Unresponsive Topic is solved
- EdwinK
- Domoticz version: BETA
Unresponsive
Dashticz became laggy and threw errors.. 'dashticz became unresponsive'.. and then ask to wait or cancel the operation. Thinking this was due to the fact that my DiskStation was using too many processes, I decided to move the webserver part to a RPi. After working with the default settings, I then put back the config and it worked... for a moment, then the same error about unresponsive returned.
I tried to get more info fro the developers tool on Chrome.
Lokonli
Re: Unresponsive
That is the websocket connection. The websocket connection will stay open, and should be no problem.
Can you test with adding to CONFIG.js the following:
config['enable_websocket'] = 0
This will disable the websocket connection.
- EdwinK
Re: Unresponsive
Unfortunately, same problem ;(
btw. With Firefox I get the following.
Source map error: Error: request failed with status 404
Resource URL: http://192.168.0.8:8082/dist/bundle.js
Source Map URL: ical.min.js.map
This page uses the non standard property “zoom”. Consider using calc() in the relevant property values, or using “transform” along with “transform-origin: 0 0”. bundle.js:1:67920
ReferenceError: alldevices is not defined
line 42 > scriptElement:83:7
Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user’s experience. For more help http://xhr.spec.whatwg.org/ bundle.js:53:83247
The script from “http://192.168.0.11:8080/json.htm?usern ... 1627889264” was loaded even though its MIME type (“application/json”) is not a valid JavaScript MIME type.
192.168.0.8:8082
The script from “http://192.168.0.11:8080/json.htm?usern ... 1627889266” was loaded even though its MIME type (“application/json”) is not a valid JavaScript MIME type.
192.168.0.8:8082
Lokonli
Re: Unresponsive
The following message means something is wrong:
Do you maybe use alldevices in your custom.js?
That may not work anymore ...
- EdwinK
Re: Unresponsive
O. I see...
- Spoiler: show
- EdwinK
Re: Unresponsive
unfortunately, after deleting those lines, Dashticz still becomes unresponsive.
- EdwinK
Re: Unresponsive
It looks like I've found it. When I removed all multigraph's the dashboard seems to work.
Lokonli
Re: Unresponsive
Interesting. Maybe it's the amount of data. How many graphs do you have? Can you check in DevTools how much graph data is received from Domoticz?
- EdwinK
Re: Unresponsive
I only had one. Need to create it again. I'll try later tonight
- EdwinK
Re: Unresponsive
This is what I have (from the readthedocs instrcutions)
- Spoiler: show
- Spoiler: show
- clinkadink
- Domoticz version: 2020.2
Re: Unresponsive
Hi, I have just noticed that the readthedocs graph section for the latest beta needs updating.
https://dashticz.readthedocs.io/en/beta ... tom-graphs
The example multigraph should be updated as follows:
- Spoiler: show
I posted an example block config (and graph) of these changes. Link below. Hope it makes sense
https://www.domoticz.com/forum/viewtopi ... 20#p236733
- EdwinK
Re: Unresponsive
going to take a look at it.
- EdwinK
Re: Unresponsive
Now this gives a error in config.js. Time to do some troubleshooting.
- EdwinK
Re: Unresponsive
This one works
This one as well:
blocks['multigraph_17'] = {
title: 'CPU, Memory & HDD',
devices: [ 491, 493, 495 ],
datasetColors: ['Red', 'Orange', 'Blue', 'Green', 'LightBlue', 'Aqua', 'Yellow', 'Purple', 'Pink'],
legend: true,
cartesian : 'linear',
graph: 'line',
lineFill: true,
drawOrderDay: ['v_491', 'v_495', 'v_493'],
drawOrderMonth: ['v_min_17', 'v_avg_17', 'v_min_18', 'v_max_17', 'v_avg_189', 'v_max_189', 'v_min_189', 'v_avg_18', 'v_max_18'],
legend: {
'v_491' : 'CPU',
'v_avg_491' : 'CPU avg',
'v_max_491' : 'CPU max',
'v_min_491' : 'CPU min',
'v_493' : 'MEM',
'v_avg_493' : 'MEM avg',
'v_max_493' : 'MEM max',
'v_min_493' : 'MEM min',
'v_495' : 'HDD',
'v_avg_495' : 'HDD avg',
'v_max_495' : 'HDD max',
'v_min_495' : 'HDD min'
blocks['graph_1'] = {
title: 'My Power',
graph: ['line','bar','bar'],
custom : {
"last day": {
range: 'day',
filter: '24 hours',
data: {
nett: 'd.v+d.v2-d.r1-d.r2',
usage: 'd.v+d.v2',
generation: '-d.r1-d.r2'
"last 2 weeks": {
range: 'month',
filter: '14 days',
data: {
usage: 'd.v+d.v2',
"last 6 months": {
range: 'year',
filter: '6 months',
data: {
usage: 'd.v+d.v2',
legend: true,
datasetColors:['blue','red','yellow']
- clinkadink
Re: Unresponsive
I am glad you have got it working
- EdwinK
Re: Unresponsive
Those two in my previous post are working, but the outside_inside_temp one is still throwing errors.
For now I'm going to forget about it, and see if I can think about it some more tomorrow.
- HansieNL
Re: Unresponsive
For latest betas there are some changes:EdwinK wrote: Sunday 16 February 2020 22:46 Those two in my previous post are working, but the outside_inside_temp one is still throwing errors.
I suppose your device idx for your graph is 1.
You have to define your device and use the _idx fot the graph types in the custom section.
title: 'My Power',
devices: [1],
custom : {
"last day": {
range: 'day',
filter: '24 hours',
data: {
nett: 'd.v_1+d.v2_1-d.r1_1-d.r2_1',
usage: 'd.v_1+d.v2_1',
generation: '-d.r1_1-d.r2_1'
"last 2 weeks": {
range: 'month',
filter: '14 days',
data: {
"last 6 months": {
range: 'year',
filter: '6 months',
data: {
legend: true,
Blah blah blah
- clinkadink
Re: Unresponsive
See updates this weekend for the graph:
https://www.domoticz.com/forum/viewtopi ... 05#p237105
