Dashticz v3 - IDX not showing data
58djarviss
Post by 58djarviss »
New to dashticz, I have an issue adding IDX. I created blocks and everything and added IDXs. IDX 7,8,9 and 10 are Philips Hue switch. They are all the same bulbs (only 7 is HueGo).
Everything works with IDX, 7,8,9 but when adding IDX 10, there is no switch at all as shown on the picture (bottom right is empty instead of IDX10).
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'blocktitle_1';
blocks['blocktitle_1']['title'] = 'Lumières';
blocks[7] = {width: 6}
blocks[8] = {width: 6}
blocks[9] = {width: 6}
blocks[10] = {width: 6}
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1',7,8,9,10]
columns[2]['width'] = 5;
Is there anything I missed ?
Thank you
Lokonli
Re: Dashticz v3 - IDX not showing data
Post by Lokonli »
Probably you have to add to CONFIG.js:
config['use_favorites'] = 0;
(you must read this setting as 'only show devices that are marked as favorite in Domoticz')
58djarviss
:) Thanks a lot.
I added it to the CONFIG.js file and now I can see it
