I am just migrating to a new server, I have limited Linux experience but I get the following error when I check the status of the service: -
/home/domoticz/domoticz/domoticz: error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory
Now I believe this library isn't available for Ubuntu 19.10 and I've just tried compiling Domoticz from source, that made no difference.
I tried to manually install this library but it won't let me due to a dependency issue.
Can anyone help, I am sure there must be a simple work around?
Domoticz works on my old server running the same OS, but that was upgraded, rather than installed from fresh.
Please help...
Unable to get working on Ubuntu 19.10 - libssl.so.1.0.0 error
- FireWizard
Re: Unable to get working on Ubuntu 19.10 - libssl.so.1.0.0 error
You can find it here: https://github.com/domoticz/domoticz/issues/3155
wget http://security.ubuntu.com/ubuntu/pool/ ... _amd64.deb
Then: sudo dpkg -i libssl1.0.0_1.0.2g-1ubuntu4.15_amd64.deb
MaxHipshot
domoticz@betelgeuze:~/domoticz$ ./domoticz
./domoticz: error while loading shared libraries: libssl.so.1.1: cannot open shared object file: No such file or directory
domoticz@betelgeuze:~/domoticz$ which openssl
/usr/bin/openssl
domoticz@betelgeuze:~/domoticz$ openssl version
OpenSSL 3.0.2 15 Mar 2022 (Library: OpenSSL 3.0.2 15 Mar 2022)
If I search for it the prompted error message, I fall into a rabbit hole being a myriad of possible reasons without a clear understanding of what is the problem and how to solve it. This is beyond me.
Please advise
/usr/bin/openssl
Please advise
- Domoticz version: 2026.3
