Python plugin for eQ-3/ELV MAX! Thermostats
Posted: Tuesday 03 March 2020 16:05
by teeminus
Hi!
I developed a python plugin to integrate the eQ-3/ELV MAX! Thermostats into domoticz. I developed the plugin quite a while ago as there were no easy to use solutions back then. The plugin has spread in my circle of friends and acquaintances and as all found this plugin quite useful, I decided to release it to the public.
The plugin has the following (main) functionalities:
  • Bidirectional synchronization between domoticz and the thermostats. The temperature can be set using domoticz and is updated in the thermostats immediatelly and if the temperature is manually changed at one thermostat, these changes are updated in domoticz.
  • Display of the thermostats battery level.
  • Display of the room temperature measured by the thermostat.
Feel free to check out the plugin at github: https://github.com/teeminus/domoticz_eq3_max
If you have any questions about the plugin, feel free to ask.
Kind regards
Teeminus
