Page 1 of 3
PLEX status (dzVents)  [SOLVED]
Posted: Sunday 08 March 2020 20:27
by OedzesG
Hallo everyone!
today i finisched my PLEX Status script.
it gives my the PLEX mediaplayer status so i can for example controle the lights when a movie is started or paused..
no media playing.PNG (14.33 KiB) Viewed 21578 times
if someone is interested, please let me know so i can make an how-2 and share the script.
Re: PLEX status (dzVents)
Posted: Sunday 08 March 2020 21:51
by EdwinK
Please share.
Posted: Sunday 08 March 2020 22:36
by OedzesG
Please share.
oke EdwinK... here we go..
The script uses the Tautulli api.. so first you need to install Tautulli..
https://github.com/Tautulli/Tautulli-Wiki/wiki/Installation
Once tautulli is instaled you can go to settings and navigate to Notification Agents and create a "webhook'
* webhook url :
http://<domoticzURL + port>/json.htm?type=command&param=customevent&event=plex_woonkamer
( you can change: woonkamer to something else, but then in the script you need to change the custom event in exactly the same name)
(becouse we use an customEvent, you need to be on dzVents: 3:0:0!!)
* Webhook Method: post
* description: what ever you want
on the page: Triggers select:
* Playback Start
* Playback Stop
* Playback Pause
* Playback Resume
On the page: Conditions:
* Parameter: Player
* Operator: is
* Value: (Here you have to search in Plex for youre plex player name (in my case: SHIELD Android TV)
Then save the webhook.
We also need the API Key from tautulli, you can find it: settings/Web Interface, scrol down en note the API. Also make sure API is enabled.
Now were done in Tautulli.
In Domoticz you have to create a dummy device... first switch and then change it to: media player in Domoticz UI.
The script whit some final instructions.
		local scriptVersion = ' release: v1.3: 20200306 '
		local scriptVar = ' plex woonkamer ' .. scriptVersion
	--<[ 				      dzVents: Plex status 2 Domoticz   			    ]>--
		local tautulli_ip = 'xxx'	-- tautulli ip:port
		local tautulli_api = 'xx'	-- tautulli api key
		local plex_player	= 'SHIELD Android TV' 		-- the plex player you want the status off
		local dz_plex_player 	= 26				-- IDX number plex media player device
	return
			on = { 	customEvents 	= { 'plex_woonkamer',},		-- if you change the webhook URL make sure this match
				timer		= { 'every minute'  		-- this only runs when a movie is playing on selected player
	       		httpResponses 		= { scriptVar .. '*', },
			logging	 		= { level 	= domoticz.LOG_DEBUG,	-- set to LOG_ERROR when testen and ok.
						    marker 	= scriptVar,
			data 			= { plex	= { initial = {}, },
	execute = function(dz, item, triggerInfo)
		local jsonPlexInfo = {}
		local callback = scriptVar .. 'getPlexInfo'
		-- make sure timer only trigger script when pms is active
		if item.isCustomEvent then
			dz.data.plex.active = 'true'
		if dz.data.plex.active == 'true' then
			if item.isCustomEvent or item.isTimerer then
		-- get plex information	trough tautulli api
			local function getPlexInfo( target, json, callback)
            local url = 'http://' .. target .. '/' .. json
            dz.openURL
               			url = url,
				method = 'GET',
				callback = callback,
		if item.isCustomEvent or item.isTimer then
		getPlexInfo( tautulli_ip, '/api/v2?apikey=' .. tautulli_api .. '&cmd=get_activity', callback )
			return
		 if item.isHTTPResponse then
		jsonPlexInfo = dz.utils.fromJSON(item.data)
            	if not(jsonPlexInfo) then return end
            		dz.log('Unexpected result from API ',dz.LOG_ERROR )
                dz.utils.dumpTable(item)
		dz.data.initialize('plex')
		-- find match in player name (api showing more players when more streams are active)
		for _, record in ipairs(jsonPlexInfo.response.data.sessions) do
			if record.player:match(plex_player) then
					dz.data.plex.active = ('true')
					dz.data.plex.state 	= (record.state)
					dz.data.plex.title	= (record.full_title)
					dz.data.plex.progress = (record.progress_percent)
		-- Change json output for updating device
		if dz.data.plex.state == 'playing' then player_state = 7
			elseif dz.data.plex.state == 'buffering' then player_state = 7
			elseif dz.data.plex.state == 'paused' then player_state = 2
		-- updating device
		dz.devices(dz_plex_player).update(player_state, dz.data.plex.title .. ' : ' .. dz.data.plex.progress .. ' %').silent()
		dz.devices(dz_plex_player).update(0, 'no media playing').silent()
Posted: Sunday 08 March 2020 22:51
by EdwinK
Trying this tomorrow ;)
Posted: Sunday 08 March 2020 22:57
by OedzesG
oké.. 8-)
please let me know if evertything worked out!
