[Solved] Unknown device or GrpMgr not enabled after Zigate IP change
Posted: Wednesday 12 February 2020 10:15
I needed to change my WIFI Zigate public IP , so I did it in the Setting Hardware menu.
Once done no more request where seen on port 9999
I had a bunch of weird SQL disk error IO messages, I decided to reboot domoticz since I wanted to have some traffic from my domoticz to the zigate.
After the reboot the communication came back however i can't pass any order anymore
Here is a log when I try to open a light manually :
I guess some relationship was broken, could you help me fix that?
I also see this kind of messages :
Thanks a lot for your help
févr. 12 09:58:40 domo.tk domoticz[333]: 2020-02-12 09:58:40.849 Status: User: kacem initiated a switch command (5/Bureau-Interrupteur/On)
févr. 12 09:58:40 domo.tk domoticz[333]: 2020-02-12 09:58:40.879 Error: (Zigate) onCommand - Unknown device or GrpMgr not enabled Bureau-Interrupteur, unit 5 , id 00158d00026a0d2cI also see this kind of messages :
févr. 12 10:12:49 domo.tk domoticz[333]: 2020-02-12 10:12:49.237 Status: (Zigate) [07] DevID = 09 Network addr = a31e IEEE = 00158d000233eecb LQI = 114 Power = 00 not found in ListOfDevices
févr. 12 10:12:49 domo.tk domoticz[333]: 2020-02-12 10:12:49.237 Status: (Zigate) [08] DevID = 28 Network addr = 715b IEEE = 00124b001e728cca LQI = 076 Power = 01 not found in ListOfDevices
févr. 12 10:12:49 domo.tk domoticz[333]: 2020-02-12 10:12:49.338 Error: (Zigate) Decode8102 - Receiving a message from unknown device : 77c8 with Data : 5377c80104000000002100020082
févr. 12 10:12:49 domo.tk domoticz[333]: 2020-02-12 10:12:49.338 Error: (Zigate) Decode8102 - Receiving a message from unknown device : 77c8 with Data : 5477c801040600000018000101Thanks a lot for your help
