System-alive-checker, final setup
Posted: Friday 21 February 2020 1:29
by HvdW
I have setup 2 system-alive devices CV-17 and Luftdaten to check 2 ESP8266 units like explained
in the Domoticz WiKi.
Notification is set for switch-off using pushbullet.
They're working as expected.
Setting Pushbullet to Enabled (in Settings->Notifications) it will send a pushmessage for these devices as well for all the other devices in my Domoticz setup.
That is where this script originating from @Dannybloe comes in.
I want notifications for just these 2 devices, not alarming at first notice but after a while and after double-checking.
-- this script can be used in conjunction with the System-alive checker plug-in.
-- the plugin pings a list of devices and creates switches for these devices
-- the reason for this script is to not treat devices as dead immediately after they
-- do not respond. More often than not, the second ping atempt does work. So only
-- if the device has been not responding for a while AFTER it is been presumed dead
-- then this script will notify you
-- put the names of these switches in the devicesToCheck list
-- you may have to tweak the THRESHOLD depending on the check interval
local THRESHOLD = 10 -- minutes
local devicesToCheck = {'CV-17', 'Luftdaten'}
active = true,
devices = devicesToCheck,
timer = 'every 5 minutes'
data = {
notified = { initial = {} }
execute = function(domoticz, device, triggerInfo)
if (triggerInfo.type == domoticz.EVENT_TYPE_TIMER) then
-- check all devices that are off and have not been updated in the past 5 minutes and have not been notified for
for index, deviceName in pairs(devicesToCheck) do
local device = domoticz.devices[deviceName]
if (device.state == 'Off' and
device.lastUpdate.minutesAgo >= THRESHOLD and
domoticz.data.notified[deviceName] == false) then
domoticz.notify(deviceName .. ' is not responding anymore.',' ',domoticz.PRIORITY_HIGH)
-- make sure we only notify once for this device in this case
domoticz.data.notified[deviceName] = true
domoticz.data.notified[device.name] = false
What I expected it to do is send a Pushbullet message.
It doesn't.
I must have overseen something.
Help is appreciated.
Re: System-alive-checker, final setup [Solved]
Posted: Friday 21 February 2020 1:40
by waaren
HvdW wrote: Friday 21 February 2020 1:29
besides false and true a value can also be nil
Can you try and change
to
domoticz.data.notified[deviceName] ~= true
Posted: Saturday 04 April 2020 0:07
by HvdW
@waaren
I've been testing the if statement and it's definitly the
that does not respond.
same goes for
Posted: Saturday 04 April 2020 1:16
by waaren
HvdW wrote: Saturday 04 April 2020 0:07
same goes for
Please always include log when reporting script issues on the forum. It will make it so much easier to help you... Thx
Can you try this. The example you used is from the early days of dzVents. A lot have changed since then..
'CV-17',
'Luftdaten',
return
on =
timer =
'every 5 minutes',
data =
logging =
level = domoticz.LOG_DEBUG, -- change to LOG_ERROR when script executes without problems
marker = 'notify',
execute = function(dz, item)
if item.isTimer then
for index, deviceName in ipairs(devicesToCheck) do
dz.log('device ' .. deviceName, dz.LOG_DEBUG)
local device = dz.devices(deviceName)
if device.state == 'Off' and device.lastUpdate.minutesAgo >= THRESHOLD and dz.data.notified[deviceName] ~= true then
dz.log('Idle device ' .. deviceName, dz.LOG_DEBUG)
dz.notify('notifyer', deviceName .. ' is not responding anymore.',dz.PRIORITY_HIGH)
dz.data.notified[deviceName] = true
dz.data.notified[item.name] = false
Posted: Saturday 04 April 2020 21:47
by HvdW
I had already replaced it with the example from the 2020.1 version.
I have setup your dzvents script and it is running with a threshold of 2 minutes and a every minute check.
If won't enter the if loop.
Here's the log output.
2020-04-04 21:43:00.275 Status: dzVents: Info: notify: ------ Start internal script: System-alive-check:, trigger: "every minute"
2020-04-04 21:43:00.275 Status: dzVents: Debug: notify: device CV-ping
2020-04-04 21:43:00.290 Status: dzVents: Debug: notify: Processing device-adapter for CV-ping: Switch device adapter
2020-04-04 21:43:00.290 Status: dzVents: Debug: notify: device Luftdaten PM10
2020-04-04 21:43:00.291 Status: dzVents: Debug: notify: Processing device-adapter for Luftdaten PM10: Custom sensor device adapter
2020-04-04 21:43:00.292 Status: dzVents: Info: notify: ------ Finished System-alive-check
Posted: Saturday 04 April 2020 22:07
by waaren
HvdW wrote: Saturday 04 April 2020 21:47
It won't enter the if loop.
I added some log statements to help you identify what is happening.
To prevent conflicts when using dzVents scripts with a data section you have to remove the data file before saving a new version.
