Add same device/block multiple times, with different settings Topic is solved
Nakebod
Post by Nakebod »
Unless I'm overlooking some settings, it is currently not possible to add one device to multiple pages with different block-settings.
E.g. I have device 123.
In the CONFIG.js I've created blocks[123] with a specified with, title, w/e settings.
In my column[] config I add 123. So far so good.
But now I want to have the same device included on a different page.
Due to the page layout (e.g. more colums, different column sizes) I need to add device 123 with different size settings.
If you add a device-block multiple times with different settings, the last configured settings are applied.
Lokonli
Re: Add same device/block multiple times, with different settings
Post by Lokonli »
This is indeed a limitation of current version. It will be improved in a future release.
Sjonnie2017
Domoticz version: Latest ß
Post by Sjonnie2017 »
Second that! I would really (really ;)) like to have the ability to use blocks in multiple columns! In my use case the settings might be the same (ie. width).
Greetz,
Sjonnie
YouLess Energy meter
Lokonli
Post by Lokonli »
If the settings are the same then you just can reuse a block in multiple columns.
You have to use the beta of last night. Update with git pull.
Sjonnie2017
I just did update this morning and can confirm it works. Thank you for your swift solution!
Greetz,
Sjonnie
