Text device to virtual device
Posted: Sunday 01 March 2020 7:51
by edwin1234
Is it in dzvents possible to set a virtual device to :
“Hot water on”
If my text device is “=H”
And that virtual device to:
“Hot water off”
If my text device is something else like:
“-H” , “0H” , “0Y”
Re: Text device to virtual device
Posted: Sunday 01 March 2020 22:26
by waaren
edwin1234 wrote: Sunday 01 March 2020 7:51
“Hot water on”
“Hot water off”
“-H” , “0H” , “0Y”
Just to make sure I understand the question. You want to change the text in textdevice based on a string entered in the same textdevice ?
Posted: Monday 02 March 2020 7:01
by edwin1234
No i want another virtual device changed to hot water on or off based on the text device that gives =H for water on and if it gives another output for hot water off, hot water off must be if the text device gives 0y or 0a or -H
Hope you understand , my english is not so good
Edwin
Posted: Monday 02 March 2020 9:07
by waaren
edwin1234 wrote: Monday 02 March 2020 7:01
OK.
Is 'another virtual device' also a text device ?
If not please post name, type and subtype.
The example below assumes a text device.
return
on =
devices =
'sourceText', -- change to name of source device
logging =
level = domoticz.LOG_DEBUG, -- INFO, DEBUG or ERROR
marker = 'Text2Text'
execute = function(dz, item)
local targetDevice = dz.devices('targetText') -- change to name of target device
local sourceText = item.text
local targetText = 'Hot water off'
if sourceText:match('=H') then -- if source device contains string '=H'
targetText = 'Hot water on'
dz.log('\nsourceText: ' .. item.text .. '\ntargetText: ' .. targetText ,dz.LOG_DEBUG)
if targetDevice.text ~= targetText then -- only change target when not equal to targettext
targetDevice.updateText(targetText)
Posted: Monday 02 March 2020 12:04
by edwin1234
Thank u very much for your help
I’ m gonna try this out.
Edwin
