Domoticz + Hombridge : Inverted MQTT data ?
Posted: Saturday 08 February 2020 1:36
Hi everyone,
I'm using Domoticz and Hombridge for month and I decided to add a 433Mhz motion sensor. In order to get feedback on my iPhone I activated the MQTT option in hombrigde, added the Domoticz hardware and the logs are obviously working because every time I move, I can get feedback in hombridge thx to Domoticz...
But... Most of my ON/OFF switch have now an issue : iOS Home App is stuck at sending ON values ! So I can switch on one time, and then I'm force to go to the Domoticz interface to switch it off ... Probably side effect, it also mess all iOS Home automations
If I deactivate the Domoticz MQTT interface (of change the publish topic), everything goes back to normal.
Everything's in Domoticz looks to work well.
If anyone have clues it will be welcomed
Raspberry Pi 3
Version: 4.10717
Build Hash: b38b49e5
Compile Date: 2019-05-09 13:04:08
dzVents Version: 2.4.19
Python Version: 3.4.2 (default, Sep 16 2019, 20:33:47) [GCC 4.9.2]
Homebridge
homebridge-edomoticz v2.1.22
Node.js Version v8.16.2
Npm version v6.13.7
Configured as follow : https://www.npmjs.com/package/homebridge-edomoticz
[2020-2-8 01:27:17] [eDomoticz] MQTT Message received for Détecteur de mouvement.
Name: Détecteur de mouvement
Device: Lighting 4,PT2262
Is Switch: true
SwitchTypeVal: 8
MQTT Message:
"Battery": 255,
"RSSI": 7,
"description": "",
"dtype": "Lighting 4",
"id": "5FF0A9",
"idx": 636,
"name": "Détecteur de mouvement",
"nvalue": 1,
"stype": "PT2262",
"svalue1": "415",
"switchType": "Motion Sensor",
"unit": 0
}Code: Select all
[2020-2-8 01:34:38] [eDomoticz] MQTT Message received for Lampe.
Device: Lighting 6,Blyss
Is Switch: true
SwitchTypeVal: 0
MQTT Message:
"Battery": 255,
"RSSI": 12,
"description": "",
"dtype": "Lighting 6",
"id": "060947",
"idx": 227,
"name": "Guirelande",
"nvalue": 0,
"stype": "Blyss",
"svalue1": "0",
"switchType": "On/Off",
"unit": 3
}Everything's in Domoticz looks to work well.
Raspberry Pi 3
Version: 4.10717
Homebridge
Npm version v6.13.7
