Hi Everyone!!!
I finally managed to set up Domoticz and pair it with my Xiaomi Gateway (had to solder serial port) which has several thermosensors connected per each room.
Now I would like to turn my home radiators into smart radiators with TRV (Thermostatic Radiator Valve), so I will be able to control the temperature per each room.
Unfortunately, I can't find any info on which TRV's are compatible with Domoticz, or at least which are hackable/flashable (like SonOff products with Tasmota) to make them compatible with Domoticz?
For example, in Amazon, there are a good few options available or on AliExpress also few interesting options
Please advice which of them are recommended and can be connected to Domoticz?
Thanks in advance!
Smart TRV compatible with Domoticz?
nurseto
Re: Smart TRV compatible with Domoticz?
I managed to get mi gateway password without soldering anything.
Just install beta version of MI Home via playstore and we can access the password of lumi hub protocol.
Maybe you can use dimmer device to interface voltage or current controlled TRV.
