Revert to previous version
Posted: Tuesday 24 March 2020 12:20
by zenodalla
Hi, I have a RPi3b+ running osmc. For this reason I think I cannot run the latest domoticz 2020 ver. In fact it doesn't work anymore. Yesterday it was all ok, then an update message appeared in the web interface, so I updated it, but it was an error. I read today after wasting hours that a new version of linux is needed and I can't update it. So my question is: how do i revert to previous version? I found in the github page a section called releases in which i found this release "Stable Release 4.10717" but I don't know how to instll it and I can't find a guide about how to install it. Can anyone help me?
thank you all
edit: I didn't make a backup
edit edit: I found an sd card which contains a versione of domoticz that i don't update from last year. So if I copy the domoticz folder from that sd home/pi/domoticz to /home/osmc after I install the current 2020 ver.1 it should work, doesn't it?
Re: Revert to previous version
Posted: Tuesday 24 March 2020 21:36
by Domange
I can't find how to retrieve a previous binary version but I follow the instructions indicated here
https://www.domoticz.com/wiki/Build_Dom ... rom_source
I choose the version tagged 4.10726 on the source control
I must adapt the script because I have 2 errors, one about Lua 5.2 (the 5.3 version was installed in the document) and the other is about the BOOST library.
I do quick and ugly, I remove the 2 tests but It works fine.
So I have the following CMakeLists.txt file
#set to minimum version that supports clean build on cygwin
cmake_minimum_required(VERSION 2.8.4)
project(domoticz)
## required min. libBoost version
SET(DOMO_MIN_LIBBOOST_VERSION 106000)
MACRO(Gitversion_GET_REVISION dir variable)
EXECUTE_PROCESS(COMMAND ${GIT_EXECUTABLE} --git-dir ./.git rev-list HEAD --count
WORKING_DIRECTORY ${dir}
OUTPUT_VARIABLE ${variable}
OUTPUT_STRIP_TRAILING_WHITESPACE)
ENDMACRO(Gitversion_GET_REVISION)
Gitversion_GET_REVISION("${CMAKE_SOURCE_DIR}" ProjectRevision)
IF(NOT ProjectRevision)
MESSAGE(STATUS "Failed to get ProjectRevision from git")
IF(EXISTS ${CMAKE_SOURCE_DIR}/appversion.default)
MESSAGE(STATUS "Read ProjectRevision from appversion.default")
FILE(STRINGS ${CMAKE_SOURCE_DIR}/appversion.default AppVersionContent)
LIST(GET AppVersionContent 0 AppVersionContent)
STRING(REPLACE " " ";" AppVersionContent ${AppVersionContent})
LIST(GET AppVersionContent 2 ProjectRevision)
ELSE(EXISTS ${CMAKE_SOURCE_DIR}/appversion.default)
MESSAGE(STATUS "No appversion.default, set ProjectRevision to 0")
set (ProjectRevision 0)
ENDIF(EXISTS ${CMAKE_SOURCE_DIR}/appversion.default)
ELSE(NOT ProjectRevision)
MATH(EXPR ProjectRevision "${ProjectRevision}+2107")
ENDIF(NOT ProjectRevision)
MESSAGE(STATUS "###########################")
MESSAGE(STATUS "Compiling Revision #${ProjectRevision}")
# The version number.
set (domoticz_VERSION_MAJOR 4)
set (domoticz_VERSION_MINOR 0)
set (domoticz_VERSION_PATCH ${ProjectRevision})
if (CMAKE_CXX_COMPILER_ID MATCHES "Clang")
set(CMAKE_CXX_STANDARD 11)
set(CMAKE_CXX_STANDARD_REQUIRED ON)
set(CXX_EXTENSIONS NO)
endif()
option(USE_OPENSSL_STATIC "Link OpenSSL static" YES)
IF(USE_OPENSSL_STATIC)
set(OPENSSL_USE_STATIC_LIBS TRUE)
ENDIF(USE_OPENSSL_STATIC)
option(USE_BUILTIN_LUA "Use builtin lua library" YES)
#IF(USE_BUILTIN_LUA)
IF(CMAKE_SYSTEM_NAME STREQUAL "Darwin")
add_definitions(-DLUA_USE_MACOSX)
ENDIF()
add_subdirectory (lua)
get_directory_property (LUA_LIBRARIES DIRECTORY lua
DEFINITION LUA_LIBRARIES)
option(USE_BUILTIN_MQTT "Use builtin Mosquitto library" YES)
IF(USE_BUILTIN_MQTT)
message(STATUS "Using builtin Mosquitto library")
add_subdirectory (MQTT)
get_directory_property (MQTT_LIBRARIES DIRECTORY MQTT
DEFINITION MQTT_LIBRARIES)
add_definitions(-DBUILTIN_MQTT)
ELSE(USE_BUILTIN_MQTT)
find_path(MQTT_INCLUDE_DIRS NAMES mosquittopp.h)
IF(MQTT_INCLUDE_DIRS)
message(STATUS "Found mosquittopp.h at: ${MQTT_INCLUDE_DIRS}")
find_library(MQTT_LIBRARIES NAMES libmosquittopp.so)
IF(MQTT_LIBRARIES)
message(STATUS "Found libmosquittopp at: ${MQTT_LIBRARIES}")
