Cleanup unused devices
Posted: Monday 09 March 2020 15:04
by peter8wun
My domoticz installation received quit a large number of divices from my RFlink hardware (>3000) that are not mine and I think this makes my domotics slow. For instance when accessing the list of divices.
is there a problem executing "delete from DeviceStatus where used =0" on the database to get rit of these devices?
Peter
Re: Cleanup unused devices
Posted: Monday 09 March 2020 15:56
by manjh
peter8wun wrote: Monday 09 March 2020 15:04
Peter
In the list of devices, click on "not used devices" at the left top. After this, select "all" for "show entries.
This will give you a complete list. Now select the little selectbox right next to the garbage bin, then click the garbage bin itself.
This gets rid of all unused devices.
Posted: Monday 09 March 2020 16:24
by waaren
My domoticz installation received quit a large number of divices from my RFlink hardware (>3000) that are not mine and I think this makes my domotics slow. For instance when accessing the list of devices.
Is there a problem executing "delete from DeviceStatus where used =0" on the database to get rit of these devices?
Not really but
to be safe make sure you have a backup and only do this when domoticz is not active.
- If you have the allow new hardware set to yes they will come back.
- These devices will also have data in other tables.
You can identify the tables (potentally) with data from these devices
select name as Tables_containing_deviceRowid from sqlite_master where type='table' and sql like '%devicerowid%';
to delete records with devicerowid's from unused devices from these tables
delete from LightingLog where devicerowid in (select id from devicestatus where used = 0);
delete from Rain where devicerowid in (select id from devicestatus where used = 0);
delete from Rain_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from Temperature where devicerowid in (select id from devicestatus where used = 0);
delete from Temperature_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from Timers where devicerowid in (select id from devicestatus where used = 0);
delete from SetpointTimers where devicerowid in (select id from devicestatus where used = 0);
delete from UV where devicerowid in (select id from devicestatus where used = 0);
delete from UV_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from Wind where devicerowid in (select id from devicestatus where used = 0);
delete from Wind_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from Meter where devicerowid in (select id from devicestatus where used = 0);
delete from Meter_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from MultiMeter where devicerowid in (select id from devicestatus where used = 0);
delete from MultiMeter_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from Notifications where devicerowid in (select id from devicestatus where used = 0);
delete from LightSubDevices where devicerowid in (select id from devicestatus where used = 0);
delete from DeviceToPlansMap where devicerowid in (select id from devicestatus where used = 0);
delete from SceneDevices where devicerowid in (select id from devicestatus where used = 0);
delete from SharedDevices where devicerowid in (select id from devicestatus where used = 0);
delete from Percentage where devicerowid in (select id from devicestatus where used = 0);
delete from Percentage_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from Fan where devicerowid in (select id from devicestatus where used = 0);
delete from Fan_Calendar where devicerowid in (select id from devicestatus where used = 0);
delete from Pushlink where devicerowid in (select id from devicestatus where used = 0);
and lastly
delete from devicestatus where used = 0;
Posted: Monday 09 March 2020 16:29
by peter8wun
Thanks for the quick and complete answer. this helps tremendously.
Posted: Monday 09 March 2020 16:34
by waaren
manjh wrote: Monday 09 March 2020 15:56
Not sure when the fix was applied but on older versions this approach (which should be the preferred one) caused domoticz to 'hang' when > 5 devices where selected for deletion.
