Not all widgets are created (Zigate plugin )
Posted: Monday 17 February 2020 7:57
by blooesky
I paired with zigate an xiaomi plug but in domoticz it was created only 2 widgets, switch and voltage. Two widgets are missing: live electricity usage and general electricity counter.
After I deleted the device from domoticz and I tried again and is the same result.
I using domoticz beta, zigate firmware 3.1c and plugin beta 4.8.002
Re: Not all widgets are created (Zigate plugin )
Posted: Monday 17 February 2020 8:00
by pipiche
Please do provide the logs when doing the pairing.
In addition please attach ( not copy paste) the export of Web admin -> tool -> list of devices raw (json) .
This will help to understand what happens.
Could you also give the reference of the device
Posted: Monday 17 February 2020 8:23
by pipiche
pipiche wrote: Monday 17 February 2020 8:00
This could be related to a new device version/firmware
Posted: Monday 17 February 2020 11:27
by blooesky
2020-02-17 12:19:27.629 (Zigate) --> Adding device 37ba in self.DevicesInPairingMode
2020-02-17 12:19:27.629 (Zigate) --> ['b7e5', 'd565', 'a512', '37ba']
2020-02-17 12:19:27.628 Status: (Zigate) Device Announcement Addr: 37ba, IEEE: 00158d0001717a57 Join Flag: 0x00 - join a network through association RSSI: 0
2020-02-17 12:19:28.263 Status: (Zigate) [-] NEW OBJECT: 37ba Active Endpoint Response Ep: 01 RSSI: 48
2020-02-17 12:19:28.263 Status: (Zigate) [-] NEW OBJECT: 37ba Active Endpoint Response Ep: 02 RSSI: 48
2020-02-17 12:19:28.263 Status: (Zigate) [-] NEW OBJECT: 37ba Active Endpoint Response Ep: 03 RSSI: 48
2020-02-17 12:19:28.263 Status: (Zigate) [-] NEW OBJECT: 37ba Request Simple Descriptor for Ep: 01
2020-02-17 12:19:28.264 Status: (Zigate) [-] NEW OBJECT: 37ba Request Simple Descriptor for Ep: 02
2020-02-17 12:19:28.265 Status: (Zigate) [-] NEW OBJECT: 37ba Request Simple Descriptor for Ep: 03
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba Simple Descriptor Response EP: 0x01 RSSI: 48
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba ProfileID 0104
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba ZDeviceID 0051
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba Application Version 0001
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster IN Count: 09
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 1: 0000 (Basic)
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 2: 0004 (Groups)
2020-02-17 12:19:28.368 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 3: 0003 (Identify)
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 4: 0006 (On/Off)
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 5: 0010 (Binary Output (Basic))
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 6: 0005 (Scenes)
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 7: 000a (Time)
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 8: 0001 (Power Configuration)
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 9: 0002
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster OUT Count: 02
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster Out 1: 0019 (Over-the-Air Upgrade)
2020-02-17 12:19:28.369 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster Out 2: 000a (Time)
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba Simple Descriptor Response EP: 0x02 RSSI: 48
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba ProfileID 0104
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba ZDeviceID 0009
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba Application Version 0001
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster IN Count: 01
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 1: 000c (Analog Input (basic))
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster OUT Count: 02
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster Out 1: 000c (Analog Input (basic))
2020-02-17 12:19:28.473 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster Out 2: 0004 (Groups)
2020-02-17 12:19:28.576 Status: (Zigate) [-] NEW OBJECT: 37ba Simple Descriptor Response EP: 0x03 RSSI: 48
2020-02-17 12:19:28.576 Status: (Zigate) [-] NEW OBJECT: 37ba ProfileID 0104
2020-02-17 12:19:28.576 Status: (Zigate) [-] NEW OBJECT: 37ba ZDeviceID 0053
2020-02-17 12:19:28.576 Status: (Zigate) [-] NEW OBJECT: 37ba Application Version 0001
2020-02-17 12:19:28.576 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster IN Count: 01
2020-02-17 12:19:28.577 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster In 1: 000c (Analog Input (basic))
2020-02-17 12:19:28.577 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster OUT Count: 01
2020-02-17 12:19:28.577 Status: (Zigate) [-] NEW OBJECT: 37ba Cluster Out 1: 000c (Analog Input (basic))
2020-02-17 12:19:29.090 Error: (Zigate) ReadCluster - 0000 - 37ba/01 Attribut ff01 received while device not inDB
2020-02-17 12:19:31.907 Status: (Zigate) [0] NEW OBJECT: 37ba Model Name: lumi.plug
2020-02-17 12:19:31.907 Status: (Zigate) [0] NEW OBJECT: 37ba Request Node Descriptor
2020-02-17 12:19:36.878 Status: (Zigate) [1] NEW OBJECT: 37ba Model Name: lumi.plug
2020-02-17 12:19:41.922 (Zigate) WARNING - ZigateCmd: 0140 0237ba01010002000000000000FF ZigateQueue: 16
2020-02-17 12:19:41.922 (Zigate) WARNING - ZigateCmd: 0140 0237ba01010019000000000000FF ZigateQueue: 17
2020-02-17 12:19:41.922 (Zigate) WARNING - ZigateCmd: 0140 0237ba0102000c000000000000FF ZigateQueue: 18
2020-02-17 12:19:41.923 (Zigate) WARNING - ZigateCmd: 0140 0237ba01020004000000000000FF ZigateQueue: 19
2020-02-17 12:19:41.923 (Zigate) WARNING - ZigateCmd: 0140 0237ba0103000c000000000000FF ZigateQueue: 20
2020-02-17 12:19:41.900 Status: (Zigate) [2] NEW OBJECT: 37ba Model Name: lumi.plug
2020-02-17 12:19:41.901 Status: (Zigate) [2] NEW OBJECT: 37ba Model Name: lumi.plug
2020-02-17 12:19:42.825 (Zigate) UpdateDevice - (Zigate - lumi.plug_Voltage-00158d0001717a57-01) 0:217.0;217.0
Posted: Monday 17 February 2020 13:40
by pipiche
Thanks for thos information. Please kindly update to the latest beta branche ( git pull ), and redo the pairing after having removed the plug related widgets
Posted: Monday 17 February 2020 14:58
by blooesky
You're welcome and thank you too for your support! I'll try and i'll return with feed back.
Posted: Monday 17 February 2020 21:41
by blooesky
Widgets are created correctly and are functional for now.
Thank you very much!
Posted: Monday 17 February 2020 21:48
by pipiche
great
