Crash after voltage report Zwave floor thermostat
Posted: Wednesday 25 March 2020 22:00
by Geitje
I keep getting a crash about every week or so. If I check the logs it must have something to do with my Zwave Heat-it floor thermostat. Every crash it is after that reported operating voltage. See the collected last lines of crashlog below. Anyone has an idea how to solve this?
2020-03-25 11:48:36.942  [6fafe220] (Darksky weather Nunspeet) Rain (Regen Nunspeet)
2020-03-25 11:48:36.958  [6fafe220] Debug: SQLH UpdateValueInt Helderheid zicht Nunspeet HwID:24  DevID:0 Type:243  sType:1 nValue:0 sValue:16.1
2020-03-25 11:48:36.970  [6fafe220] subtype       = Visibility
Visibility = 16.1 km
2020-03-25 11:48:36.970  [6fafe220] (Darksky weather Nunspeet) General/Visibility (Helderheid zicht Nunspeet)
2020-03-25 11:48:36.986  [6fafe220] Debug: SQLH UpdateValueInt Ozone Sensor HwID:24  DevID:00000100 Type:243  sType:31 nValue:0 sValue:339.8000
2020-03-25 11:48:36.986  [6fafe220] subtype       = Custom Sensor
Value = 339.8
2020-03-25 11:48:36.988  [6fafe220] (Darksky weather Nunspeet) General/Custom Sensor (Ozone Sensor)
2020-03-25 11:48:37.002  [6fafe220] Debug: SQLH UpdateValueInt Cloud Cover Nunspeet HwID:24  DevID:00000001 Type:243  sType:6 nValue:0 sValue:6.00
2020-03-25 11:48:37.013  [6fafe220] subtype       = Percentage
Percentage = 6.00
2020-03-25 11:48:37.014  [6fafe220] (Darksky weather Nunspeet) General/Percentage (Cloud Cover Nunspeet)
2020-03-25 11:48:37.365  [74b88220] (Zigate Zigbee) Receive NACK from Overloop slaapkamer pama (5296) clusterId: 0000
2020-03-25 11:48:40.196  [6d4fe220] Debug: Yeelight::InsertUpdateSwitch colorMode: 2, Bri: 100, Hue: 359, Sat: 100, RGB: 16711680, CT: 3124
2020-03-25 11:48:40.197  [6d4fe220] Debug: Yeelight::InsertUpdateSwitch colorMode: 2, Bri: 75, Hue: 359, Sat: 100, RGB: 16711680, CT: 3236
2020-03-25 11:48:40.198  [6d4fe220] Debug: Yeelight::InsertUpdateSwitch colorMode: 2, Bri: 100, Hue: 0, Sat: 100, RGB: 16711680, CT: 3601
2020-03-25 11:48:40.199  [6d4fe220] Debug: Yeelight::InsertUpdateSwitch colorMode: 2, Bri: 100, Hue: 358, Sat: 84, RGB: 16721711, CT: 4241
2020-03-25 11:48:42.310  [6fafe220] Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11  DevID:00000501 Type:243  sType:29 nValue:0 sValue:0.030;893900.000
2020-03-25 11:48:42.330  [6fafe220] subtype       = kWh
Instant = 0.030
Counter = 893.900
2020-03-25 11:48:42.330  [6fafe220] (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter)
2020-03-25 11:48:42.357  [6fafe220] Debug: SQLH UpdateValueInt Vloerverwarming badkamer stroomverbruik HwID:11  DevID:0000501 Type:248  sType:1 nValue:0 sValue:0.0
2020-03-25 11:48:42.377  [6fafe220] subtype       = Electric
Usage = 0.0 W
2020-03-25 11:48:42.377  [6fafe220] (Zwave USB) Usage (Vloerverwarming badkamer stroomverbruik)
2020-03-25 11:48:42.404  [74b88220] Debug: SQLH HandleOnOffAction: OnAction:
2020-03-25 11:48:42.405  [6fafe220] Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11  DevID:00000501 Type:243  sType:29 nValue:0 sValue:0.030;893900.000
2020-03-25 11:48:42.407  [74b88220] Debug: SQLH UpdateValueInt Lamp overloop slaapkamer Anna HwID:35  DevID:14b457fffe2607c9 Type:244  sType:73 nValue:1 sValue:99
2020-03-25 11:48:42.416  [6fafe220] subtype       = kWh
Instant = 0.030
Counter = 893.900
2020-03-25 11:48:42.417  [6fafe220] (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter)
