Backup and restore on a clean fresh installation
Posted: Saturday 29 February 2020 2:06
by Patricen
For some reason, I decided to burn a new SD card with a clean Raspbian installation on my rpi, reinstalled domoticz (the easy way), and this works like a charm, but without my previous data.
I updated domoticz to the same version as my previous system and I'm trying to get back my data, but...
As soon as I do replace domoticz.db, the system decides staying offline. Are there other files I need to copy to the new card so that it works?
I'm stuck.
Re: Backup and restore on a clean fresh installation
Posted: Saturday 29 February 2020 8:30
by waaren
Patricen wrote: Saturday 29 February 2020 2:06 I updated domoticz to the same version as my previous system and I'm trying to get back my data, but...
I'm stuck.
Assuming you stop domoticz before replacing domoticz.db with the old copy, a first step in the problem investigation would be to start domoticz from the command line interface or with log active and share what you see.
Posted: Saturday 29 February 2020 10:14
by Patricen
That's pretty weird, it looks unstable
pi@domoticz:~ $ sudo service domoticz.sh status ● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated)
Active: active (exited) since Sat 2020-02-29 10:06:07 CET; 2min 6s ago
Docs: man:systemd-sysv-generator(8)
Process: 410 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SU
févr. 29 10:06:05 domoticz systemd[1]: Starting LSB: Home Automation System...
févr. 29 10:06:07 domoticz domoticz.sh[410]: 2020-02-29 10:06:07.142 Status: Do
févr. 29 10:06:07 domoticz domoticz.sh[410]: 2020-02-29 10:06:07.142 Status: Bu
févr. 29 10:06:07 domoticz domoticz.sh[410]: 2020-02-29 10:06:07.143 Status: St
févr. 29 10:06:07 domoticz domoticz.sh[410]: domoticz: Domoticz is starting up..
févr. 29 10:06:07 domoticz domoticz[429]: Domoticz is starting up....
févr. 29 10:06:07 domoticz domoticz[466]: Domoticz running...
févr. 29 10:06:07 domoticz systemd[1]: Started LSB: Home Automation System.
lines 1-14/14 (END)
After a sudo service domoticz.sh restart it works, but that is not very convenient after a power loss
Posted: Saturday 29 February 2020 10:49
by jkimmel
Patricen wrote: Saturday 29 February 2020 2:06 Hello,
I'm stuck.
I think the better approach would be to use the backup/restore function of Domoticz (Settings) instead of copying the domoticz.db
