I’ve just installed HABridge 5.3.0 over the 3.4.1 version I used previously, but it isn’t clear how I configure it to work;
I’ve set the Bridge Control to my Domoticz settings - IP address and port
On the devices, I’ve set Map Type to Domoticz
On the ‘On Items’ ive set the type to Domoticz Device
What isn’t clear to me now as to what I put in the Target Item field?
Anyone know?
HABridge 5.3 and domoticz Topic is solved
nigels0
- Domoticz version: 3.8153
Re: HABridge 5.3 and domoticz
Scratch that; just seen the Domoticz tab and that builds the script
PWsweden
Hi.
I'm facing the same issue. I can't seem to figure out how to configure HABridge properly. Can you please explain what you mean with the Domoticz tab builds the script? I have the tab but I still can't figure it out.
Thanks in advance.
Thanks in advance.