2020-03-25 11:48:42.449  [6fafe220] Debug: SQLH UpdateValueInt Voltage HwID:11  DevID:00000501 Type:243  sType:8 nValue:0 sValue:235.400
2020-03-25 11:48:42.449  [6fafe220] subtype       = Voltage
Voltage = 235.400 V
2020-03-25 11:48:42.450  [6fafe220] (Zwave USB) General/Voltage (Voltage)
2020-03-25 11:48:42.484  [74b88220] Error: Domoticz(pid:5466, tid:5475('PluginMgr')) received fatal signal 11 (Segmentation fault)
2020-03-25 11:48:42.484  [74b88220] Error: siginfo address=0x155a, address=(nil)
2020-03-25 11:48:50.960  [6fafe220] Debug: SQLH UpdateValueInt Temperatuur buiten HwID:3  DevID:16385 Type:82  sType:5 nValue:0 sValue:8.8;47;1
2020-03-25 11:48:51.024  [6fafe220] subtype       = TH5 - WTGR800
Sequence nbr  = 0
ID            = 16385
Temperature   = 8.8 C
Humidity      = 47 %
Status        = Comfortable
Signal level  = 12
Battery       = Low
2020-03-25 11:48:51.025  [6fafe220] (433Mhz RFlink Gateway) Temp + Humidity (Temperatuur buiten)
2020-03-25 11:48:51.135  [6fafe220] Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11  DevID:00000501 Type:243  sType:29 nValue:0 sValue:0.030;893900.000
2020-03-25 11:48:51.159  [6fafe220] subtype       = kWh
Instant = 0.030
Counter = 893.900
2020-03-25 11:48:51.160  [6fafe220] (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter)
2020-03-25 11:48:51.198  [6fafe220] Debug: SQLH UpdateValueInt Vloerverwarming badkamer stroomverbruik HwID:11  DevID:0000501 Type:248  sType:1 nValue:0 sValue:0.0
2020-03-25 11:48:51.210  [6fafe220] subtype       = Electric
Usage = 0.0 W
2020-03-25 11:48:51.210  [6fafe220] (Zwave USB) Usage (Vloerverwarming badkamer stroomverbruik)
2020-03-25 11:48:51.252  [6fafe220] Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11  DevID:00000501 Type:243  sType:29 nValue:0 sValue:0.040;893900.000
2020-03-25 11:48:51.263  [6fafe220] subtype       = kWh
Instant = 0.040
Counter = 893.900
2020-03-25 11:48:51.264  [6fafe220] (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter)
2020-03-25 11:48:51.296  [6fafe220] Debug: SQLH UpdateValueInt Voltage HwID:11  DevID:00000501 Type:243  sType:8 nValue:0 sValue:235.400
2020-03-25 11:48:51.296  [6fafe220] subtype       = Voltage
Voltage = 235.400 V
2020-03-25 11:48:51.296  [6fafe220] (Zwave USB) General/Voltage (Voltage)
2020-03-25 11:48:51.507  [74b88220] Error: Thread 4 (Thread 0x74b88220 (LWP 5475)):
2020-03-25 11:48:51.507  [74b88220] Error: #0  __waitpid (options=0, stat_loc=0x74b85e88, pid=3763) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2020-03-25 11:48:51.507  [74b88220] Error: #1  __waitpid (pid=3763, stat_loc=0x74b85e88, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2020-03-25 11:48:51.507  [74b88220] Error: #2  0x002db8c4 in dumpstack_gdb(bool) ()
2020-03-25 11:48:51.507  [74b88220] Error: #3  0x002dbe90 in signal_handler(int, siginfo_t*, void*) ()
2020-03-25 11:48:51.507  [74b88220] Error: #4  <signal handler called>
2020-03-25 11:48:51.507  [74b88220] Error: #5  raise (sig=11) at ../sysdeps/unix/sysv/linux/raise.c:50
2020-03-25 11:48:51.507  [74b88220] Error: #6  <signal handler called>
2020-03-25 11:48:51.507  [74b88220] Error: #7  0x007f346c in packet.queue ()
2020-03-25 11:48:51.507  [74b88220] Error: #8  0x007f6458 in send.real_publish ()
2020-03-25 11:48:51.507  [74b88220] Error: #9  0x007ee278 in mosquitto_publish ()
2020-03-25 11:48:51.508  [74b88220] Error: #10 0x002bf71c in mosqdz::mosquittodz::publish(int*, char const*, int, void const*, int, bool) ()