ENDIF(MQTT_LIBRARIES)
INCLUDE_DIRECTORIES(${MQTT_INCLUDE_DIRS})
ELSE(MQTT_INCLUDE_DIRS)
message(FATAL_ERROR "Mosquitto includes or library cannot be found, and you ask to NOT use builtin")
ENDIF(MQTT_INCLUDE_DIRS)
ENDIF(USE_BUILTIN_MQTT)
option(USE_BUILTIN_SQLITE "Use builtin sqlite library" YES)
IF(USE_BUILTIN_SQLITE)
add_subdirectory (sqlite)
get_directory_property (SQLite_LIBRARIES DIRECTORY sqlite
DEFINITION SQLite_LIBRARIES)
ELSE(USE_BUILTIN_SQLITE)
find_package(PkgConfig)
pkg_check_modules(SQLite QUIET sqlite3)
IF(SQLite_FOUND)
INCLUDE_DIRECTORIES(${SQLite_INCLUDE_DIRS})
add_definitions(-DWITH_EXTERNAL_SQLITE)
ELSE(SQLite_FOUND)
MESSAGE(FATAL_ERROR "SQLite3 not found but USE_BUILTIN_SQLITE=NO")
ENDIF(SQLite_FOUND)
ENDIF(USE_BUILTIN_SQLITE)
option(USE_PYTHON "Use Python for Plugins and Event-Scripts" YES)
IF(USE_PYTHON)
find_package(PythonInterp 3.4)
find_package(PythonLibs 3.4)
IF(PYTHONLIBS_FOUND)
MESSAGE(STATUS "Python3 includes found at: ${PYTHON_INCLUDE_PATH}")
INCLUDE_DIRECTORIES(${PYTHON_INCLUDE_PATH})
add_definitions(-DENABLE_PYTHON)
ELSE(PYTHONLIBS_FOUND)
MESSAGE(FATAL_ERROR "Python3 not found on your system, use USE_PYTHON=NO or sudo apt-get install python3-dev)")
ENDIF(PYTHONLIBS_FOUND)
ENDIF(USE_PYTHON)
SET(EXECUTABLE_OUTPUT_PATH "" CACHE INTERNAL
"Where to put the executables for Domoticz"
INCLUDE(CheckIncludeFile)
CHECK_INCLUDE_FILE (execinfo.h HAVE_EXECINFO_H)
IF(HAVE_EXECINFO_H)
# FreeBSD has to include libexecinfo
IF(CMAKE_SYSTEM_NAME STREQUAL "FreeBSD")
find_library(EXECINFO_LIBRARIES NAMES libexecinfo.so)
IF(EXECINFO_LIBRARIES)
ADD_DEFINITIONS(-DHAVE_EXECINFO_H)
ENDIF()
ELSEIF(CMAKE_SYSTEM_NAME STREQUAL "NetBSD")
ENDIF()
ELSE()
ENDIF()
ENDIF(HAVE_EXECINFO_H)
INCLUDE(CheckIncludeFiles)
option(INCLUDE_LINUX_I2C "Include I2C support" YES)
IF (INCLUDE_LINUX_I2C)
CHECK_INCLUDE_FILES ("sys/types.h;linux/i2c-dev.h;linux/i2c.h" HAVE_LINUX_I2C_H)
IF (HAVE_LINUX_I2C_H)
message(STATUS "Building with I2C support")
add_definitions(-DHAVE_LINUX_I2C)
ELSE()
message(WARNING "I2C support disabled: headers not found!")
ENDIF (HAVE_LINUX_I2C_H)
ENDIF (INCLUDE_LINUX_I2C)
option(INCLUDE_SPI "Include SPI support" YES)
IF (INCLUDE_SPI)
CHECK_INCLUDE_FILES ("sys/types.h;linux/spi/spidev.h" HAVE_LINUX_SPI_H)
IF (HAVE_LINUX_SPI_H)
message(STATUS "Building with SPI support")
add_definitions(-DHAVE_LINUX_SPI)
ELSE()
message(WARNING "SPI support disabled: headers not found!")
ENDIF (HAVE_LINUX_SPI_H)
ENDIF (INCLUDE_SPI)
#set(CMAKE_EXE_LINKER_FLAGS "-static")
# Macro for setting up precompiled headers. Usage:
# add_precompiled_header(target header.h [FORCEINCLUDE])
# MSVC: A source file with the same name as the header must exist and
# be included in the target (E.g. header.cpp).
# MSVC: Add FORCEINCLUDE to automatically include the precompiled
# header file from every source file.
# GCC: The precompiled header is always automatically included from
# every header file.
MACRO(ADD_PRECOMPILED_HEADER _targetName _input)
GET_FILENAME_COMPONENT(_inputWe ${_input} NAME_WE)
SET(pch_source ${_inputWe}.cpp)
FOREACH(arg ${ARGN})
IF(arg STREQUAL FORCEINCLUDE)
SET(FORCEINCLUDE ON)
ELSE(arg STREQUAL FORCEINCLUDE)
SET(FORCEINCLUDE OFF)
ENDIF(arg STREQUAL FORCEINCLUDE)
ENDFOREACH(arg)
IF(MSVC)
GET_TARGET_PROPERTY(sources ${_targetName} SOURCES)
SET(_sourceFound FALSE)
FOREACH(_source ${sources})
SET(PCH_COMPILE_FLAGS "")
IF(_source MATCHES \\.\(cc|cxx|cpp\)$)
GET_FILENAME_COMPONENT(_sourceWe ${_source} NAME_WE)
IF(_sourceWe STREQUAL ${_inputWe})
SET(PCH_COMPILE_FLAGS "${PCH_COMPILE_FLAGS} /Yc${_input}")
SET(_sourceFound TRUE)
ELSE(_sourceWe STREQUAL ${_inputWe})
SET(PCH_COMPILE_FLAGS "${PCH_COMPILE_FLAGS} /Yu${_input}")
IF(FORCEINCLUDE)
SET(PCH_COMPILE_FLAGS "${PCH_COMPILE_FLAGS} /FI${_input}")
ENDIF(FORCEINCLUDE)
ENDIF(_sourceWe STREQUAL ${_inputWe})
SET_SOURCE_FILES_PROPERTIES(${_source} PROPERTIES COMPILE_FLAGS "${PCH_COMPILE_FLAGS}")
ENDIF(_source MATCHES \\.\(cc|cxx|cpp\)$)
ENDFOREACH()
IF(NOT _sourceFound)
MESSAGE(FATAL_ERROR "A source file for ${_input} was not found. Required for MSVC builds.")