The data file is <domoticz dir>/scripts/dzVents/data/__data_<scriptname>.lua>
'CV-17',
'Luftdaten',
return
on =
timer =
'every 5 minutes',
data =
notified = { initial = {} },
logging =
marker = 'notify',
dz.log('device name ' .. device.name, dz.LOG_DEBUG)
dz.log('device state ' .. device.state, dz.LOG_DEBUG)
dz.log('device lastUpdate ' .. device.lastUpdate.minutesAgo, dz.LOG_DEBUG)
dz.log('device notified ' .. tostring(dz.data.notified[deviceName]), dz.LOG_DEBUG)
Posted: Saturday 04 April 2020 22:50
by HvdW
Hi @waaren
Here is the result when both are responding:
2020-04-04 23:06:00.227 Status: dzVents: Info: notify: ------ Start internal script: System-alive-check:, trigger: "every minute"
2020-04-04 23:06:00.243 Status: dzVents: Debug: notify: Processing device-adapter for CV-ping: Switch device adapter
2020-04-04 23:06:00.243 Status: dzVents: Debug: notify: device name CV-ping
2020-04-04 23:06:00.243 Status: dzVents: Debug: notify: device state On
2020-04-04 23:06:00.243 Status: dzVents: Debug: notify: device lastUpdate 1332
2020-04-04 23:06:00.243 Status: dzVents: Debug: notify: device notified nil
2020-04-04 23:06:00.244 Status: dzVents: Debug: notify: Processing device-adapter for Luftdaten PM10: Custom sensor device adapter
2020-04-04 23:06:00.244 Status: dzVents: Debug: notify: device name Luftdaten PM10
2020-04-04 23:06:00.244 Status: dzVents: Debug: notify: device state 10.43
2020-04-04 23:06:00.244 Status: dzVents: Debug: notify: device lastUpdate 2
2020-04-04 23:06:00.244 Status: dzVents: Debug: notify: device notified false
2020-04-04 23:06:00.245 Status: dzVents: Info: notify: ------ Finished System-alive-check
Below when CV switch is unplugged:
2020-04-04 23:08:23.230 Status: dzVents: Info: Handling events for: "CV-ping", value: "Off"
2020-04-04 23:08:23.230 Status: dzVents: Info: notify: ------ Start internal script: System-alive-check: Device: "CV-ping (System Alive Checker)", Index: 59
2020-04-04 23:08:23.231 Status: dzVents: Info: notify: ------ Finished System-alive-check
After round 1:
2020-04-04 23:09:00.280 Status: dzVents: Info: notify: ------ Start internal script: System-alive-check:, trigger: "every minute"
2020-04-04 23:09:00.295 Status: dzVents: Debug: notify: Processing device-adapter for CV-ping: Switch device adapter
2020-04-04 23:09:00.295 Status: dzVents: Debug: notify: device name CV-ping
2020-04-04 23:09:00.295 Status: dzVents: Debug: notify: device state Off
2020-04-04 23:09:00.295 Status: dzVents: Debug: notify: device lastUpdate 0
2020-04-04 23:09:00.295 Status: dzVents: Debug: notify: device notified false
2020-04-04 23:09:00.296 Status: dzVents: Debug: notify: Processing device-adapter for Luftdaten PM10: Custom sensor device adapter
2020-04-04 23:09:00.296 Status: dzVents: Debug: notify: device name Luftdaten PM10
2020-04-04 23:09:00.296 Status: dzVents: Debug: notify: device state 10.43
2020-04-04 23:09:00.297 Status: dzVents: Debug: notify: device lastUpdate 5
2020-04-04 23:09:00.297 Status: dzVents: Debug: notify: device notified false
2020-04-04 23:09:00.297 Status: dzVents: Info: notify: ------ Finished System-alive-check
After round 2:
2020-04-04 23:11:00.309 Status: dzVents: Info: notify: ------ Start internal script: System-alive-check:, trigger: "every minute"
2020-04-04 23:11:00.325 Status: dzVents: Debug: notify: Processing device-adapter for CV-ping: Switch device adapter
2020-04-04 23:11:00.325 Status: dzVents: Debug: notify: device name CV-ping
2020-04-04 23:11:00.325 Status: dzVents: Debug: notify: device state Off
2020-04-04 23:11:00.325 Status: dzVents: Debug: notify: device lastUpdate 2
2020-04-04 23:11:00.325 Status: dzVents: Debug: notify: device notified false
2020-04-04 23:11:00.325 Status: dzVents: Debug: notify: Idle device CV-ping
2020-04-04 23:11:00.326 Status: dzVents: Debug: notify: Processing device-adapter for Luftdaten PM10: Custom sensor device adapter
2020-04-04 23:11:00.326 Status: dzVents: Debug: notify: device name Luftdaten PM10
2020-04-04 23:11:00.326 Status: dzVents: Debug: notify: device state 10.43
2020-04-04 23:11:00.326 Status: dzVents: Debug: notify: device lastUpdate 7
2020-04-04 23:11:00.326 Status: dzVents: Debug: notify: device notified false
2020-04-04 23:11:00.327 Status: dzVents: Info: notify: ------ Finished System-alive-check
Posted: Saturday 04 April 2020 23:05
by waaren
HvdW wrote: Saturday 04 April 2020 22:50
Hi @waaren
Here is the result:
2020-04-04 22:48:00.552 Status: dzVents: Debug: notify: device name CV-ping
2020-04-04 22:48:00.552 Status: dzVents: Debug: notify: device state On
2020-04-04 22:48:00.553 Status: dzVents: Debug: notify: device name Luftdaten PM10
2020-04-04 22:48:00.553 Status: dzVents: Debug: notify: device state 10.43
Seems to be correct. Both devices do not have state 'Off' so the script skips the if step. No need to send a notification.
