PiKrellCam
Posted: Sunday 16 February 2020 10:51
Anyone uses a script in PikrellCam to make an action in Domoticz on starting motion capture
Or sending email with pictures ?
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
on_motion_begin /home/pi/region.py
on_motion_end /home/pi/on_motion_end.sh
#!/usr/bin/env python
import os,sys,socket,time
from subprocess import Popen
from shutil import copyfile
hold = 5000
holdoff = 180000
filename = '/run/pikrellcam/motion-events'
file = open('/run/pikrellcam/motion-events','r')
state = 'wait'
tsent0 = open('/temp/tsent0').read()
tsent1 = open('/temp/tsent1').read()
tsent2 = open('/temp/tsent2').read()
while 1:
where = file.tell()
line = file.readline()
if not line:
time.sleep(0.01)
file.seek(where)
continue
line = line.strip('\n')
if (line.find('<motion') == 0):
state = 'motion'
elif (line.find('</motion>') == 0):
state = 'wait'
elif (line.find('<end>') == 0):
sys.exit(1)
elif (state == 'motion'):
if (line.startswith(str(2))):
tnow = int(round(time.time() * 1000))
if (tnow >= int(tsent2) + holdoff and tnow > int(tsent1) + hold and tnow > int(tsent0) + hold):
r, x, y, dx, dy, mag, count = line.split()
if (int(mag) >= 2 and int(mag) <= 40 and int(count) >= 110 and int(count) <= 3000):
copyfile('/run/pikrellcam/mjpeg.jpg', ('/temp/snapshot-%s-%s.jpg' % (r,tnow)))
tsent2 = tnow
with open('/temp/tsent2', 'w') as myFile:
myFile.write('{}'.format(tsent2))
Popen('/usr/bin/php /home/pi/pikrellcam/www/telegram.php %s %s %s %s' % (('/temp/snapshot-%s-%s.jpg' % (r,tnow)),str(r),str(mag),str(count),),shell=True)
elif (line.startswith(str(3))):
if (tnow >= int(tsent0) + holdoff and tnow > int(tsent1) + hold and tnow > int(tsent2) + hold):
if (int(mag) >= 2 and int(mag) <= 40 and int(count) >= 130 and int(count) <= 3000):
tsent0 = tnow
<?php
error_reporting(E_ALL);ini_set("display_errors","on");
$disnot=false;
$time=time();
$data=file_get_contents('http://192.168.2.2/camera.php');
if($data)$d=unserialize($data);
else {
$d=array();
$d['Weg']='On';
$d['meldingen']='On';
$d['poortrf']='Off';
if(isset($_REQUEST['silent'])){
$disnot=$_REQUEST['silent'];
if($d['Weg']==1||$d['meldingen']=='Off')$disnot=true;
if(isset($_REQUEST['snapshot'])||isset($_REQUEST['deurbel'])){
shell_exec('cp /run/pikrellcam/mjpeg.jpg /temp/snapshot.jpg');
$file='/temp/snapshot.jpg';
if($d['poortrf']=='On'||$d['meldingen']=='Off'){unlink($file);exit;}
$jpg_image=imagecreatefromjpeg($file);
$white=imagecolorallocate($jpg_image,0,0,0);
$font='/home/pi/pikrellcam/www/arial.ttf';
if(isset($_REQUEST['deurbel']))imagettftext($jpg_image,48,0,15,60,0,$font,'DEURBEL');
imagejpeg($jpg_image,$file);
imagedestroy($jpg_image);
usleep(20000);
$url="https://api.telegram.org/bot111TELEGRAMBOTID111/sendPhoto?chat_id=CHATID1";
$post_fields=array('chat_id'=>CHATID1,'photo'=>new CURLFile(realpath($file)),'disable_notification'=>$disnot);
for($x=1;$x<=100;$x++){
$ch=curl_init();
curl_setopt($ch,CURLOPT_HTTPHEADER,array("Content-Type:multipart/form-data"));