ENDIF(NOT _sourceFound)
ENDIF(MSVC)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wno-switch -Wno-parentheses-equality -Wno-deprecated-declarations -Wno-tautological-compare -Wno-unused-value -Wno-comment -Wno-unsequenced -Wno-logical-op-parentheses -Wno-literal-conversion")
ENDIF()
IF(CMAKE_SYSTEM_NAME STREQUAL "OpenBSD")
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -pthread")
ENDIF()
ENDIF()
IF(CMAKE_COMPILER_IS_GNUCXX)
SET(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++11")
#SET(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -Wno-switch")
#ADD_DEFINITIONS( -Wall -O0 -ggdb )
#ADD_DEFINITIONS( -Wfatal-errors -Wformat=2 -Werror=format-security )
GET_FILENAME_COMPONENT(_name ${_input} NAME)
SET(_source "${CMAKE_CURRENT_SOURCE_DIR}/${_input}")
SET(_outdir "${CMAKE_CURRENT_BINARY_DIR}/${_name}.gch")
MAKE_DIRECTORY(${_outdir})
SET(_output "${_outdir}/.c++")
STRING(TOUPPER "CMAKE_CXX_FLAGS_${CMAKE_BUILD_TYPE}" _flags_var_name)
# Strip out -Wl,… linker directives as they make GCC fail
STRING(REGEX REPLACE " -Wl,[^ ]*" " " _compiler_FLAGS " ${CMAKE_CXX_FLAGS} ${${_flags_var_name}}")
GET_DIRECTORY_PROPERTY(_directory_flags INCLUDE_DIRECTORIES)
FOREACH(item ${_directory_flags})
LIST(APPEND _compiler_FLAGS "-I${item}")
ENDFOREACH(item)
GET_DIRECTORY_PROPERTY(_directory_flags COMPILE_DEFINITIONS)
LIST(APPEND _compiler_FLAGS "-D${item}")
ENDFOREACH(item)
SEPARATE_ARGUMENTS(_compiler_FLAGS)
MESSAGE("${CMAKE_CXX_COMPILER} ${CMAKE_CXX_COMPILER_ARG1} ${_compiler_FLAGS} -x c++-header -o ${_output} ${_source}")
ADD_CUSTOM_COMMAND(
OUTPUT ${_output}
COMMAND ${CMAKE_CXX_COMPILER} ${CMAKE_CXX_COMPILER_ARG1} ${_compiler_FLAGS} -x c++-header -o ${_output} ${_source}
DEPENDS ${_source} )
ADD_CUSTOM_TARGET(${_targetName}_gch DEPENDS ${_output})
ADD_DEPENDENCIES(${_targetName} ${_targetName}_gch)
SET_TARGET_PROPERTIES(${_targetName} PROPERTIES COMPILE_FLAGS "-include ${_name} -Winvalid-pch")
ENDIF(CMAKE_COMPILER_IS_GNUCXX)
ENDMACRO()
FIND_PROGRAM(GIT_EXECUTABLE git
DOC "git command line client")
include_directories(${CMAKE_SOURCE_DIR}/main)
include_directories(${CMAKE_SOURCE_DIR}/tinyxpath)
# a custom target that is always built
ADD_CUSTOM_TARGET(revisiontag ALL)
# creates appversion.h using cmake script
ADD_CUSTOM_COMMAND(TARGET revisiontag COMMAND ${CMAKE_COMMAND}
-DSOURCE_DIR=${CMAKE_CURRENT_SOURCE_DIR}
-P ${CMAKE_CURRENT_SOURCE_DIR}/getgit.cmake)
## Target
set(
domoticz_SRCS
main/stdafx.cpp
main/BaroForecastCalculator.cpp
main/CmdLine.cpp
main/Camera.cpp
main/domoticz.cpp
main/dzVents.cpp
main/EventSystem.cpp
main/EventsPythonModule.cpp
main/EventsPythonDevice.cpp
main/Helper.cpp
main/IFTTT.cpp
main/localtime_r.cpp
main/Logger.cpp
main/LuaCommon.cpp
main/LuaHandler.cpp
main/mainworker.cpp
main/RFXNames.cpp
main/Scheduler.cpp
main/SignalHandler.cpp
main/SQLHelper.cpp
main/SunRiseSet.cpp
main/TrendCalculator.cpp
main/WebServer.cpp
main/WebServerHelper.cpp
main/WindCalculation.cpp
push/BasePush.cpp
push/FibaroPush.cpp
push/GooglePubSubPush.cpp
push/HttpPush.cpp
push/InfluxPush.cpp
push/WebsocketPush.cpp
httpclient/HTTPClient.cpp
httpclient/UrlEncode.cpp
hardware/1Wire.cpp
hardware/1Wire/1WireByOWFS.cpp
hardware/1Wire/1WireByKernel.cpp
hardware/1Wire/1WireCommon.cpp
hardware/1Wire/1WireForWindows.cpp
hardware/AccuWeather.cpp
hardware/AnnaThermostat.cpp
hardware/Arilux.cpp
hardware/ASyncSerial.cpp
hardware/ASyncTCP.cpp
hardware/AtagOne.cpp
hardware/BleBox.cpp
hardware/cayenne_lpp/CayenneLPP_Dec.cpp
hardware/ColorSwitch.cpp
hardware/Comm5Serial.cpp
hardware/Comm5SMTCP.cpp
hardware/Comm5TCP.cpp
hardware/csocket.cpp
hardware/CurrentCostMeterBase.cpp
hardware/CurrentCostMeterSerial.cpp
hardware/CurrentCostMeterTCP.cpp
hardware/Daikin.cpp
hardware/DarkSky.cpp
hardware/DavisLoggerSerial.cpp
hardware/DenkoviDevices.cpp
hardware/DenkoviUSBDevices.cpp
hardware/DenkoviTCPDevices.cpp
hardware/DomoticzHardware.cpp
hardware/DomoticzInternal.cpp
hardware/DomoticzTCP.cpp
hardware/Dummy.cpp
hardware/EcoCompteur.cpp
hardware/EcoDevices.cpp
hardware/eHouseTCP.cpp
hardware/eHouse/EhouseEvents.cpp
hardware/eHouse/EhouseTcpClient.cpp