Posted: Saturday 04 April 2020 23:45
by HvdW
Luftdaten off:
2020-04-04 23:29:00.503 Status: dzVents: Info: notify: ------ Start internal script: System-alive-check:, trigger: "every minute"
2020-04-04 23:29:00.519 Status: dzVents: Debug: notify: Processing device-adapter for CV-ping: Switch device adapter
2020-04-04 23:29:00.519 Status: dzVents: Debug: notify: device name CV-ping
2020-04-04 23:29:00.519 Status: dzVents: Debug: notify: device state On
2020-04-04 23:29:00.519 Status: dzVents: Debug: notify: device lastUpdate 13
2020-04-04 23:29:00.519 Status: dzVents: Debug: notify: device notified false
2020-04-04 23:29:00.520 Status: dzVents: Debug: notify: Processing device-adapter for Luftdaten: Switch device adapter
2020-04-04 23:29:00.520 Status: dzVents: Debug: notify: device name Luftdaten
2020-04-04 23:29:00.520 Status: dzVents: Debug: notify: device state Off
2020-04-04 23:29:00.520 Status: dzVents: Debug: notify: device lastUpdate 2
2020-04-04 23:29:00.520 Status: dzVents: Debug: notify: [b]device notified nil[/b]
2020-04-04 23:29:00.520 Status: dzVents: Debug: notify: Idle device Luftdaten
2020-04-04 23:29:00.521 Status: dzVents: Info: notify: ------ Finished System-alive-check
2020-04-04 23:29:00.522 Status: EventSystem: Script event triggered: /home/hein/domoticz/dzVents/runtime/dzVents.lua
2020-04-04 23:29:00.524 Status: Notification: notifyer
2020-04-04 23:29:00.525 Status: Notification: notifyer
2020-04-04 23:31:00.464 Status: dzVents: Info: notify: ------ Start internal script: System-alive-check:, trigger: "every minute"
2020-04-04 23:31:00.479 Status: dzVents: Debug: notify: Processing device-adapter for CV-ping: Switch device adapter
2020-04-04 23:31:00.479 Status: dzVents: Debug: notify: device name CV-ping
2020-04-04 23:31:00.479 Status: dzVents: Debug: notify: device state On
2020-04-04 23:31:00.479 Status: dzVents: Debug: notify: device lastUpdate 15
2020-04-04 23:31:00.479 Status: dzVents: Debug: notify: device notified false
2020-04-04 23:31:00.480 Status: dzVents: Debug: notify: Processing device-adapter for Luftdaten: Switch device adapter
2020-04-04 23:31:00.480 Status: dzVents: Debug: notify: device name Luftdaten
2020-04-04 23:31:00.480 Status: dzVents: Debug: notify: device state Off
2020-04-04 23:31:00.480 Status: dzVents: Debug: notify: device lastUpdate 4
2020-04-04 23:31:00.480 Status: dzVents: Debug: notify: [b]device notified true[/b]
2020-04-04 23:31:00.481 Status: dzVents: Info: notify: ------ Finished System-alive-check
2020-04-04 23:31:00.620 Status: EventSystem: Script event triggered: /home/hein/domoticz/dzVents/runtime/dzVents.lua
2020-04-04 23:31:00.659 Status: Notification: notifyer
Device notified can be nil (in case device state On) or true (in case device state Off)
The script doesn't enter the if statement below:
I tested with ==true as well.
Posted: Saturday 04 April 2020 23:52
by waaren
HvdW wrote: Saturday 04 April 2020 23:45
Yes it does. That's why you see the line
Posted: Sunday 05 April 2020 0:11
by HvdW
You're right it is working like it should.
Thanks a lot for helping.
Posted: Sunday 05 April 2020 1:01
by waaren
HvdW wrote: Sunday 05 April 2020 0:11
Why aren't the lines
dz.notify('notifyer', deviceName .. ' achter de tweede if.',dz.PRIORITY_HIGH)
displayed?
dz.notify does not display. It notifies using the domoticz notification system.
see the wiki
notify(subject, message, priority, sound, extra, subsystem): Function. Send a notification (like Prowl). Priority can be like domoticz.PRIORITY_LOW, PRIORITY_MODERATE, PRIORITY_NORMAL, PRIORITY_HIGH, PRIORITY_EMERGENCY. For sound see the SOUND constants below. subsystem can be a table containing one or more notification subsystems. See domoticz.NSS_subsystem types.
