Domoticz crashes on complex data in customEvent
Posted: Saturday 21 March 2020 11:12
trying out customEvents but my domoticz service crashes each time I try to send some more data
I've tried different payloads, every time a valid json. The only thing that works is when data is a plain integer, string value:
Does not work:
The script doesn't do anything yet, it just logs data output:
EDIT1: I thought I should parse json but it still failed and then I tried empty execute function which also crashes.
2020-03-21 10:58:19.235 MQTT: Topic: domoticz/in, Message: {"command":"customevent","event":"notResponsive","data":[{"idx":29,"test":"ok"}]}
2020-03-21 10:58:19.244 Error: Domoticz(pid:32647, tid:32690('EventSystemQueu')) received fatal signal 6 (Aborted)
2020-03-21 10:58:19.244 Error: siginfo address=0x7f87, address=0xffffffff
Message: {"command":"customevent","event":"notResponsive","data":29}
Message: {"command":"customevent","event":"notResponsive","data":{"idx":29,"test":"ok"}}
customEvents =
'notResponsive',
logging = {
level = domoticz.LOG_DEBUG,
marker = "BatteryStatus"
execute = function(dz, item, info)
dz.log(item.data)
dz.log(item.isCustomEvent)