curl_setopt($ch,CURLOPT_URL,$url);
curl_setopt($ch,CURLOPT_RETURNTRANSFER,1);
curl_setopt($ch,CURLOPT_POSTFIELDS,$post_fields);
$result=json_decode(curl_exec($ch),true);
if($result['ok']===true){echo 'OK';break;}
sleep($x*3);
$url="https://api.telegram.org/bot111TELEGRAMBOTID111/sendPhoto?chat_id=CHATID2";
$post_fields=array('chat_id'=>CHATID2,'photo'=>new CURLFile(realpath($file)),'disable_notification'=>$disnot);
$ch=curl_init();
sleep($x*3);
$folder='/temp/stills/'.strftime("%Y/%m/%d",$time);
if(!file_exists($folder))mkdir($folder, 0777, true);
rename($file , $folder.'/'.str_replace('temp','',str_replace('.jpg','',$file)).'-'.strftime("%Y%m%d-%H%M%S",$time).'.jpg');
}elseif(isset($argv[1])){
$file=$argv[1];
$r=$argv[2];
$mag=$argv[3];
$count=$argv[4];
imagettftext($jpg_image,24,0,10,30,0,$font,"count=$count");
imagettftext($jpg_image,24,0,10,60,0,$font,"mag=$mag");
imagettftext($jpg_image,24,0,10,90,0,$font,"r=$r");
usleep(20000);
$ch=curl_init();
if($result['ok']===true){break;}
sleep($x*3);
$ch=curl_init();
sleep($x*3);
$timestamp=substr($file,-17);$timestamp=str_replace('.jpg','',$timestamp);$timestamp=$timestamp/1000;
$folder='/temp/stills/'.strftime("%Y/%m",$time);
rename($file , $folder.'/PiCam3-'.strftime("%Y-%m-%d_%H-%M-%S",$timestamp).'-'.$r.'.jpg');
<?php
* Pass2PHP
* php version 7.3.4-2
* @category Home_Automation
* @package Pass2PHP
* @author Guy Verschuere <[email protected]>
* @license GNU GPLv3
* @link https://egregius.be
require '/var/www/config.php';
$mysqli=new mysqli('localhost', $dbuser, $dbpass, $dbname);
$result = $mysqli->query("select n,i,s,UNIX_TIMESTAMP(t) as t,m from devices;") or trigger_error($mysqli->error." [$sql]");
while ($row = $result->fetch_array()) {
$d[$row['n']]['i'] = $row['i'];
$d[$row['n']]['s'] = $row['s'];
$d[$row['n']]['t'] = $row['t'];
$d[$row['n']]['m'] = $row['m'];
$data=array();
$data['Weg']=$d['Weg']['s'];
$data['meldingen']=$d['auto']['s'];
$data['poortrf']=$d['poortrf']['s'];
echo serialize($data);
shell_exec('curl -s "http://127.0.0.1/beep.php" > /dev/null 2>/dev/null &');
<?php
* Pass2PHP
* @package Pass2PHP
require 'secure/functions.php';
$d=fetchdata();
if ($d['Weg']['s']>0) {
die('Slapen of niet thuis');
if (past('Xlight')<60) {
die('To soon');
if (past('belknop')<60) {
die('To soon');
if ($d['poortrf']['s']=='On') {
die('Poort on');
if ($d['auto']['s']=='Off') {
die('Meldingen uitgeschakeld');
if ($d['lgtv']['s']=='On') {
shell_exec('python3 secure/lgtv.py -c send-message -a "Beweging oprit" 192.168.2.27');
if ($d['Xvol']['s']!=5) {
sl('Xvol', 5, basename(__FILE__).':'.__LINE__);
sl('Xbel', 20, basename(__FILE__).':'.__LINE__);
import os,sys,socket,time,urllib2
state = 'wait'
while 1:
where = file.tell()
if not line:
time.sleep(0.01)
file.seek(where)
continue
state = 'motion'
state = 'wait'
urllib2.urlopen("http://192.168.2.2:8080/json.htm?type=command¶m=switchlight&idx=1383&switchcmd=Off")
sys.exit(1)
urllib2.urlopen("http://192.168.2.2:8080/json.htm?type=command¶m=switchlight&idx=1383&switchcmd=On")