Posted: Monday 09 March 2020 11:13
by EdwinK
So far it's working:
2020-03-09 11:07:41 - DEBUG :: Thread-25 : Tautulli ActivityHandler :: Session 4 started by user 1480083 (EdwinK) with ratingKey 3413 ('Allo 'Allo! - The Return of 'Allo 'Allo!).
2020-03-09 11:07:41 - DEBUG :: Thread-1 : Tautulli NotificationHandler :: Notifiers enabled for notify_action 'on_play'.
2020-03-09 11:07:41 - DEBUG :: Thread-1 : Tautulli NotificationHandler :: Checking global notification conditions.
2020-03-09 11:07:41 - DEBUG :: Thread-1 : Tautulli NotificationHandler :: Global notification conditions evaluated to 'True'.
2020-03-09 11:07:41 - DEBUG :: Thread-1 : Tautulli NotificationHandler :: Checking custom notification conditions for notifier_id 1.
2020-03-09 11:07:41 - DEBUG :: Thread-1 : Tautulli NotificationHandler :: {1} player | is | 'plex server' > 'tv ue50j6200' > False
2020-03-09 11:07:41 - DEBUG :: Thread-1 : Tautulli NotificationHandler :: Condition logic [blank]: {1} > False
2020-03-09 11:07:41 - DEBUG :: Thread-1 : Tautulli NotificationHandler :: Custom conditions evaluated to 'False'. Conditions: [False].
2020-03-09 11:07:41 - DEBUG :: Thread-1 : Tautulli NotificationHandler :: Custom notification conditions not satisfied, skipping notifier_id 1.
2020-03-09 11:08:47 - DEBUG :: Thread-25 : Tautulli ActivityHandler :: Session 4 paused.
2020-03-09 11:08:47 - DEBUG :: Thread-2 : Tautulli NotificationHandler :: Notifiers enabled for notify_action 'on_pause'.
2020-03-09 11:08:47 - DEBUG :: Thread-2 : Tautulli NotificationHandler :: Checking global notification conditions.
2020-03-09 11:08:47 - DEBUG :: Thread-2 : Tautulli NotificationHandler :: Global notification conditions evaluated to 'True'.
2020-03-09 11:08:47 - DEBUG :: Thread-2 : Tautulli NotificationHandler :: Checking custom notification conditions for notifier_id 1.
2020-03-09 11:08:47 - DEBUG :: Thread-2 : Tautulli NotificationHandler :: {1} player | is | 'plex server' > 'tv ue50j6200' > False
2020-03-09 11:08:47 - DEBUG :: Thread-2 : Tautulli NotificationHandler :: Condition logic [blank]: {1} > False
2020-03-09 11:08:47 - DEBUG :: Thread-2 : Tautulli NotificationHandler :: Custom conditions evaluated to 'False'. Conditions: [False].
2020-03-09 11:08:47 - DEBUG :: Thread-2 : Tautulli NotificationHandler :: Custom notification conditions not satisfied, skipping notifier_id 1.
but nothing changes on the switch.
Posted: Monday 09 March 2020 11:18
by OedzesG
can you share the script?