hardware/eHouse/EhouseUdpListener.cpp
hardware/EnOceanESP2.cpp
hardware/EnOceanESP3.cpp
hardware/EnphaseAPI.cpp
hardware/Ec3kMeterTCP.cpp
hardware/EvohomeBase.cpp
hardware/EvohomeRadio.cpp
hardware/EvohomeScript.cpp
hardware/EvohomeSerial.cpp
hardware/EvohomeTCP.cpp
hardware/EvohomeWeb.cpp
hardware/ETH8020.cpp
hardware/FritzboxTCP.cpp
hardware/GoodweAPI.cpp
hardware/Gpio.cpp
hardware/GpioPin.cpp
hardware/HardwareMonitor.cpp
hardware/HarmonyHub.cpp
hardware/Honeywell.cpp
hardware/HEOS.cpp
hardware/I2C.cpp
hardware/ICYThermostat.cpp
hardware/InComfort.cpp
hardware/KMTronicBase.cpp
hardware/KMTronic433.cpp
hardware/KMTronicSerial.cpp
hardware/KMTronicTCP.cpp
hardware/KMTronicUDP.cpp
hardware/Kodi.cpp
hardware/Limitless.cpp
hardware/LogitechMediaServer.cpp
hardware/Meteostick.cpp
hardware/MochadTCP.cpp
hardware/MQTT.cpp
hardware/MultiFun.cpp
hardware/MySensorsBase.cpp
hardware/MySensorsSerial.cpp
hardware/MySensorsTCP.cpp
hardware/MySensorsMQTT.cpp
hardware/NefitEasy.cpp
hardware/Nest.cpp
hardware/NestOAuthAPI.cpp
hardware/Netatmo.cpp
hardware/HttpPoller.cpp
hardware/OnkyoAVTCP.cpp
hardware/OpenWeatherMap.cpp
hardware/OpenWebNetTCP.cpp
hardware/OpenWebNetUSB.cpp
hardware/openwebnet/bt_openwebnet.cpp
hardware/OpenZWave.cpp
hardware/openzwave/control_panel/ozwcp.cpp
hardware/openzwave/control_panel/zwavelib.cpp
hardware/OTGWBase.cpp
hardware/OTGWSerial.cpp
hardware/OTGWTCP.cpp
hardware/PanasonicTV.cpp
hardware/P1MeterBase.cpp
hardware/P1MeterSerial.cpp
hardware/P1MeterTCP.cpp
hardware/PhilipsHue/PhilipsHue.cpp
hardware/PhilipsHue/PhilipsHueHelper.cpp
hardware/PhilipsHue/PhilipsHueSensors.cpp
hardware/PiFace.cpp
hardware/Pinger.cpp
hardware/PVOutput_Input.cpp
hardware/RAVEn.cpp
hardware/Rego6XXSerial.cpp
hardware/RelayNet.cpp
hardware/RFLinkBase.cpp
hardware/RFLinkSerial.cpp
hardware/RFLinkTCP.cpp
hardware/RFXBase.cpp
hardware/RFXComSerial.cpp
hardware/RFXComTCP.cpp
hardware/Rtl433.cpp
hardware/S0MeterBase.cpp
hardware/S0MeterSerial.cpp
hardware/S0MeterTCP.cpp
hardware/SatelIntegra.cpp
hardware/SBFSpot.cpp
hardware/serial/serial.cpp
hardware/serial/impl/unix.cpp
hardware/SolarEdgeAPI.cpp
hardware/SolarMaxTCP.cpp
hardware/Sterbox.cpp
hardware/SysfsGpio.cpp
hardware/Tado.cpp
hardware/TCPProxy/tcpproxy_server.cpp
hardware/TE923.cpp
hardware/TE923Tool.cpp
hardware/TeleinfoBase.cpp
hardware/TeleinfoSerial.cpp
hardware/Tellstick.cpp
hardware/TellstickFactory.cpp
hardware/Thermosmart.cpp
hardware/ToonThermostat.cpp
hardware/TTNMQTT.cpp
hardware/USBtin.cpp
hardware/USBtin_MultiblocV8.cpp
hardware/VolcraftCO20.cpp
hardware/Winddelen.cpp
hardware/WOL.cpp
hardware/Wunderground.cpp
hardware/XiaomiGateway.cpp
hardware/Yeelight.cpp
hardware/YouLess.cpp
hardware/ZiBlueBase.cpp
hardware/ZiBlueSerial.cpp
hardware/ZiBlueTCP.cpp
hardware/ZWaveBase.cpp
hardware/plugins/DelayedLink.cpp
hardware/plugins/Plugins.cpp
hardware/plugins/PluginManager.cpp
hardware/plugins/PluginProtocols.cpp
hardware/plugins/PluginTransports.cpp
hardware/plugins/PythonObjects.cpp
notifications/NotificationBase.cpp
notifications/NotificationBrowser.cpp
notifications/NotificationEmail.cpp
notifications/NotificationGCM.cpp
notifications/NotificationHelper.cpp
notifications/NotificationHTTP.cpp
notifications/NotificationKodi.cpp
notifications/NotificationLogitechMediaServer.cpp
notifications/NotificationPushbullet.cpp
notifications/NotificationProwl.cpp
notifications/NotificationPushover.cpp
notifications/NotificationPushsafer.cpp
notifications/NotificationPushalot.cpp
notifications/NotificationSMS.cpp
notifications/NotificationTelegram.cpp
smtpclient/SMTPClient.cpp
tcpserver/TCPClient.cpp
tcpserver/TCPServer.cpp
webserver/Base64.cpp
webserver/connection.cpp
webserver/connection_manager.cpp
webserver/cWebem.cpp
webserver/fastcgi.cpp
webserver/mime_types.cpp
webserver/proxycereal.cpp
webserver/proxyclient.cpp
webserver/reply.cpp
webserver/request_handler.cpp
webserver/request_parser.cpp
webserver/server.cpp
webserver/Websockets.cpp
webserver/WebsocketHandler.cpp
json/json_reader.cpp
json/json_value.cpp
json/json_writer.cpp
tinyxpath/action_store.cpp
tinyxpath/htmlutil.cpp
