Zigate and group management in Domoticz
Posted: Wednesday 26 February 2020 9:00
by TonkaNL
For some Ikea remotes (or other devices) to work properly in Domoticz, you have to add them to groups.
Here it says how: https://github.com/pipiche38/Domoticz-Z ... -Remote.md
In this step by step manual, it states the following:
Phase 1: bring everyone on the Zigate network
Put the Zigate in pairing mode. I suggest that you put 255 for the Permit to Join parameter. Make sure that you have also enabled 'accept New Hardware' in Domoticz settings.
Enable 'group management' :
You must have the following entry in Domoticz-Zigate plugin file Conf/PluginConf.txt 'enablegroupmanagement':'1', The file will looks like that:
channel':'11,15,19,20,25,26',
vibrationAqarasensitivity':'medium',
resetMotiondelay':'30',
logLQI':'0',
logFORMAT':'0'
However, in my install, there is no file called PluginConf.txt Only PluginConf.json, which is well, the json file.
Must I make this file myself, or do I have to re-install the plugin?
Thanks.
Tonka
Re: Zigate and group management in Domoticz
Posted: Wednesday 26 February 2020 10:24
by pipiche
The documentation is a bit out-dated.
The best is to use the Web Interface, that you can reach on port 9440
https://github.com/pipiche38/Domoticz-Z ... terface.md
https://github.com/pipiche38/Domoticz-Z ... igation.md
On teh Web Interface you have to enable Group via Settings and then you can create your group under Group Management
Posted: Wednesday 26 February 2020 12:52
by TonkaNL
Ok, thanks.
I'll try.
Posted: Wednesday 26 February 2020 13:00
by TonkaNL
Ok, so here I see the light bulb that has not been deleted..
Nice interface!!
Posted: Wednesday 26 February 2020 14:05
by pipiche
TonkaNL wrote: Wednesday 26 February 2020 13:00 Ok, so here I see the light bulb that has not been deleted..
Nice interface!!
And should be in Dutch ;-)
Posted: Wednesday 26 February 2020 16:18
by TonkaNL
Is there a request hidden in your post? 😬
I can give it a shot..
How does this work? Is there a text template available that I can translate?
Posted: Wednesday 26 February 2020 17:04
by pipiche
If you are on the Web Admin Page, you can select the language on the upper left corner
Screenshot 2020-02-26 at 17.02.04.png (321.2 KiB) Viewed 538 times
Posted: Thursday 27 February 2020 15:18
by TonkaNL
Ah, ok. Thanks!