Posted: Monday 09 March 2020 13:55
by EdwinK
The same script you posted above, but adapted
		local tautulli_ip   = '192.168.0.11:8181'	                -- tautulli ip:port
		local tautulli_api  = '****'	-- tautulli api key
		local plex_player   = 'Plex Server' 		                -- the plex player you want the status off
		local dz_plex_player= 508				                    -- IDX number plex media player device
	return
						    marker 	= scriptVar,
            dz.openURL
               			url = url,
				method = 'GET',
			return
		-- updating device
Posted: Monday 09 March 2020 18:46
by OedzesG
you sure youre plex_player is: Plex Server?
Normaly its something like: Chrome, Chromecast, SHIELD Android TV, or something..
if youre not sure, start streaming with the device you want to know the status of, then go to plex en check: Activity.
In this example it: "Chrome" you need!
Changed the script a litlle, this should be working!
	local scriptVersion = ' v1.3: 20200306 '
		local dz_plex_player 	= 508
	return
			logging		= { level 		= domoticz.LOG_ERROR,
					    marker 		= scriptVar,
		dz.openURL
                		url = url,
				method = 'GET',
			return
		if dz.data.plex.state == 'playing' then dz.data.plex.state = 7
			elseif dz.data.plex.state == 'buffering' then dz.data.plex.state = 7
			elseif dz.data.plex.state == 'paused' then dz.data.plex.state = 2
		dz.devices(dz_plex_player).update(dz.data.plex.state, dz.data.plex.title .. ' : ' .. dz.data.plex.progress .. ' %').silent()
Posted: Monday 09 March 2020 22:58
by EdwinK
Got the following:
Screen Shot 2020-03-09 at 22.55.56.png (138.11 KiB) Viewed 21488 times
So I assume it should be TV UE50J6200?
Posted: Tuesday 10 March 2020 6:52
by OedzesG
exactly
Posted: Tuesday 10 March 2020 10:38
by OedzesG
also make sure youre webhook settings match...
webhook Tautullia.PNG (25.01 KiB) Viewed 21468 times
Posted: Tuesday 10 March 2020 10:50
by EdwinK
That was the one part I forgot to change ;)
Posted: Tuesday 10 March 2020 10:58
by EdwinK
And now i've got it working ;)
Thanks. Maybe you could put this in the WIKI?
Posted: Tuesday 10 March 2020 11:45
by OedzesG
i hope you enjoy it! :)
im not an scripting expert... just create the script (whit lots of help from @waaren) becouse i could not find anything in dzVents for plex..
i think there can be some aprovements and have some ideas to add..
(to be honest, i have no clue how to place it on the wiki :lol: )
Posted: Monday 06 April 2020 14:47
by finalcut62
What a great script. I had to update my Raspberry PI and Domoticz for it (which turned to be much easier than expected - previous versions I had to compile myself because of desired OpenZwave support), and it worked straight out of the box.
Do you all have any examples of attached Lighting-scripts? My preference was to dim a group of Hue lights to 0 (matching a cinema experience) but I'll settle of 'off' for 'playing' and 'resume', and for 'on' at all other events...
Posted: Saturday 11 April 2020 23:17
by OedzesG
What a great script
thnx! @finalcut62
 local mediaPlayerStates =
    		Off = 0,
    		On = 1,
    		Paused = 2,
    		Stopped = 3,
    		Video = 4,
    		Audio = 5,
    		Photo = 6,
    		Playing = 7,
    		Disconnected = 8,
    		Sleeping = 9,
    		Unknown = 10,
In the script: 0,2,7 used..
Posted: Thursday 07 May 2020 22:48
by dennis075
Script looks great, trying it tomorrow. Is it correct that you need the plex pass to let this work? That's something to keep in mind when trying this :D
Posted: Thursday 07 May 2020 23:26
by OedzesG
No script is not using PLEX but Tautulli.. and as far i know, you can run Tautulli withoud PLEX pass.
Good luck!
Please let me know if everything went well...
Posted: Friday 08 May 2020 11:42
by dennis075
OedzesG wrote: Thursday 07 May 2020 23:26
Good luck!
Installed everything and works pretty good! And indeed no plex pass needed.
