[Zigate] Unreachable device reported every two days or so
Posted: Sunday 23 February 2020 9:15
Hi Guys !
I didn't do much modifications since my last small issue https://www.domoticz.com/forum/viewtopi ... 68&t=31312.
However every two days or so, i wake up and see that none of my automatic schedules were executed.
I don't have the logs from the first times but it was always similar to this :
displays every seconds (or even multiple times a second) until I restart domoticz.
If I tcpdump during the issue I don't see any communication towards the zigate.
restarting domoticz solves the issue.
This morning the logs were completely different
These are the logs I have :
This time restarting domoticz solved the issue as well but it took a very long time.
I did a ram snapshot of my VM with the issue if needed.
I was not able to find the error in the forum existing thread so I allow myself to open this thread.
I am using last stable domoticz release 4.10717 2019-05-09 and I can see those kind of messages.
As for zigate I am on the stable branch as well.
As a workaround i could just monitor the logs and when recording only errors i can restart domoticz for me to avoid any issue when i am not home.
Thanks in advance for your advices
2020-02-20 23:39:04.740 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 45 sec
2020-02-20 23:39:04.742 Error: (Zigate) No transport, write directive to 'Zigate' ignored.
2020-02-20 23:39:09.760 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 50 sec
2020-02-20 23:39:14.729 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 55 sec
2020-02-20 23:39:19.748 (Zigate) pingZigate - WARNING: Ping sent but no response yet from Zigate. Status: Sent - Ping: 60 sec
2020-02-20 23:39:19.750 Error: (Zigate) pingZigate - no Heartbeat with Zigate, try to reConnect
2020-02-20 23:39:19.751 (Zigate) Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '8x.4x.17x.18x', Port: '9999', Baud: -1, Connected: False, Parent: 'None'
2020-02-20 23:39:19.751 (Zigate) Lost connection, reConn Transport.reConn: Name: 'Zigate', Transport: 'TCP/IP', Protocol: 'None ', Address: '8x.4x.17x.18x', Port: '9999', Baud: -1, Connected: False, Parent: 'None'
2020-02-20 23:39:19.752 Status: (Zigate) Connection Name: Zigate, Transport: TCP/IP, Address: None:9999
2020-02-20 23:40:24.892 Error: (Zigate) onMessage : Frame CRC is bad, computed = 112 received = 242
2020-02-20 23:40:39.898 Error: (Zigate) onMessage : Frame CRC is bad, computed = 119 received = 240
2020-02-20 23:40:54.947 Error: (Zigate) onMessage : Frame size is bad, computed = 61 received = 69
2020-02-21 00:30:41.561 Error: (Zigate) pingZigate - unknown status : None
2020-02-21 00:30:46.531 Error: (Zigate) pingZigate - unknown status : None
2020-02-21 00:30:51.550 Error: (Zigate) pingZigate - unknown status : None
Last unknown status : None If I tcpdump during the issue I don't see any communication towards the zigate.
2020-02-23 06:21:31.631 Status: (Zigate) Device Annoucement ShortAddr: 13ec, IEEE: 00158d0002a71956
2020-02-23 06:21:31.632 (Zigate) Decode004d - rebind clusters for 13ec
2020-02-23 06:29:01.974 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum+Baro-00158d0001ab445f-01) 0:10.5;89.0;3;1008.4;3
2020-02-23 06:29:01.976 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0001ab445f-01) 0:10.5;89.0;3
2020-02-23 06:29:01.978 (Zigate) UpdateDevice - (Balcon-Humidité) 89.0:3
2020-02-23 06:29:02.087 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum+Baro-00158d0001ab445f-01) 0:10.5;89.0;3;1008.0;3
2020-02-23 06:29:02.093 (Zigate) UpdateDevice - (Balcon-Baromètre) 0:1008.0;3
2020-02-23 06:29:02.096 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum+Baro-00158d0001ab445f-01) 0:10.5;89.0;3;1008.4;3
2020-02-23 06:29:02.097 (Zigate) UpdateDevice - (Balcon-Baromètre) 0:1008.4;3
2020-02-23 06:35:47.645 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum+Baro-00158d0001ab445f-01) 0:10.6;89.0;3;1008.4;3
2020-02-23 06:35:47.647 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum-00158d0001ab445f-01) 0:10.6;89.0;3
2020-02-23 06:35:47.648 (Zigate) UpdateDevice - (Balcon-Température) 10.6:10.6
2020-02-23 06:35:47.801 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum+Baro-00158d0001ab445f-01) 0:10.6;89.0;3;1008.0;3
2020-02-23 06:35:47.803 (Zigate) UpdateDevice - (Balcon-Baromètre) 0:1008.0;3
2020-02-23 06:35:47.805 (Zigate) UpdateDevice - (Zigate - lumi.weather_Temp+Hum+Baro-00158d0001ab445f-01) 0:10.6;89.0;3;1008.1;3
2020-02-23 06:35:47.806 (Zigate) UpdateDevice - (Balcon-Baromètre) 0:1008.1;3
2020-02-23 06:44:25.270 Error: PluginSystem: Exception processing message.
2020-02-23 06:45:33.336 Error: Zigate hardware (2) thread seems to have ended unexpectedly
2020-02-23 06:45:47.341 Error: Zigate hardware (2) thread seems to have ended unexpectedly
2020-02-23 06:46:01.346 Error: Zigate hardware (2) thread seems to have ended unexpectedly
this last error is repeated every 14seconds until I wake up in the morning and restart domoticzI did a ram snapshot of my VM with the issue if needed.
Error: (Zigate) ATTENTION: the WebServer part is not supported with this version of Domoticz. Please upgrade to a version greater than 4.10901Code: Select all
root@domo:/home/domoticz/domoticz/plugins/Domoticz-Zigate# git branch
* stableThanks in advance for your advices
