How to decode Json response  [Solved]
gerardosamara
Domoticz version: 4.10778
Post by gerardosamara »
Hi ,
Domoticz V4.11763
Rasbian Buster
RPI3
I have created a dzVents script to display on a text device the EurUsd exchange rate from the API of www.alphavantage.com
https://www.alphavantage.co/documentation/
As per the header this is a JSON response ( Content-Type application/json )
I could not figure out how to extract the "currency exchange rate" in the forum or the dzvents wiki ?
Here is the code
-- Cours EURUSD
ALPHA_APIKEY = 'xxxx'
-- ALPHA_URL = 'https://www.alphavantage.co/query?function=FX_INTRADAY&from_symbol=EUR&to_symbol=USD&interval=5min&apikey=' .. ALPHA_APIKEY
ALPHA_URL = 'https://www.alphavantage.co/query?function=CURRENCY_EXCHANGE_RATE&from_currency=EUR&to_currency=USD&apikey=' .. ALPHA_APIKEY
		timer = {
			'every 5 minutes' --  to trigger the request
		httpResponses = {
			'forex_eurusd' -- must match with the callback passed to the openURL command
	logging = {
    level = domoticz.LOG_DEBUG,
    marker = "EurUsd"
		if (item.isTimer) then
			domoticz.openURL({
				url = ALPHA_URL,
				method = 'GET',
				callback = 'forex_eurusd', -- see httpResponses above.
		if (item.isHTTPResponse) then
			if (item.statusCode == 200) then
			    domoticz.log('item content =', domoticz.LOG_DEBUG)
			    domoticz.log(item, domoticz.LOG_DEBUG)
				if (item.isJSON) then
				   domoticz.log('item.JSON content =', domoticz.LOG_DEBUG)
				   domoticz.log(item.json , domoticz.LOG_DEBUG)
				   -- Decode exchange rate
				   domoticz.log('EUR USD Exchange rate =', domoticz.LOG_DEBUG)
					-- update Dummy text device in Domoticz
					-- domoticz.devices('EurUsd').updateText(exchange_rate)
				domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
Here is the log showing the JSON response
2020-03-08 21:00:00.132 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-03-08 21:00:01.036 Status: dzVents: Info: Handling httpResponse-events for: "forex_eurusd"
2020-03-08 21:00:01.037 Status: dzVents: Info: EurUsd: ------ Start internal script: EurUsd: HTTPResponse: "forex_eurusd"
2020-03-08 21:00:01.038 Status: dzVents: Debug: EurUsd: item content =
2020-03-08 21:00:01.038 Status: dzVents: Debug: EurUsd: {["json"]={["Realtime Currency Exchange Rate"]={["4. To_Currency Name"]="United States Dollar", ["5. Exchange Rate"]="1.13950000", ["2. From_Currency Name"]="Euro", ["6. Last Refreshed"]="2020-03-09 03:00:00", ["7. Time Zone"]="UTC", ["1. From_Currency Code"]="EUR", ["8. Bid Price"]="1.13940000", ["3. To_Currency Code"]="USD", ["9. Ask Price"]="1.13950000"}}, ["callback"]="forex_eurusd", ["headers"]={["Content-Type"]="application/json", ["Via"]="1.1 vegur", ["Transfer-Encoding"]="chunked", ["Connection"]="keep-alive", ["Vary"]="Cookie", ["Date"]="Mon, 09 Mar 2020 03:00:00 GMT", ["Server"]="gunicorn/19.7.0", ["Allow"]="GET, HEAD, OPTIONS", ["X-Frame-Options"]="SAMEORIGIN"}, ["baseType"]="httpResponse", ["trigger"]="forex_eurusd", ["isSecurity"]=false, ["ok"]=true, ["isCustomEvent"]=false, ["statusText"]="OK", ["isHTTPResponse"]=true, ["isJSON"]=true, ["_contentType"]="application/json", ["isXML"]=false, ["isHardware"]=false, ["isSystem"]=false, ["protocol"]="HTTP/1.1", ["isTimer"]=false, ["data"]="{
2020-03-08 21:00:01.038 "Realtime Currency Exchange Rate": {
2020-03-08 21:00:01.038 "1. From_Currency Code": "EUR",
2020-03-08 21:00:01.038 "2. From_Currency Name": "Euro",
2020-03-08 21:00:01.038 "3. To_Currency Code": "USD",
2020-03-08 21:00:01.038 "4. To_Currency Name": "United States Dollar",
