Push sensor data to remote Domoticz
Posted: Sunday 08 March 2020 11:17
by ronaldbro
I have some Bluetooth plant sensors which are out of range of my Domoticz Raspberry Pi so decided to buy a new Pi as a slave. But after adding the plant sensors to my secondary Domoticz I found out that the standard Remote Server doesn't work for dummy sensors. I found some solutions on the forum using MQTT and node red, but I wanted a simple solution. So I created a generic script to push updates to the primary Domoticz using json.
It works very simple.
1) Create the sensor on the slave using the dummy device or a plugin.
2) Create the same sensor on the master using the dummy device. Make sure you create the same type.
3) Copy this script to the slave
4) Change the URL to the master
5) Edit the mapping table in the script. [slave idx] = {remoteIdx = 'master idx'}
6) Now as soon as the sensor on the slave get's an update the value is pushed to the master.
In the script below only the sensor types used by the Xiaomi Mi Flower Mate are added, but it can be easily extended for other sensor types. Just add an elseif for the correct type/subtype and make sure to use the correct json found here https://www.domoticz.com/wiki/Domoticz ... .2Fsensors
 local server = 'http://192.168.2.10:8080'
local MAPPING = {
    [56] = {remoteIdx =  999}, -- Plant 1: Vocht
    [22] = {remoteIdx =  703}, -- Plant 1: Temperatuur
    [23] = {remoteIdx =  704}, -- Plant 1: Lucht
    [24] = {remoteIdx =  705}, -- Plant 1: Voeding
    [57] = {remoteIdx = 1000}, -- Plant 2: Vocht
    [26] = {remoteIdx =  707}, -- Plant 2: Temperatuur
    [27] = {remoteIdx =  708}, -- Plant 2: Lucht
    [28] = {remoteIdx =  709}, -- Plant 2: Voeding
    [58] = {remoteIdx = 1001}, -- Plant 3: Vocht
    [30] = {remoteIdx =  711}, -- Plant 3: Temperatuur
    [31] = {remoteIdx =  712}, -- Plant 3: Lucht
    [32] = {remoteIdx =  713}, -- Plant 3: Voeding
    [59] = {remoteIdx = 1002}, -- Plant 4: Vocht
    [34] = {remoteIdx =  715}, -- Plant 4: Temperatuur
    [35] = {remoteIdx =  716}, -- Plant 4: Lucht
    [36] = {remoteIdx =  717}, -- Plant 4: Voeding
    [60] = {remoteIdx = 1003}, -- Plant 5: Vocht
    [53] = {remoteIdx =  719}, -- Plant 5: Temperatuur
    [54] = {remoteIdx =  720}, -- Plant 5: Lucht
    [55] = {remoteIdx =  721}, -- Plant 5: Voeding
    [61] = {remoteIdx = 1004}, -- Plant 6: Vocht
    [48] = {remoteIdx =  723}, -- Plant 6: Temperatuur
    [49] = {remoteIdx =  724}, -- Plant 6: Lucht
    [50] = {remoteIdx =  725}, -- Plant 6: Voeding
---------- Script starts here ----------
local callbackString = 'RemoteDataPush_callback'
local getTriggerDevices = function()
	local tDevs = {}
	for idx, _ in pairs(MAPPING) do
		tDevs[idx] = idx
	return(tDevs)
		devices = getTriggerDevices(),
        httpResponses = { callbackString }
	logging = {
--        level = domoticz.LOG_DEBUG,
        level = domoticz.LOG_INFO,
--        level = domoticz.LOG_ERROR,
        marker = "Remote Data Push"
	execute = function(dz, item, info)
        if item.isDevice then
            dz.log('Send data to ' .. server .. ' - local idx = ' .. item.idx .. ' - remote idx = ' .. MAPPING[item.idx].remoteIdx ..' - deviceType = ' .. item.deviceType .. ' - deviceSubType = ' .. item.deviceSubType .. ' - nvalue = ' .. item.nValue .. ' - svalue = ' .. item.sValue)
            if item.deviceType == 'General' and item.deviceSubType == 'Custom Sensor' then
                dz.openURL({url = server .. '/json.htm?type=command&param=udevice&idx=' .. MAPPING[item.idx].remoteIdx ..'&nvalue=0&svalue=' .. item.sValue, callback = callbackString})
            elseif item.deviceType == 'General' and item.deviceSubType == 'Soil Moisture' then
                dz.openURL({url = server .. '/json.htm?type=command&param=udevice&idx=' .. MAPPING[item.idx].remoteIdx ..'&nvalue=' .. item.nValue, callback = callbackString})
            elseif item.deviceType == 'General' and item.deviceSubType == 'Percentage' then
                dz.openURL({url = server .. '/json.htm?type=command&param=udevice&idx=' .. MAPPING[item.idx].remoteIdx ..'&nvalue=0&svalue=' .. item.nValue, callback = callbackString})
            elseif item.deviceType == 'Lux' and item.deviceSubType == 'Lux' then
                dz.openURL({url = server .. '/json.htm?type=command&param=udevice&idx=' .. MAPPING[item.idx].remoteIdx ..'&svalue=' .. item.sValue, callback = callbackString})
            elseif item.deviceType == 'Temp' and item.deviceSubType == 'LaCrosse TX3' then
            elseif item.deviceType == 'Humidity' and item.deviceSubType == 'LaCrosse TX3' then
                dz.openURL({url = server .. '/json.htm?type=command&param=udevice&idx=' .. MAPPING[item.idx].remoteIdx ..'&nvalue=' .. item.nValue .. '&svalue=' .. item.sValue, callback = callbackString})
                dz.log('Not implemented devicetype found. Devicetype = ' .. item.deviceType .. ' subtype = ' .. item.deviceSubType, dz.LOG_ERROR)
        elseif item.isHTTPResponse then
            if item.json.status == 'OK' then
                dz.log('Updated the remote device succesfully.')