tinyxpath/lex_util.cpp
tinyxpath/node_set.cpp
tinyxpath/tinystr.cpp
tinyxpath/tinyxml.cpp
tinyxpath/tinyxmlerror.cpp
tinyxpath/tinyxmlparser.cpp
tinyxpath/tokenlist.cpp
tinyxpath/xml_util.cpp
tinyxpath/xpath_expression.cpp
tinyxpath/xpath_processor.cpp
tinyxpath/xpath_stream.cpp
tinyxpath/xpath_stack.cpp
tinyxpath/xpath_static.cpp
tinyxpath/xpath_syntax.cpp
add_executable(domoticz ${domoticz_SRCS})
# explicitly say that the executable depends on the revisiontag
add_dependencies(domoticz revisiontag)
INCLUDE(TestBigEndian)
TEST_BIG_ENDIAN(BIGENDIAN)
IF(${BIGENDIAN})
ADD_DEFINITIONS(-DIS_BIG_ENDIAN)
ENDIF(${BIGENDIAN})
## Link libraries
# Find MD5/RMD160/SHA library
find_package(OpenSSL REQUIRED)
if(NOT OPENSSL_INCLUDE_DIR)
message(SEND_ERROR "Failed to find OpenSSL include files (ssl.h), no HTTPS support")
endif()
if(NOT OPENSSL_FOUND)
message(SEND_ERROR "Failed to find the OpenSSL library, no HTTPS support")
find_library(MD_LIBRARY NAMES md)
if(MD_LIBRARY)
target_link_libraries(domoticz ${MD_LIBRARY})
endif(MD_LIBRARY)
else()
message(STATUS "OPENSSL_LIBRARIES: ${OPENSSL_LIBRARIES}")
add_definitions(-DWWW_ENABLE_SSL)
include_directories(${OPENSSL_INCLUDE_DIR})
target_link_libraries(domoticz ${OPENSSL_LIBRARIES})
endif()
# Boost
option(USE_STATIC_BOOST "Build with static BOOST libraries" YES)
set(Boost_USE_STATIC_LIBS ${USE_STATIC_BOOST})
set(Boost_USE_MULTITHREADED ON)
unset(Boost_INCLUDE_DIR CACHE)
unset(Boost_LIBRARY_DIRS CACHE)
find_package(Boost REQUIRED COMPONENTS thread system)
if(USE_STATIC_BOOST)
message(STATUS "Linking against boost static libraries")
else(USE_STATIC_BOOST)
message(STATUS "Linking against boost dynamic libraries")
endif(USE_STATIC_BOOST)
include_directories(${Boost_INCLUDE_DIRS})
# ZLIB
option(USE_BUILTIN_ZLIB "Use builtin zlib library" NO)
if(USE_BUILTIN_ZLIB)
add_subdirectory (zlib)
include_directories(${ZLIB_INCLUDE_DIRS})
else(USE_BUILTIN_ZLIB)
find_package(ZLIB REQUIRED)
if(ZLIB_FOUND)
MESSAGE(STATUS "ZLIB libraries found at: ${ZLIB_LIBRARIES}")
MESSAGE(STATUS "ZLIB includes found at: ${ZLIB_INCLUDE_DIRS}")
else()
MESSAGE(FATAL_ERROR "ZLIB not found on your system, see install.txt how to get them installed. (for example 'sudo apt-get install zlib1g-dev')")
endif(ZLIB_FOUND)
endif(USE_BUILTIN_ZLIB)
# MINIZIP
option(USE_BUILTIN_MINIZIP "Use builtin minizip library" YES)
if(USE_BUILTIN_MINIZIP)
add_subdirectory(zip)
get_directory_property(MINIZIP_LIBRARIES DIRECTORY zip DEFINITION MINIZIP_LIBRARIES)
get_directory_property(MINIZIP_INCLUDE_DIRS DIRECTORY zip DEFINITION MINIZIP_INCLUDE_DIRS)
include_directories(${MINIZIP_INCLUDE_DIRS})
else(USE_BUILTIN_MINIZIP)
pkg_check_modules(MINIZIP minizip)
if(MINIZIP_FOUND)
MESSAGE(STATUS "MINIZIP libraries found at: ${MINIZIP_LIBRARIES}")
MESSAGE(STATUS "MINIZIP includes found at: ${MINIZIP_INCLUDE_DIRS}")
else()
MESSAGE(FATAL_ERROR "MINIZIP not found on your system, see install.txt how to get them installed. (for example 'sudo apt-get install libminizip-dev')")
endif(MINIZIP_FOUND)
endif(USE_BUILTIN_MINIZIP)
# CURL
FIND_PACKAGE(CURL)
IF(CURL_FOUND)
MESSAGE(STATUS "Curl libraries found at: ${CURL_LIBRARIES}")
MESSAGE(STATUS "Curl includes found at: ${CURL_INCLUDE_DIRS}")
INCLUDE_DIRECTORIES(${CURL_INCLUDE_DIRS})
# add_definitions(-DWWW_ENABLE_SSL)
else()
MESSAGE(FATAL_ERROR "cURL not found on your system, see install.txt how to get them installed. (for example 'sudo apt-get install curl libcurl4-gnutls-dev')")
ENDIF(CURL_FOUND)
# USB
option(WITH_LIBUSB "Enable libusb support" YES)
if(WITH_LIBUSB)
find_path(LIBUSB_INCLUDE_DIR usb.h
HINTS ${PC_LIBUSB_INCLUDEDIR} ${PC_LIBUSB_INCLUDE_DIRS})
find_library(LIBUSB_LIBRARY NAMES usb
HINTS ${PC_LIBUSB_LIBDIR} ${PC_LIBUSB_LIBRARY_DIRS})
set(LIBUSB_LIBRARIES ${LIBUSB_LIBRARY})
find_package_handle_standard_args(LIBUSB DEFAULT_MSG LIBUSB_LIBRARIES LIBUSB_INCLUDE_DIR)
IF(LIBUSB_FOUND)
MESSAGE(STATUS "LIBUSB found at: ${LIBUSB_LIBRARIES}")
add_definitions(-DWITH_LIBUSB)
target_link_libraries(domoticz ${LIBUSB_LIBRARIES})
else()
MESSAGE(STATUS "==== LibUSB not found, support for TE923/Voltcraft disabled!")
