Blocky interface down Topic is solved
masselb
Domoticz version: 4.10717
Post by masselb »
Hello peeps, I have had a crash of my SD-card but luckily i save the database. So, format a new card, put buster on it, then domoticz, placed the database back. So far, so good, all fine. However, opening my events tab shows no normal screen. Script I had running under blockly works, however I have no interface left. That is, cannot switch the script on or off, not even delete it or make a new one. Last state was off and it still is.
I suspect having a problem with my factories.js in the /events folder.
Anybody has a solution to this? It is pretty annoying ;)
Re: Blocky interface down
masselb wrote: Tuesday 24 March 2020 17:46 Anybody has a solution to this? It is pretty annoying ;)
Did you try to clear browsercache and appcache ? ( different things.)
masselb
Post by masselb »
Hello Waaren,
I did. Afterwards, I rebooted the pi with event option off. Then put it back on and booted the pi again. WORKED! That is, everything is fine now but I am not sure why :)) Still, thx a million even for giving my post some time. :D
AimoPaukku
Domoticz version: Stable
Post by AimoPaukku »
Mine looks like the same with edge browser.
With crome all normal.
thomasbaetge
Domoticz version: 2023.1
Post by thomasbaetge »
Hi All,
I am facing the same issue on my PI after the upgrade to 2020.1.
Tried clearing every cache, rebooted several times, no luck at all. The problem persists on different devices (Laptop / Phone).
Only the edge browser shows at least the headers in the right pane at the top, but the blockly section is empty in any case.
Please advice!
Thanks in advance!
EDIT: I fixed it:
Set Domoticz to default theme
clear browser data (all)
--> Works again
after that you can change the theme again.
