Removing a device crash Domoticz
Posted: Monday 24 February 2020 11:25
by pipiche
Domoticz V.4.11533
OZW: 1.6-992-g76e21d80
I'm not a OZW specialist, I'm more on the Zigbee side and currently migrating out some OZW devices to be replaced by Zigbee components.
While removing unused OZW I'm getting a Domotciz crash . As it is quiet difficult to see which devices belongs to this device in the Domtcz Device list
Feb 24 11:21:43 pi3 domoticz[19184]: 2020-02-24 11:21:43.617  Status: OpenZWave: Remove Failed Device initiated...
Feb 24 11:21:43 pi3 domoticz[19184]: 2020-02-24 11:21:43.617  Status: OpenZWave: RemoveFailedNode ControllerCommand - Starting
Feb 24 11:21:43 pi3 domoticz[19184]: 2020-02-24 11:21:43.627  Status: OpenZWave: RemoveFailedNode ControllerCommand - InProgress
Feb 24 11:21:46 pi3 domoticz[19184]: 2020-02-24 11:21:46.618 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s). Command: "ControllerCommand_RemoveFailedNode: 0x01, 0x05, 0x00, 0x61, 0x06, 0x8f, 0x12"
Feb 24 11:21:46 pi3 domoticz[19184]: 2020-02-24 11:21:46.618 Always,
Feb 24 11:21:46 pi3 domoticz[19184]: 2020-02-24 11:21:46.618 Always, Dumping queued log messages
Feb 24 11:21:46 pi3 domoticz[19184]: 2020-02-24 11:21:46.619 Always,
Feb 24 11:21:46 pi3 domoticz[19184]: 2020-02-24 11:21:46.619 Always, End of queued log message dump
Feb 24 11:21:46 pi3 domoticz[19184]: 2020-02-24 11:21:46.619  Error: OpenZWave: Type_Notification, NodeID not found internally!. HomeID: 3290841831, NodeID: 255 (0xff)
Feb 24 11:21:46 pi3 domoticz[19184]: 2020-02-24 11:21:46.623  Status: OpenZWave: ControllerCommand - Error - Failed
Feb 24 11:21:47 pi3 domoticz[19184]: 2020-02-24 11:21:47.215  Error: Domoticz(pid:19184, tid:19206('OZW-driver')) received fatal signal 11 (Segmentation fault)
Feb 24 11:21:47 pi3 domoticz[19184]: 2020-02-24 11:21:47.215  Error: siginfo address=0x1a, address=0xb6b6ff70
Feb 24 11:21:47 pi3 domoticz[19184]: 2020-02-24 11:21:47.244  Error: Failed to start gdb, will use backtrace() for printing stack frame
Feb 24 11:21:47 pi3 domoticz[19184]: 2020-02-24 11:21:47.246  Error: #0  /usr/bin/domoticz :  + 0x15f31c [0x5af31c]
Feb 24 11:21:47 pi3 domoticz[19184]: 2020-02-24 11:21:47.246  Error: #1  /usr/bin/domoticz :  + 0x15ff00 [0x5aff00]
Feb 24 11:21:47 pi3 domoticz[19184]: 2020-02-24 11:21:47.246  Error: #2  /lib/libc.so.6 : __default_rt_sa_restorer + 0 [0xb64a45e0]
Feb 24 11:21:47 pi3 domoticz[19184]: 2020-02-24 11:21:47.246  Error: #3  /lib/libopenzwave.so.1.6 : OpenZWave::Driver::HandleRemoveFailedNodeRequest(unsigned char*) + 0x4c [0xb6b6b02c]
Feb 24 11:21:47 pi3 domoticz[19184]: 2020-02-24 11:21:47.246  Error: #4  /lib/libopenzwave.so.1.6 : OpenZWave::Driver::ProcessMsg(unsigned char*, unsigned char) + 0x9b8 [0xb6b6ff70]
Feb 24 11:21:47 pi3 domoticz[19184]: 2020-02-24 11:21:47.246  Error: #5  /lib/libopenzwave.so.1.6 : OpenZWave::Driver::ReadMsg() + 0x5d4 [0xb6b70f7c]
Feb 24 11:21:47 pi3 domoticz[19184]: 2020-02-24 11:21:47.246  Error: #6  /lib/libopenzwave.so.1.6 : OpenZWave::Driver::DriverThreadProc(OpenZWave::Internal::Platform::Event*) + 0x2d0 [0xb6b727a4]
Feb 24 11:21:47 pi3 domoticz[19184]: 2020-02-24 11:21:47.246  Error: #7  /lib/libopenzwave.so.1.6 : OpenZWave::Internal::Platform::ThreadImpl::Run() + 0x20 [0xb6b27f90]
Feb 24 11:21:47 pi3 domoticz[19184]: 2020-02-24 11:21:47.247  Error: #8  /lib/libopenzwave.so.1.6 : OpenZWave::Internal::Platform::ThreadImpl::ThreadProc(void*) + 0x8 [0xb6b27fac]