2020-03-08 21:00:01.038 "5. Exchange Rate": "1.13950000",
2020-03-08 21:00:01.038 "6. Last Refreshed": "2020-03-09 03:00:00",
2020-03-08 21:00:01.038 "7. Time Zone": "UTC",
2020-03-08 21:00:01.038 "8. Bid Price": "1.13940000",
2020-03-08 21:00:01.038 "9. Ask Price": "1.13950000"
2020-03-08 21:00:01.038 }
2020-03-08 21:00:01.038 }", ["isVariable"]=false, ["isScene"]=false, ["isDevice"]=false, ["isGroup"]=false, ["statusCode"]=200}
2020-03-08 21:00:01.038 Status: dzVents: Debug: EurUsd: item.JSON content =
2020-03-08 21:00:01.038 Status: dzVents: Debug: EurUsd: {["Realtime Currency Exchange Rate"]={["4. To_Currency Name"]="United States Dollar", ["5. Exchange Rate"]="1.13950000", ["2. From_Currency Name"]="Euro", ["6. Last Refreshed"]="2020-03-09 03:00:00", ["7. Time Zone"]="UTC", ["1. From_Currency Code"]="EUR", ["8. Bid Price"]="1.13940000", ["3. To_Currency Code"]="USD", ["9. Ask Price"]="1.13950000"}}
2020-03-08 21:00:01.038 Status: dzVents: Debug: EurUsd: EUR USD Exchange rate =
2020-03-08 21:00:01.039 Status: dzVents: Info: EurUsd: ------ Finished EurUsd
Please anybody may suggest a solution ?
Thank you
Domoticz Beta V4.11763 in Debian 10 VM
Domoticz Beta V4.11763 in RPI3
MDAH 0.2.42 + Imperihome Pro V4.3.17
App Android Domoticz Lite V0.2.201
Re: How to decode Json response
gerardosamara wrote: Monday 09 March 2020 4:19 I have created a dzVents script to display on a text device the EurUsd exchange rate from the API of www.alphavantage.com
I always use domoticz.utils.dumpTable() when the structure of the the JSON is not clear at first sight. Best to look at the log on OS level as that will also show the indention (= nesting in table)
See below.
-- Cours EURUSD
local scriptVar = 'forex_eurusd'
return
    on =
        timer =
        devices  =
            'JSONTrigger' --  to trigger the request during development / test
        httpResponses =
            scriptVar,            -- must match with the callback passed to the openURL command
    logging =
        marker = scriptVar,
    execute = function(dz, item)
        ALPHA_APIKEY = '7EBxxxxx'
        if item.isTimer or item.isDevice then
            dz.openURL(
                    url = ALPHA_URL,
                    method = 'GET',
                    callback = scriptVar, -- see httpResponses above.
            if item.ok then
                myJSON = ( item.isJSON and item.json ) or dz.utils.fromJSON(item.data) -- JSON to Lua table ( also when not recognized as JSON )
                if _G.logLevel == dz.LOG_DEBUG then
                     dz.utils.dumpTable(myJSON) -- show structure of converted JSON -- ( only for debug )
                local exchangeRateText = 'EUR USD Exchange rate = ' .. dz.utils.round(myJSON["Realtime Currency Exchange Rate"]["5. Exchange Rate"], 4)
                dz.log(exchangeRateText,dz.LOG_DEBUG)
                -- update Dummy text device in dz
                dz.devices('EurUsd').updateText(exchangeRateText)
                dz.log('There was a problem handling the request', dz.LOG_ERROR)
                dz.log(item, dz.LOG_ERROR)
gerardosamara
Re: How to decode Json response  [Solved]
Thanks a lot @waaren for the updated script
It works very well as per attached screenshot
And thanks again for this great dzvents framework
Capture eurusd.PNG (66.53 KiB) Viewed 1263 times
gerardosamara wrote: Monday 09 March 2020 21:41 And thanks again for this great dzVents framework
YW but please note that most of the credits for the original idea and initial dzVents framework should go to @dannybloe and @jvandenbroek
