timeofday[‘Nighttime’] and time.hour < 7
binbo
Post by binbo »
Can someone help me with the logic of this Lua code...
If timeofday[‘Nighttime’] then
If time.hour < 7 then
 commandArray[‘light’] = “On”
I want the light to come on from night time — but not come on after 7am - as it is already light. (Night time ends at 7:36am)
My logic is wrong though as 23 is higher then 7 so my if statement will fail. I didn’t want to put a set hour in my if statement like this:
If time.hour > 18 and time.hour < 7
Any help would be great.
Many thanks.
bewo
Domoticz version: 2021.1
Re: timeofday[‘Nighttime’] and time.hour < 7
Post by bewo »
Hi binbo,
if you really wan't to use the hard time 7 o'clock it's possible, but i think it would be an nicer way to use sunset and sunrise...
-- Set the light device:
light_device = 'light'
-- Set the time:
now = os.date("%H") * 60 + os.date("%M")
sunrise = timeofday['SunsetInMinutes']
sunset = timeofday['SunriseInMinutes']
-- Turn on:
if now >= sunset or now <= sunrise then
    if otherdevices[light_device] == 'Off' then
        commandArray[light_device] = 'On'
-- Turn off:
    if otherdevices[light_device] == 'On' then
        commandArray[light_device] = 'Off'
As i understood the light should always be on in nighttime. So this is what the script will do. It wouldn't be possible to turn off the light by hand.
Individual projects:
Domoticz on a Intel Xeon Server | AeonLabs Z-Wave Gen.5 | RFXCOM RFXtrx433E USB | ESP-Wifi-Modules | Shellys
Wall-mounted 22" Touch Control Display (self construct) | LUA wind monitor| LUA heating control | and many many more :)
DaanT
Post by DaanT »
Hi binbo,
I don't rely understand you last sentence. But the last code you gave is a solution I would use too, but you need an 'OR', not an 'AND'.
If time.hour > 18 or time.hour < 7
DaanT