2020-03-25 11:48:51.508  [74b88220] Error: #11 0x004d9988 in MQTT::SendMessage(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
2020-03-25 11:48:51.508  [74b88220] Error: #12 0x004db6a0 in MQTT::SendDeviceInfo(int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*) ()
2020-03-25 11:48:51.508  [74b88220] Error: #13 0x002bd4c8 in boost::signals2::detail::signal_impl<void (int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*), boost::signals2::optional_last_value<void>, int, std::less<int>, boost::function<void (int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*)>, boost::function<void (boost::signals2::connection const&, int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*)>, boost::signals2::mutex>::operator()(int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*) ()
2020-03-25 11:48:51.508  [74b88220] Error: #14 0x0064edf0 in Plugins::CDevice_update(Plugins::CDevice*, _object*, _object*) ()
2020-03-25 11:48:51.508  [74b88220] Error: #15 0x75e5cd48 in _PyMethodDef_RawFastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2020-03-25 11:48:51.508  [74b88220] Error: #16 0x75e5dca4 in _PyCFunction_FastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2020-03-25 11:48:51.508  [74b88220] Error: #17 0x75c5d1d4 in _PyEval_EvalFrameDefault () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2020-03-25 11:48:51.508  [74b88220] Error: #18 0x75d8f4d4 in _PyEval_EvalCodeWithName () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2020-03-25 11:48:51.508  [74b88220] Error: #19 0x75e5d340 in _PyFunction_FastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2020-03-25 11:48:51.508  [74b88220] Error: #20 0x75c5a950 in _PyEval_EvalFrameDefault () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2020-03-25 11:48:51.508  [74b88220] Error: #21 0x75c5edd4 in ?? () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
______________________________________________________
2020-02-23 06:39:34.321  Debug: SQLH UpdateValueInt Temperatuur buiten HwID:3  DevID:16385 Type:82  sType:5 nValue:0 sValue:7.0;83;3
2020-02-23 06:39:34.724  (433Mhz RFlink Gateway) Temp + Humidity (Temperatuur buiten)
2020-02-23 06:39:39.403  Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11  DevID:00000501 Type:243  sType:29 nValue:0 sValue:0.050;766100.000
2020-02-23 06:39:39.470  Debug: SQLH UpdateValueInt PiMonitor - GPU temperature HwID:10  DevID:000A0002 Type:243  sType:31 nValue:54 sValue:54.8
2020-02-23 06:39:40.675  (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter)
2020-02-23 06:39:41.049  Debug: SQLH UpdateValueInt Vloerverwarming badkamer stroomverbruik HwID:11  DevID:0000501 Type:248  sType:1 nValue:0 sValue:0.0
2020-02-23 06:39:41.115  (Zwave USB) Usage (Vloerverwarming badkamer stroomverbruik)
2020-02-23 06:39:41.129  Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11  DevID:00000501 Type:243  sType:29 nValue:0 sValue:0.000;766100.000
2020-02-23 06:39:41.146  (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter)
2020-02-23 06:39:41.213  Debug: SQLH UpdateValueInt Vloerverwarming badkamer stroomverbruik HwID:11  DevID:0000501 Type:248  sType:1 nValue:0 sValue:0.0
2020-02-23 06:39:41.223  (Zwave USB) Usage (Vloerverwarming badkamer stroomverbruik)
2020-02-23 06:39:41.224  Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11  DevID:00000501 Type:243  sType:29 nValue:0 sValue:0.000;766100.000
2020-02-23 06:39:41.235  (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter)
