TV etc..
ressof
Domoticz version: Latest
Post by ressof »
When I ask google to turn on or off a device it will do so but google answer that there was an error with the device
I have latest domoticz and dzga versions.
This is from my log:
2020-03-30 16:45:46 - INFO - Request {
  "inputs": [
      "context": {
        "locale_country": "SE",
        "locale_language": "sv"
      "intent": "action.devices.EXECUTE",
      "payload": {
        "commands": [
            "devices": [
                "id": "ColorSwitch427"
            "execution": [
                "command": "action.devices.commands.OnOff",
                "params": {
                  "on": false
  "requestId": "16575895686983337135"
2020-03-30 16:45:46 - ERROR - 400 Client Error: Bad Request for url: https://homegraph.googleapis.com/v1/devices:reportStateAndNotification
2020-03-30 16:45:46 - INFO - Error handling message {'inputs': [{'context': {'locale_country': 'SE', 'locale_language': 'sv'}, 'intent': 'action.devices.EXECUTE', 'payload': {'commands': [{'devices': [{'id': 'ColorSwitch427'}], 'execution': [{'command': 'action.devices.commands.OnOff', 'params': {'on': False}}]}]}}], 'requestId': '16575895686983337135'}: {'errorCode': 'unknownError'}
2020-03-30 16:45:46 - INFO - Response {
  "payload": {
    "errorCode": "unknownError"
Do you know what the problem could be? It has been working but I don't know which version I was using.
DewGew
Post by DewGew »
ressof wrote: Tuesday 31 March 2020 8:20 Hi
  "inputs": [
      "context": {
      "payload": {
        "commands": [
            "devices": [
            "execution": [
                "params": {
                  "on": false
  "payload": {
check if your smart-home-key.json is valid
ressof
Post by ressof »
DewGew wrote: Tuesday 31 March 2020 12:10
  "inputs": [
      "context": {
      "payload": {
        "commands": [
            "devices": [
            "execution": [
                "params": {
                  "on": false
  "payload": {
How can I check this?
DewGew
Post by DewGew »
Justintime
Post by Justintime »
The best and easiest way to connect Domticz to Google Home.
Still i get the message "there is an unknown fault" (in dutch) I know this is a language thing. Is this on the roadmap to solve?
Otherwise i know what to do in Domiticz to quiet this.
DewGew
Post by DewGew »
Justintime wrote: Tuesday 31 March 2020 21:11 The best and easiest way to connect Domticz to Google Home.
I dont get that message. When do you get it?
ressof
Post by ressof »
DewGew wrote: Tuesday 31 March 2020 12:40 Try make a new key https://console.cloud.google.com/apis/c ... accountkey
next check all steps again in https://github.com/DewGew/Domoticz-Goog ... -on-Google
I have completely removed my config on google and started over but with the same problem.
I have Swedish as language. But this have been working before.
DewGew
Post by DewGew »
ressof wrote: Wednesday 01 April 2020 8:45
Is it same on all switches or just colorswitch?
ressof
Post by ressof »
DewGew wrote: Wednesday 01 April 2020 9:20
It seems that it is only on colorswitch that a Domoticz plugin called ShellyMQTT created.
It seems that the plugin creates colorswitch white instead of ight/switch dimmer.
I have a bulb with colorswitch rgbw that is working.
DewGew
Post by DewGew »
ressof wrote: Wednesday 01 April 2020 9:37
Paste the json output here for that device e.g http://your.domoticz.ip:8080/json.htm?t ... =DEVICEIDX
ressof
Post by ressof »
DewGew wrote: Wednesday 01 April 2020 10:18
	"ActTime" : 1585729270,
	"AstrTwilightEnd" : "22:22",
	"AstrTwilightStart" : "04:13",
	"CivTwilightEnd" : "20:35",
	"CivTwilightStart" : "05:59",
	"DayLength" : "13:15",
	"NautTwilightEnd" : "21:25",
	"NautTwilightStart" : "05:09",
	"ServerTime" : "2020-04-01 10:21:10",
	"SunAtSouth" : "13:17",
	"Sunrise" : "06:40",
	"Sunset" : "19:55",
	"app_version" : "2020.1 (build 11853)",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"Color" : "",
			"CustomImage" : 0,
			"Data" : "Off",
			"Description" : "",
			"DimmerType" : "abs",
			"Favorite" : 0,
			"HardwareID" : 11,
			"HardwareName" : "ShellyMQTT",
			"HardwareType" : "Shelly MQTT",
			"HardwareTypeVal" : 94,
			"HaveDimmer" : true,
			"HaveGroupCmd" : false,
			"HaveTimeout" : false,
			"ID" : "shellydimmer-F35FDD-0-dimmer",
			"Image" : "Light",
			"IsSubDevice" : false,
			"LastUpdate" : "2020-04-01 10:19:38",
			"Level" : 98,
			"LevelInt" : 98,
			"MaxDimLevel" : 100,
			"Name" : "K\u00f6k Tak",
			"Notifications" : "false",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Protected" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"Status" : "Off",
			"StrParam1" : "",
			"StrParam2" : "",
			"SubType" : "White",
			"SwitchType" : "Dimmer",
			"SwitchTypeVal" : 7,
			"Timers" : "false",
			"Type" : "Color Switch",
			"TypeImg" : "dimmer",
			"Unit" : 1,
			"Used" : 1,
			"UsedByCamera" : false,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "427"
	"status" : "OK",
	"title" : "Devices"
DewGew
Post by DewGew »
ressof wrote: Wednesday 01 April 2020 10:21
	"Sunset" : "19:55",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"Color" : "",
			"CustomImage" : 0,
			"Data" : "Off",
			"Description" : "",
			"Favorite" : 0,
			"HardwareID" : 11,
			"Image" : "Light",
			"Level" : 98,
			"LevelInt" : 98,
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Status" : "Off",
			"StrParam1" : "",
			"StrParam2" : "",
			"Timers" : "false",
			"Unit" : 1,
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "427"
	"status" : "OK",
	"title" : "Devices"
Try latest beta V1.7.4
ressof
Post by ressof »
DewGew wrote: Wednesday 01 April 2020 11:13
	"Sunset" : "19:55",
	"result" :
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"Color" : "",
			"CustomImage" : 0,
			"Data" : "Off",
			"Description" : "",
			"Favorite" : 0,
			"HardwareID" : 11,
			"Image" : "Light",
			"Level" : 98,
			"LevelInt" : 98,
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Status" : "Off",
			"StrParam1" : "",
			"StrParam2" : "",
			"Timers" : "false",
			"Unit" : 1,
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "427"
	"status" : "OK",
	"title" : "Devices"
Now its working.
Thank you.
Justintime
When I give a command "zet Eettafellamp aan" (turn on dining light)
Google is turning on the light. She gives confirmation but than she says there is an unknown error / fault.
I have solved this to put this text in domoticz switch.
<voicecontrol>
nicknames = Eettafellamp
report_state = False
</voicecontrol>
But i have to do with every switch. Except curtains.
Another question. When I say synchronize devices. Domoticz google home is calling it "my test app" where can is change the name?
EdwinK
Post by EdwinK »
One day I will understand all this. I promise.
For domain name, can I use something like noip.com or should it be more as www.mydomain.com?
DewGew
Post by DewGew »
EdwinK wrote: Saturday 04 April 2020 19:26 One day I will understand all this. I promise.
You can use noip.com or similar with reverse proxy