                dz.log(item.json)
                dz.log('Something went wrong updating the remote device', dz.LOG_ERROR)
                dz.log(item.json, dz.LOG_ERROR)
            dz.log('Unknown script trigger.', dz.LOG_ERROR)
Re: Push sensor data to remote Domoticz
Posted: Friday 27 March 2020 13:13
by manjh
Very creative solution. There is one downside to this that I can see: if the master and slave are not in the same subnet, you will have to do a port-forward on the master network for 8080. Not something I look forward to.
Once this port is open, the master Domoticz is open for anything.
With the MQTT solution there is a filter on both sides: on the slave side you explicitely have to decide which devices are sent out on the queue. On the master side, there is a similar filter where you explicitely decide which updates are accepted from the queue.
Effectively this means that a really smart hacker could break in and send me fake updates to the devices in my replication list. Unless the device is critical (e.g. an alarm trigger) this seems like an acceptable risk.
Posted: Tuesday 26 May 2020 16:27
by ray308
@ronaldbro thanks for this idea, I was strugling with the dummy's for a while to get them on my remote server.
Can you tell me where to put the script?
I did put in as an event (DzVents) but it returns an error. I assume that the script has to be somewhere else?
I only use the custom sensor to try this out.
Posted: Friday 05 June 2020 22:44
by ronaldbro
You can copy paste it to a new dzVents script in Domoticz. Just create a new script, delete everything and paste this one.
Can you post the error?
Posted: Saturday 06 June 2020 11:38
by ray308
Just created a new dzVents script on the slave, deleted everything, and pasted your script in it.
Offcource with my own server ip/port en the correct idx numbers.
No errors in the log now, but no update either on the master, any ideas?
Posted: Saturday 06 June 2020 12:06
by waaren
ray308 wrote: Saturday 06 June 2020 11:38 Just created a new dzVents script on the slave, deleted everything, and pasted your script in it.
What are your settings in
Posted: Saturday 06 June 2020 12:09
by ray308
10.0.1. is my local lan, both devices are in there.
Posted: Saturday 06 June 2020 12:47
by ronaldbro
Have you set an admin password? I thought even if you don’t need it it must be set to use json calls.
Posted: Sunday 07 June 2020 11:32
by ronaldbro
Another possibility... Do you have dzVents enabled On your slave in settings -> other?
Do you see any action on the slave in the log when a value of the configured devices changes?
Posted: Sunday 07 June 2020 11:56
by ray308
Yep, I so have an admin password, and dzVents is enabled in settings, Im running more scriptst, fot weather and my watermeter. Just checked if it was really enabled.
I.ll check al the settings again..
Posted: Sunday 07 June 2020 12:03
by ronaldbro
It would be interesting to know if the problem is on the master side or on the slave side. If you set the lof level in the script to info then you should see something in the log when the devices gets updated.
Posted: Sunday 07 June 2020 12:12
by ronaldbro
I just updated the script to give an error when a DeviceType is not implemented yet, this might be the cause...
To update you can just copy/paste everything below the device mapping.
Posted: Sunday 07 June 2020 14:13
by ray308
Thx, just implemented the new script, no change in the log, just that the script started.
My dummy devices are getting there info from another script (weather script) is this maybe the problem?
Posted: Sunday 07 June 2020 15:01
by ronaldbro
If the script is starting then it should work.
I added some error logging to the script and also checking the result. Can you update the script and post the log?
Posted: Sunday 07 June 2020 19:22
by ray308
I think it only saves the scripts, that is what I see in the log. I think the script is not running at al. Is there a way to check this?
Posted: Sunday 07 June 2020 19:49
by ronaldbro
You should see log messages if the script is called. Can you post your device mapping you have in your script?