2020-02-23 06:39:41.236  Debug: SQLH UpdateValueInt Vloerverwarming badkamer stroomverbruik HwID:11  DevID:0000501 Type:248  sType:1 nValue:0 sValue:0.0
2020-02-23 06:39:41.246  (Zwave USB) Usage (Vloerverwarming badkamer stroomverbruik)
2020-02-23 06:39:41.247  Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11  DevID:00000501 Type:243  sType:29 nValue:0 sValue:0.000;766100.000
2020-02-23 06:39:41.258  (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter)
2020-02-23 06:39:42.452  Error: Domoticz(pid:4700, tid:4711('PluginMgr')) received fatal signal 11 (Segmentation fault)
2020-02-23 06:39:42.516  Error: siginfo address=0x125c, address=(nil)
2020-02-23 06:39:46.341  Debug: SQLH UpdateValueInt Temperature HwID:11  DevID:1282 Type:80  sType:5 nValue:0 sValue:23.8
2020-02-23 06:39:52.348  Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds
2020-02-23 06:39:55.052  (Zwave USB) Temp (Temperature)
2020-02-23 06:39:57.729  Debug: SQLH UpdateValueInt Vloerverwarming badkamer temp. instelling HwID:11  DevID:0000501 Type:242  sType:1 nValue:0 sValue:23.50
2020-02-23 06:40:22.485  (Zwave USB) Thermostat (Vloerverwarming badkamer temp. instelling)
2020-02-23 06:40:30.463  Debug: SQLH UpdateValueInt Ingestelde temperatuur Nefit Easy HwID:2  DevID:0010101 Type:242  sType:1 nValue:0 sValue:17.00
2020-02-23 06:40:45.316  (Nefit Easy Thermostaat ) Thermostat (Ingestelde temperatuur Nefit Easy)
2020-02-23 06:40:45.316  Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-02-23 06:40:47.333  Debug: SQLH UpdateValueInt Temperatuur kamer HwID:2  DevID:1 Type:80  sType:5 nValue:0 sValue:18.0
2020-02-23 06:40:48.194  Error: #0  /home/pi/domoticz/domoticz() [0x2cd824]
2020-02-23 06:40:48.201  Error: #1  /home/pi/domoticz/domoticz : signal_handler(int, siginfo_t*, void*) + 0x1f8 [0x2ce1e0]
2020-02-23 06:40:48.201  Error: #2  /lib/arm-linux-gnueabihf/libc.so.6 : __default_rt_sa_restorer + 0 [0x76a14130]
2020-02-23 07:07:12.376  Status: Domoticz V4.11674 (c)2012-2020 GizMoCuz
2020-02-23 07:07:12.406  Status: Build Hash: 91c3475ac, Date: 2020-02-09 10:00:09
2020-02-23 07:07:12.407  Status: Startup Path: /home/pi/domoticz/
2020-02-23 07:07:21.384  Sunrise: 07:37:00 SunSet: 18:03:00
2020-02-23 07:07:21.385  Day length: 10:27:00 Sun at south: 12:50:00
____________________________________________________________-
2020-02-23 21:34:32.164  Debug: SQLH UpdateValueInt Ingestelde temperatuur Nefit Easy HwID:2  DevID:0010101 Type:242  sType:1 nValue:0 sValue:19.00
2020-02-23 21:34:32.184  (Nefit Easy Thermostaat ) Thermostat (Ingestelde temperatuur Nefit Easy)
2020-02-23 21:34:32.211  Debug: SQLH UpdateValueInt Temperatuur kamer HwID:2  DevID:1 Type:80  sType:5 nValue:0 sValue:19.1
2020-02-23 21:34:32.230  (Nefit Easy Thermostaat ) Temp (Temperatuur kamer)
2020-02-23 21:34:32.352  Debug: SQLH UpdateValueInt Flow Temperature HwID:2  DevID:3 Type:80  sType:5 nValue:0 sValue:41.0
2020-02-23 21:34:32.352  (Nefit Easy Thermostaat ) Temp (Flow Temperature)
2020-02-23 21:34:34.633  Debug: SQLH UpdateValueInt Cooling HwID:11  DevID:0000502 Type:242  sType:1 nValue:0 sValue:21.00
2020-02-23 21:34:34.634  (Zwave USB) Thermostat (Cooling)
2020-02-23 21:34:34.693  Debug: SQLH UpdateValueInt Cooling HwID:11  DevID:0000502 Type:242  sType:1 nValue:0 sValue:21.00
2020-02-23 21:34:34.695  (Zwave USB) Thermostat (Cooling)
2020-02-23 21:34:44.685  Debug: SQLH UpdateValueInt PiMonitor - CPU usage HwID:10  DevID:000A0004 Type:243  sType:31 nValue:4 sValue:4.4