ENDIF(LIBUSB_FOUND)
endif(WITH_LIBUSB)
## support lua popen on Linux platforms
#IF(${CMAKE_SYSTEM_NAME} MATCHES "Linux")
# SET(OperatingSystem "Linux")
# add_definitions(-DLUA_USE_LINUX)
#ENDIF(${CMAKE_SYSTEM_NAME} MATCHES "Linux")
# OpenZWave
# try to find open-zwave, if found, include support
option(USE_STATIC_OPENZWAVE "Build with static OpenZwave libraries" YES)
if(USE_STATIC_OPENZWAVE)
find_library(OpenZWave NAMES libopenzwave.a HINTS "../open-zwave-read-only" "../open-zwave-read-only/cpp/build")
set(OPENZWAVE_LIB ${OpenZWave})
else()
pkg_check_modules(OPENZWAVE libopenzwave)
if(OPENZWAVE_FOUND)
MESSAGE(STATUS "==== OpenZWave package found!")
find_library(OpenZWave NAMES libopenzwave.so HINTS ${OPENZWAVE_LIBRARY_DIRS})
message(STATUS ${OpenZWave})
endif()
endif()
IF(OpenZWave)
target_link_libraries(domoticz ${OpenZWave})
include_directories(${CMAKE_SOURCE_DIR}/hardware/openzwave)
add_definitions(-DWITH_OPENZWAVE)
# open-zwave needs libudev if statically linked
IF(USE_STATIC_OPENZWAVE)
set(IOKIT_LIBRARY "-framework IOKit -framework CoreFoundation" CACHE FILEPATH "IOKit framework" FORCE)
target_link_libraries(domoticz ${IOKIT_LIBRARY})
ELSEIF(CMAKE_SYSTEM_NAME STREQUAL "FreeBSD")
MESSAGE(STATUS "Building on FreeBSD, libudev not needed!")
FIND_PATH(ICONV_INCLUDE_DIR iconv.h)
FIND_LIBRARY(ICONV_LIBRARIES NAMES iconv libiconv libiconv-2 c)
IF(ICONV_INCLUDE_DIR AND ICONV_LIBRARIES)
SET(ICONV_FOUND TRUE)
#target_link_libraries(domoticz ${ICONV_INCLUDE_DIR})
target_link_libraries(domoticz ${ICONV_LIBRARIES} -lrt)
message(STATUS ${ICONV_LIBRARIES})
ELSE()
MESSAGE(FATAL_ERROR "libiconv not found on your system")
ENDIF(ICONV_INCLUDE_DIR AND ICONV_LIBRARIES)
MESSAGE(STATUS "Building on NetBSD, libudev not needed!")
ELSE()
find_library(UDEV NAMES libudev.a)
IF(UDEV)
message(STATUS ${UDEV})
target_link_libraries(domoticz ${UDEV} -lrt -lresolv)
ELSE()
find_library(UDEV NAMES libudev.so)
IF(UDEV)
ELSE()
MESSAGE(FATAL_ERROR "LIB UDEV not found on your system, see install.txt how to get them installed.\nsudo apt-get install libudev-dev")
ENDIF(UDEV)
ENDIF(UDEV)
ENDIF()
ENDIF(USE_STATIC_OPENZWAVE)
ELSE()
MESSAGE(STATUS "==== OpenZWave not found, support disabled!")
ENDIF(OpenZWave)
IF(EXISTS /sys/class/gpio)
message(STATUS "GPIO is available")
add_definitions(-DWITH_GPIO)
ELSE()
message(STATUS "GPIO is not available")
ENDIF()
find_path(TELLDUSCORE_INCLUDE NAMES telldus-core.h)
if (TELLDUSCORE_INCLUDE)
message(STATUS "Found telldus-core (telldus-core.h) at : ${TELLDUSCORE_INCLUDE}")
find_library(TELLDUS_LIBRARIES NAMES libtelldus-core.so)
if(TELLDUS_LIBRARIES)
message(STATUS "Found libtelldus-core at : ${TELLDUS_LIBRARIES}, adding telldus support")
add_definitions(-DWITH_TELLDUSCORE)
endif(TELLDUS_LIBRARIES)
else()
message(STATUS "Not found telldus-core (telldus-core.h), not adding tellstick support")
endif (TELLDUSCORE_INCLUDE)
target_link_libraries(domoticz ${Boost_LIBRARIES} ${ZLIB_LIBRARIES} ${MINIZIP_LIBRARIES} ${CURL_LIBRARIES} pthread ${LUA_LIBRARIES} ${MQTT_LIBRARIES} ${SQLite_LIBRARIES} ${CMAKE_DL_LIBS} ${TELLDUS_LIBRARIES})
elseif(CMAKE_SYSTEM_NAME STREQUAL "OpenBSD")
target_link_libraries(domoticz ${Boost_LIBRARIES} ${ZLIB_LIBRARIES} ${MINIZIP_LIBRARIES} ${CURL_LIBRARIES} pthread ${LUA_LIBRARIES} ${MQTT_LIBRARIES} ${SQLite_LIBRARIES} ${CMAKE_DL_LIBS} ${TELLDUS_LIBRARIES} ${EXECINFO_LIBRARIES})
else()
target_link_libraries(domoticz -lrt ${Boost_LIBRARIES} ${ZLIB_LIBRARIES} ${MINIZIP_LIBRARIES} ${CURL_LIBRARIES} pthread ${LUA_LIBRARIES} ${MQTT_LIBRARIES} ${SQLite_LIBRARIES} ${CMAKE_DL_LIBS} ${TELLDUS_LIBRARIES} ${EXECINFO_LIBRARIES})
ENDIF()
ADD_PRECOMPILED_HEADER(domoticz "main/stdafx.h")
option(USE_STATIC_LIBSTDCXX "Build with static libgcc/libstdc++ libraries" YES)
IF(USE_STATIC_LIBSTDCXX)
message(STATUS "Using static libgcc/libstdc++")
SET(CMAKE_SHARED_LIBRARY_LINK_C_FLAGS "${CMAKE_SHARED_LIBRARY_LINK_C_FLAGS} -static-libgcc -static-libstdc++")
SET(CMAKE_SHARED_LIBRARY_LINK_CXX_FLAGS "${CMAKE_SHARED_LIBRARY_LINK_CXX_FLAGS} -static-libgcc -static-libstdc++")
SET(CMAKE_CXX_LINK_FLAGS "${CMAKE_CXX_LINK_FLAGS} -static-libgcc -static-libstdc++")
ELSE(USE_STATIC_LIBSTDCXX)
message(STATUS "Using dynamic libgcc_s/libstdc++")
ENDIF(USE_STATIC_LIBSTDCXX)
# build a CPack driven installer package
INCLUDE(InstallRequiredSystemLibraries)
SET(CPACK_GENERATOR "DEB")
SET(CPACK_PACKAGE_NAME "domoticz")
SET(CPACK_PACKAGE_DESCRIPTION_SUMMARY "${domoticz}-Home Automation System (Domotica).")
