Need help in diagnosing a script
Posted: Wednesday 26 February 2020 9:18
I need some help in diagnosing a script.
In my setup when a pump is turned on, waterflow readings are being sent to Domoticz every second. They are fed to a waterflow sensor and a variable (as I could not get dzVents or Blockly to work with the sensor). I need a script to check the waterflow around 20 seconds after the pump was started. If it's too low, a safety switch should be triggered. My script looks like this:
It doesn't report any errors, however it's never triggered. I get constant info on the log that the variable was updated, however the script does not run. Updating the waterflow variable manually also does not trigger the script.
Regards, darkdude
on = { variables = {"pompa_zbiornika_przeplyw"},
data = { count = { initial = 0 }
execute = function(domoticz, _)
local przeplyw = domoticz.variables("pompa_zbiornika_przeplyw").value
local pompa = domoticz.devices("POMPA ZBIORNIKA").state
if (pompa == "On") then
domoticz.data.count = domoticz.data.count + 1
elseif (pompa ~= "On") then
domoticz.data.count = 0
if (domoticz.data.count >= 20 ) then
if (przeplyw >= 0 and przeplyw <= 5 and pompa == 'On' ) then
domoticz.devices("BLOKADA POMPY ZBIORNIKA").switchOn().checkFirst()
elseif (przeplyw > 5 and przeplyw < 22 and pompa == 'On' ) then
domoticz.devices("BRUDNY FILTR ZBIORNIKA").switchOn().checkFirst()
}Regards, darkdude