2020-02-23 21:34:44.688  Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11  DevID:00000501 Type:243  sType:29 nValue:0 sValue:748.630;768400.000
2020-02-23 21:34:44.708  (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter)
2020-02-23 21:34:44.730  Error: Domoticz(pid:2161, tid:2215('PluginMgr')) received fatal signal 11 (Segmentation fault)
2020-02-23 21:34:44.730  Error: siginfo address=0x871, address=(nil)
2020-02-23 21:34:44.822  Debug: SQLH UpdateValueInt Vloerverwarming badkamer stroomverbruik HwID:11  DevID:0000501 Type:248  sType:1 nValue:0 sValue:748.3
2020-02-23 21:34:44.841  (Zwave USB) Usage (Vloerverwarming badkamer stroomverbruik)
2020-02-23 21:34:44.854  Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11  DevID:00000501 Type:243  sType:29 nValue:0 sValue:748.260;768400.000
2020-02-23 21:34:44.866  (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter)
2020-02-23 21:34:44.977  Debug: SQLH UpdateValueInt Voltage HwID:11  DevID:00000501 Type:243  sType:8 nValue:0 sValue:230.500
2020-02-23 21:34:44.977  (Zwave USB) General/Voltage (Voltage)
2020-02-23 21:34:51.145  Error: Thread 4 (Thread 0x74b6e220 (LWP 2215)):
2020-02-23 21:34:51.146  Error: #0  __waitpid (options=0, stat_loc=0x74b6c2d0, pid=23733) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2020-02-23 21:34:51.146  Error: #1  __waitpid (pid=23733, stat_loc=0x74b6c2d0, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2020-02-23 21:34:51.146  Error: #2  0x002cdbcc in dumpstack_gdb(bool) ()
2020-02-23 21:34:51.146  Error: #3  0x002ce198 in signal_handler(int, siginfo_t*, void*) ()
2020-02-23 21:34:51.146  Error: #4  <signal handler called>
2020-02-23 21:34:51.146  Error: #5  raise (sig=11) at ../sysdeps/unix/sysv/linux/raise.c:50
2020-02-23 21:34:51.146  Error: #6  <signal handler called>
2020-02-23 21:34:51.146  Error: #7  0x007d4e04 in packet.queue ()
2020-02-23 21:34:51.146  Error: #8  0x007d7df0 in send.real_publish ()
2020-02-23 21:34:51.146  Error: #9  0x007cfc14 in mosquitto_publish ()
2020-02-23 21:34:51.146  Error: #10 0x002b46dc in mosqdz::mosquittodz::publish(int*, char const*, int, void const*, int, bool) ()
2020-02-23 21:34:51.146  Error: #11 0x004c16f0 in MQTT::SendMessage(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
2020-02-23 21:34:51.146  Error: #12 0x004c3184 in MQTT::SendDeviceInfo(int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*) ()
2020-02-23 21:34:51.146  Error: #13 0x002b379c in boost::signals2::detail::signal_impl<void (int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*), boost::signals2::optional_last_value<void>, int, std::less<int>, boost::function<void (int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*)>, boost::function<void (boost::signals2::connection const&, int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*)>, boost::signals2::mutex>::operator()(int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*) ()
2020-02-23 21:34:51.146  Error: #14 0x006330c8 in Plugins::CDevice_update(Plugins::CDevice*, _object*, _object*) ()