SET(CPACK_PACKAGE_VENDOR "Domoticz.com")
SET(CPACK_PACKAGE_CONTACT "[email protected]")
SET(CPACK_RESOURCE_FILE_LICENSE "${CMAKE_CURRENT_SOURCE_DIR}/License.txt")
SET(CPACK_PACKAGE_VERSION_MAJOR "${domoticz_VERSION_MAJOR}")
SET(CPACK_PACKAGE_VERSION_MINOR "${domoticz_VERSION_MINOR}")
SET(CPACK_PACKAGE_VERSION_PATCH "${domoticz_VERSION_PATCH}")
SET(CPACK_PACKAGE_INSTALL_DIRECTORY "domoticz")
#SET (DOMOTICZ_VERSION_SHORT "${domoticz_VERSION_MAJOR}.${domoticz_VERSION_MINOR}.${domoticz_VERSION_PATCH}")
#SET(CPACK_PACKAGE_FILE_NAME "domoticz-${DOMOTICZ_VERSION_SHORT}-${CMAKE_SYSTEM_NAME}")
SET(CPACK_SOURCE_PACKAGE_FILE_NAME "${domoticz}-dev")
SET(CPACK_PACKAGING_INSTALL_PREFIX "/")
SET(CPACK_PACKAGE_DEFAULT_LOCATION "/opt/${CPACK_PACKAGE_NAME}")
SET(CPACK_PACKAGE_EXECUTABLES "domoticz;Home Automation System (Domotica).")
#set(CPACK_DEB_COMPONENT_INSTALL TRUE)
SET(CPACK_DEBIAN_ARCHITECTURE ${CMAKE_SYSTEM_PROCESSOR})
INCLUDE(CPack)
IF(CMAKE_INSTALL_PREFIX_INITIALIZED_TO_DEFAULT)
set(CMAKE_INSTALL_PREFIX "/opt/${CPACK_PACKAGE_NAME}" CACHE PATH "Install path prefix, prepended onto install directories." FORCE)
ENDIF(CMAKE_INSTALL_PREFIX_INITIALIZED_TO_DEFAULT)
install(TARGETS domoticz DESTINATION ${CMAKE_INSTALL_PREFIX})
install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/www DESTINATION ${CMAKE_INSTALL_PREFIX})
install(FILES ${CMAKE_CURRENT_SOURCE_DIR}/License.txt DESTINATION ${CMAKE_INSTALL_PREFIX})
install(FILES ${CMAKE_CURRENT_SOURCE_DIR}/History.txt DESTINATION ${CMAKE_INSTALL_PREFIX})
install(FILES ${CMAKE_CURRENT_SOURCE_DIR}/server_cert.pem DESTINATION ${CMAKE_INSTALL_PREFIX})
install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/scripts DESTINATION ${CMAKE_INSTALL_PREFIX} USE_SOURCE_PERMISSIONS)
install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/plugins DESTINATION ${CMAKE_INSTALL_PREFIX})
install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/Config DESTINATION ${CMAKE_INSTALL_PREFIX})
install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/dzVents DESTINATION ${CMAKE_INSTALL_PREFIX})
install(FILES ${CMAKE_CURRENT_SOURCE_DIR}/updatedomo DESTINATION ${CMAKE_INSTALL_PREFIX} PERMISSIONS OWNER_EXECUTE OWNER_WRITE OWNER_READ GROUP_EXECUTE GROUP_READ)
Hope it can help
Posted: Tuesday 24 March 2020 21:55
by GJvdP
I have the same problem. I tried to view my domoticz pages but could not get past the pop-up that told me to ugrade to 2020-1.
No notes on having to install a new OS first. Now my system doesn't work. No back-up made.
So pls advice with detailed instructions on either:
1 - revert to the previous version of Domoticz
2 - how to upgrade to the lastest Debian/Raspian version in order to get Domoticz working
I still have acces to my RP3+ through Putty and/or Winscp.
I hope anyone can help/
For future releases pls add the option not to install the update (was not possible this time) or warn the people that a needs an updated version of the OS to work. I had a perfect working system before this happened.
Decided to go ahead and try to upgrade to Buster on my Pi3+
Followed the outlines on the following site:
https://pimylifeup.com/upgrade-raspbian ... an-buster/
This indeed upgraded Stretch to Buster.
But Domoticz 2020.1 was still unreachable, but running updaterelease in the domoticz directory (through the terminal server) fixed that problem.
Happy times !!!!
Posted: Wednesday 25 March 2020 8:31
by zenodalla
Domange wrote: Tuesday 24 March 2020 21:36
What do you mean?
Meanwhile I tried to install ver. 4.10717 -> fail and 4.10659 -> fail. I had problem because of boost. Actually in CMakeLists.txt there's this line:
I've found a issue post on github (obviously now I can't find it
) in which someone had same error, about the version of boost. I edited 10600 and replaced with 1.6.0 I don't know if this can be a problem.
