Help Uninstalling Domoticz From Raspberry Pi Topic is solved
petecal
I just installed Domoticz on my Pi using:
"curl -L https....."
It has totally hung up my system.
I really need to uninstall it but I don't know how.
I am new to Pi, Linux, etc.
I have been using OpenHAB for home automation.
I was trying to get some z-wave devices to work on OpenHAB using an Aeotec USB stick.
I was having some difficulties so I went to the Aeotec site and that directed me to Domoticz.
I didn't know Domoticz was a HA system.
I am totally hung.
I can't deal with this now.
I have spent too much time trying to unravel this hole I have dug for myself.
Please tell me how to uninstall Domoticz.
Please.
Thank you so much.
Pete
I am totally hung.
Please.
Thank you so much.
Pete
Re: Help Uninstalling Domoticz From Raspberry Pi
Sounds like you need a beer...
How about a format and a clean setup, would that be an option?
Check these howto's: https://sancla.com
petecal
No way a clean install.
I have too much in this configuration.
Are you saying there is no way to uninstall Domoticz????
Do you still have ssh access to the Raspberry?
If so.
After that with positive result. Delete the complete domoticz dir in /home/pi/domoticz or otherwise where you installed it.
After this system should work as before and domoticz removed.
If so.
sudo systemctl stop domoticz.service
sudo systemctl disable domoticz.serviceCode: Select all
sudo rm /etc/init.d/domoticz.sh
sudo systemctl daemon-reload- McMelloW
- Domoticz version: V2024.1
EddyG,EddyG wrote: Sunday 09 February 2020 21:58 Do you still have ssh access to the Raspberry?
If so.
After that with positive result. Delete the complete domoticz dir in /home/pi/domoticz or otherwise where you installed it.Code: Select all
sudo systemctl stop domoticz.service sudo systemctl disable domoticz.serviceAfter this system should work as before and domoticz removed.Code: Select all
sudo rm /etc/init.d/domoticz.sh sudo systemctl daemon-reload
Does this include the /home/pi/domoticz/ folders also?
Greetings McMelloW
freijn
- Domoticz version: Stable
first stop the service as mentioned already thenMcMelloW wrote: Monday 10 February 2020 16:33 Does this include the /home/pi/domoticz/ folders also?
sudo rm -r /home/pi/domoticz
does the "trick"
- McMelloW
Thanks, freijn. I thought I already missed the domoticz foldersfreijn wrote: Monday 10 February 2020 16:42 first stop the service as mentioned already then
does the "trick"
Greetings McMelloW
petecal
EddyG,
Yep, that worked.
My Pi is blazing along like a Tesla.
Thank you so much!!!
Pete
Yep, that worked.
Pete