2020-02-23 21:34:51.146  Error: #15 0x75e42d48 in _PyMethodDef_RawFastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2020-02-23 21:34:51.146  Error: #16 0x75e43ca4 in _PyCFunction_FastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2020-02-23 21:34:51.146  Error: #17 0x75c431d4 in _PyEval_EvalFrameDefault () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2020-02-23 21:34:51.146  Error: #18 0x75d754d4 in _PyEval_EvalCodeWithName () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2020-02-23 21:34:51.146  Error: #19 0x75e43340 in _PyFunction_FastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2020-02-23 21:34:51.146  Error: #20 0x75c40950 in _PyEval_EvalFrameDefault () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2020-02-23 21:34:51.146  Error: #21 0x75c44dd4 in ?? () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2020-03-02 01:23:23.024  Debug: SQLH UpdateValueInt Temperature HwID:11  DevID:1282 Type:80  sType:5 nValue:0 sValue:22.1
2020-03-02 01:23:23.044  (Zwave USB) Temp (Temperature)
2020-03-02 01:23:27.056  Debug: SQLH UpdateValueInt Xiron HwID:3  DevID:20482 Type:82  sType:5 nValue:0 sValue:18.2;48;1
2020-03-02 01:23:27.056  (433Mhz RFlink Gateway) Temp + Humidity (Xiron)
2020-03-02 01:23:32.074  Debug: SQLH UpdateValueInt Ingestelde temperatuur Nefit Easy HwID:2  DevID:0010101 Type:242  sType:1 nValue:0 sValue:17.00
2020-03-02 01:23:32.093  (Nefit Easy Thermostaat ) Thermostat (Ingestelde temperatuur Nefit Easy)
2020-03-02 01:23:32.096  Debug: SQLH UpdateValueInt Temperatuur kamer HwID:2  DevID:1 Type:80  sType:5 nValue:0 sValue:18.7
2020-03-02 01:23:32.133  (Nefit Easy Thermostaat ) Temp (Temperatuur kamer)
2020-03-02 01:23:32.262  Debug: SQLH UpdateValueInt Flow Temperature HwID:2  DevID:3 Type:80  sType:5 nValue:0 sValue:52.0
2020-03-02 01:23:32.262  (Nefit Easy Thermostaat ) Temp (Flow Temperature)
2020-03-02 01:23:33.023  Debug: SQLH UpdateValueInt PiMonitor - CPU temperature HwID:10  DevID:000A0001 Type:243  sType:31 nValue:50 sValue:50.5
2020-03-02 01:23:33.038  Debug: SQLH UpdateValueInt Vloerverwarming badkamer temp. instelling HwID:11  DevID:0000501 Type:242  sType:1 nValue:0 sValue:21.00
2020-03-02 01:23:33.064  (Zwave USB) Thermostat (Vloerverwarming badkamer temp. instelling)
2020-03-02 01:23:33.081  Error: Domoticz(pid:27323, tid:27329('PluginMgr')) received fatal signal 11 (Segmentation fault)
2020-03-02 01:23:33.081  Error: siginfo address=0x6abb, address=(nil)
2020-03-02 01:23:33.099  Debug: SQLH UpdateValueInt Vloerverwarming badkamer temp. instelling HwID:11  DevID:0000501 Type:242  sType:1 nValue:0 sValue:21.00
2020-03-02 01:23:33.111  (Zwave USB) Thermostat (Vloerverwarming badkamer temp. instelling)
2020-03-02 01:23:33.127  Debug: SQLH UpdateValueInt Vloerverwarming badkamer temp. instelling HwID:11  DevID:0000501 Type:242  sType:1 nValue:0 sValue:21.00
2020-03-02 01:23:33.137  (Zwave USB) Thermostat (Vloerverwarming badkamer temp. instelling)
2020-03-02 02:20:29.128  Error: MQTT: disconnected, restarting (rc=7)
2020-03-02 02:20:29.128  Status: Schedule item started! Name: Vloerverwarming badkamer temp. instelling, Type: On Time, ThermostatID: 403, Time: 2020-03-02 02:20:28
2020-03-02 02:20:29.128  Error: mainworker seems to have ended or hung unexpectedly (last update 3420.000000 seconds ago)
2020-03-02 02:20:29.361  Debug: SQLH: Do Task ItemType:4 Cmd:Off Value:
2020-03-02 02:20:30.196  Error: Domoticz(27323) is exiting due to watchdog triggered...
2020-03-02 02:20:30.220  Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-03-02 02:20:32.568  Error: #0  /home/pi/domoticz/domoticz() [0x2cd824]
2020-03-02 02:20:32.798  Error: #1  /home/pi/domoticz/domoticz : signal_handler(int, siginfo_t*, void*) + 0x1f8 [0x2ce1e0]
2020-03-02 02:20:32.798  Error: #2  /lib/arm-linux-gnueabihf/libc.so.6 : __default_rt_sa_restorer + 0 [0x76991130]