After that I can successfully run this command
cmake -DCMAKE_BUILD_TYPE=Release CMakeLists.txt -DUSE_OPENSSL_STATIC="NO"
make
but when i type make at a certain point it "freezes" to this line
Building CXX object CMakeFiles/domoticz.dir/main/EventSystem.cpp.o
I don't know what I'm doing wrong, I'll try to find other solutions.
edit: now I'm trying to compile ver4.9700 but it gets stucked at this line:
[ 26%] Building CXX object CMakeFiles/domoticz.dir/main/WebServer.cpp.o
cc1plus: warning: ./stdafx.h.gch/.c++: not used because `BOOST_ALL_NO_LIB' is defined [-Winvalid-pch]
Posted: Thursday 26 March 2020 21:11
by Domange
I choose the version V4.10717 by a checkout on the label "4.10717"
I think you have some trouble trouble with the BOOST library.
Have you any error when you have generated it ?
Maybe am I lucky but I don't have any problem to generate it....
Posted: Sunday 29 March 2020 20:07
by zenodalla
no, it seemed to be ok when I generated it. I found this old sd card with an installation of ver 4.10717 so I simply copied the folder.
Posted: Sunday 29 March 2020 20:36
by freijn
Copy the domoticz.sb from your crashed SD card and playback to the older version.
Posted: Tuesday 31 March 2020 22:59
by Calzor Suzay
zenodalla wrote: Sunday 29 March 2020 20:07
Was it the arm7l version? Can you upload the directory online to be downloaded?
I have the same issue and need the old folder back...
Posted: Wednesday 08 April 2020 15:04
by zenodalla
I don't think the RPi3b+ is arm7l. I'm sorry.
Posted: Thursday 16 April 2020 11:45
by Calzor Suzay
Think it is, the main download page says "Arm 32bit(Raspberry/Cubie/...) and if you hover over the file to download it's called domoticz_linux_armv7l.tgz
Do you have this file for the previous stable release or anyone else for that matter?
Posted: Monday 20 April 2020 18:30
by trissbe
Same at my installation.
But I was stuck at; Linking CXX executable domoticz, it appeared that OpenZwave 1.6 was blocking my installation, so I did the following steps to install 1.4;
rm -rf open-zwave-read-only/
git clone
https://github.com/OpenZWave/open-zwave.git open-zwave-read-only
cd open-zwave-read-only
git checkout v1.4-3335-g74e0598
make
sudo make install
After this installation I have finally a running copy of version 4.10693
But I still experience the error about driver failed
- Spoiler: show
- 2020-04-20 17:49:44.225 Status: Domoticz V4.10659 (c)2012-2019 GizMoCuz
2020-04-20 17:49:44.225 Status: Build Hash: 649306c4d-modified, Date: 2019-05-06 10:27:06
2020-04-20 17:49:44.225 Status: Startup Path: /home/pi/domoticz/
2020-04-20 17:49:44.294 Sunrise: 05:37:00 SunSet: 19:48:00
2020-04-20 17:49:44.294 Day length: 14:11:00 Sun at south: 12:43:00
2020-04-20 17:49:44.294 Civil twilight start: 05:01:00 Civil twilight end: 20:24:00
2020-04-20 17:49:44.294 Nautical twilight start: 04:16:00 Nautical twilight end: 21:09:00
2020-04-20 17:49:44.294 Astronomical twilight start: 03:25:00 Astronomical twilight end: 22:01:00
2020-04-20 17:49:44.372 Status: PluginSystem: Started, Python version '3.7.3'.
2020-04-20 17:49:44.373 Status: Philips Hue: Using default poll interval of 10 secs.
2020-04-20 17:49:44.382 Active notification Subsystems: (0/13)
2020-04-20 17:49:44.383 Status: WebServer(HTTP) started on address: :: with port 8080
2020-04-20 17:49:44.402 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
2020-04-20 17:49:44.402 Error: WebServer(SSL) check privileges for opening ports below 1024
2020-04-20 17:49:44.403 Status: Proxymanager started.
2020-04-20 17:49:44.404 Status: Camera: settings (re)loaded
2020-04-20 17:49:44.405 Starting shared server on: :::2224
2020-04-20 17:49:44.405 Status: TCPServer: shared server started...
2020-04-20 17:49:44.406 Status: RxQueue: queue worker started...
2020-04-20 17:49:46.407 Status: WOL: Started
2020-04-20 17:49:46.408 Status: Philips Hue: Worker started...
2020-04-20 17:49:46.408 Status: Nest: Worker started...
2020-04-20 17:49:46.408 Status: Panasonic Plugin: Started
2020-04-20 17:49:46.409 Status: SolarEdgeAPI Worker started...
2020-04-20 17:49:46.410 Status: EventSystem: reset all events...
2020-04-20 17:49:46.412 Status: EventSystem: reset all device statuses...
2020-04-20 17:49:46.509 Status: Panasonic Plugin: (Living) Starting thread.
2020-04-20 17:49:46.510 Status: Panasonic Plugin: (Living) started.
2020-04-20 17:49:46.522 Status: Python EventSystem: Initalizing event module.
2020-04-20 17:49:46.523 Status: EventSystem: Started
2020-04-20 17:49:46.524 Status: EventSystem: Queue thread started...
2020-04-20 17:49:46.797 Status: PluginSystem: Entering work loop.
2020-04-20 17:49:46.910 Status: OpenZWave: using config in: /home/pi/domoticz/Config/
2020-04-20 17:49:46.913 Always, OpenZwave Version 1.4.3335 Starting Up
2020-04-20 17:49:46.914 Status: OpenZWave: Starting...
2020-04-20 17:49:46.914 Status: OpenZWave: Version: 1.4-3335-g74e05982-dirty
2020-04-20 17:49:46.915 Error: OpenZWave: Driver Failed!!
*edit*
*using Razberry with firmware 5.36 on a PI
Posted: Thursday 23 April 2020 15:10
by pinknemo13
freijn wrote: Sunday 29 March 2020 20:36
Thanks but can you share more info about it? Thanks in advance.
