[SOLVED] RFlink + garage door Somfy
Bertone
Post by Bertone »
Hi everyone from France,
I recently installed Domoticz on a Raspberry and built my RFlink. I use it to order my shutters (Chacon) and everything is going well. I wanted to add my garage doors which are equipped with Somfy RTS. I paired without problem (the LED flashes to confirm) but when I make an opening / closing request, nothing happens. I read on different posts that maybe I had to change the chip (433.42 instead of 433.92) on my RFlink, I changed and still have the same problem. I also read that the STOP command could move the door but no, it doesn't work either.
Do you have a solution ?
Sorry if my english is bad, I try to do my best.
Thanks for your help.
2020-03-20 17:20:04.669 Status: User: DaX initiated a switch command (45/Garage 1/Stop)
2020-03-20 17:20:04.670 Status: RFLink Sending: 10;RTS;1f1f1f;1;STOP;
2020-03-20 17:20:07.940 (RFLINK) Light/Switch (Unknown)
2020-03-20 17:20:12.398 Status: User: DaX initiated a switch command (45/Garage 1/Off)
2020-03-20 17:20:12.398 Status: RFLink Sending: 10;RTS;1f1f1f;1;OFF;
2020-03-20 17:20:15.642 (RFLINK) Light/Switch (Unknown)
2020-03-20 17:20:18.418 Status: User: DaX initiated a switch command (45/Garage 1/On)
2020-03-20 17:20:18.419 Status: RFLink Sending: 10;RTS;1f1f1f;1;ON;
Bertone
Re: RFlink + garage door Somfy
Post by Bertone »
@b_weijenberg, thanks for you answer in private but I can't answer (New on the forum and not possible to send a PM)
I know RFXtrx433XL can control Somfy and Chacon but I search a solution with my device. Don't want to buy a device 100$ or € just to control garage doors ;)
Ron
Domoticz version: 2.2284
Post by Ron »
Do you have the RFXtrx433XL version and did you manually add a new switch with these options?:
Hardware: RFXtrx433XL
Name: Pick a name
Switch type: Blinds
Type: RFY
ID: Just fill in some numbers
Unit code: Just pick a number
Then click "Test" while the RFY motor is in learning state.
The motor should then add thuis switch as a new remote.
Somfy RFY.JPG (32.79 KiB) Viewed 1816 times
Bertone
Post by Bertone »
I have a RFlink.
It's ok now, I followed the instructions here https://matdomotique.wordpress.com/2016 ... -et-somfy/
