How to Send data to ESP8266 display
Posted: Friday 31 January 2020 21:31
by jandoedel
I have Domoticz running on a Raspberry.
I use different ESP8266 with espeasy on it sending data to Domoticz
Now i want on a display, at the ESPEasy, some data from Domoticz to display.
In Domoticz i can send 1 data to the ESP8266 with HTTPLink (http://192.168.0.21/control?cmd=lcd,3,12,%v)
I have to send more data to the display is this possible?
does anyone have this setup working.
On ESPEasy i have a LCD2004 working
Re: How to Send data to ESP8266 display
Posted: Wednesday 05 February 2020 20:09
by jandoedel
I use now in a lua script
commandArray[#commandArray+1] = {['OpenURL']='http://192.168.0.21/control?cmd=lcd,4,12,test'}
then i get on the display on line 4 pos 12 the word test
How can i display a value b.v. power with idx 90
Thanks Jan
Posted: Wednesday 12 February 2020 15:14
by jandoedel
Oke this is working.
-- LCD Aansturen
    Levering = 'P1 Smart Meter Delivery L1';
    Verbruik = 'Power';
    if otherdevices_svalues[Verbruik] > '0.0' then
           LCDLine3 = otherdevices_svalues[Verbruik];
           commandArray[1] = {['OpenURL']="http://192.168.0.21/control?cmd=lcd,3,1,Verbruik :" } ;
           commandArray[2] = {['OpenURL']="http://192.168.0.21/control?cmd=lcd,3,12,"..LCDLine3.. " " } ;
           print(LCDLine3)
        LCDLine3 = otherdevices_svalues[Levering];
        commandArray[1] = {['OpenURL']="http://192.168.0.21/control?cmd=lcd,3,1,Levering :" } ;
Posted: Wednesday 12 February 2020 15:29
by xury
Easier way is use MQTT import on ESPEasy to get values from domoticz/out topic using Node-red flow:
        "id": "8eea3e72.a634d",
        "type": "tab",
        "label": "Flow 6",
        "disabled": false,
        "info": ""
        "id": "43362c6c.ae8434",
        "type": "mqtt in",
        "z": "8eea3e72.a634d",
        "name": "",
        "topic": "domoticz/out",
        "qos": "2",
        "datatype": "auto",
        "broker": "9748a36f.44bdd",
        "x": 350,
        "y": 260,
        "wires": [
                "c2775a1f.93e698"
        "id": "c2775a1f.93e698",
        "type": "json",
        "name": "",
        "property": "payload",
        "action": "",
        "pretty": false,
        "x": 510,
        "y": 260,
        "wires": [
                "999344f2.06deb8"
        "id": "999344f2.06deb8",
        "type": "switch",
        "name": "",
        "property": "payload.idx",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "30",
                "vt": "str"
                "t": "eq",
                "v": "93",
                "vt": "str"
                "t": "eq",
                "v": "96",
                "vt": "str"
                "t": "eq",
                "v": "98",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 4,
        "x": 650,
        "y": 260,
        "wires": [
                "90eadebf.aa81d"
                "30467635.48e29a"
                "ff317967.d3f8a8"
                "d54b8ee0.0434a"
        "id": "d54b8ee0.0434a",
        "type": "function",
        "name": "Prepare event",
        "func": "temp = msg.payload;\nmsg.topic = \"cmnd/espeasy/test4\"\nmsg.payload =  parseFloat(temp.svalue1);\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 840,
        "y": 320,
        "wires": [
                "7db1ffba.bc5c8"
        "id": "ff317967.d3f8a8",
        "type": "function",
        "func": "temp = msg.payload;\nmsg.topic = \"cmnd/espeasy/test3\"\nmsg.payload =  parseFloat(temp.svalue1);\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 840,
        "y": 280,
        "wires": [
                "7db1ffba.bc5c8"
        "id": "30467635.48e29a",
        "type": "function",
        "func": "temp = msg.payload;\nmsg.topic = \"cmnd/espeasy/test2\"\nmsg.payload =  parseFloat(temp.svalue1);\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 840,
        "y": 240,
        "wires": [
                "7db1ffba.bc5c8"
        "id": "90eadebf.aa81d",
        "type": "function",
        "func": "temp = msg.payload;\nmsg.topic = \"cmnd/espeasy/test\"\nmsg.payload =  parseFloat(temp.svalue1);\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 840,
        "y": 180,
        "wires": [
                "7db1ffba.bc5c8"
        "id": "7db1ffba.bc5c8",
        "type": "mqtt out",
        "name": "",
        "topic": "",
        "qos": "2",
        "retain": "",
        "x": 1070,
        "y": 280,
        "wires": []
        "id": "9748a36f.44bdd",
        "type": "mqtt-broker",
        "z": "",
        "broker": "localhost",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "compatmode": true,
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "willTopic": "",
        "willQos": "0",
        "willPayload": ""
Posted: Thursday 13 February 2020 18:32
by jandoedel
thanks
This is new for my.
I try to look at it how this is working
Posted: Wednesday 31 August 2022 11:46
by heinemancp
So i use this:
  commandArray[1]={['OpenURL'] = baseurlESPEasy..'oledcmd,clear' }
    commandArray[2]={['OpenURL'] = baseurlESPEasy..'oled,1,1,**Domoticz**'..spatie..h..dubbelepunt..m}
    commandArray[3]={['OpenURL'] = baseurlESPEasy..'oled,2,1,T_in'..dubbelepunt..spatie..tp..spatie..'*C' }
but then i get error messages, because de LUA script cannot open the URL (thats correct, only sending text).
how to disable this error messages, and let it stop sending emails...
2022-08-31 11:45:01.569 Error: Error opening url: http://IP/control?cmd=oledcmd,clear
2022-08-31 11:45:01.745 Error: Error opening url: http://IP/control?cmd=oled,1,1,**Domoticz**%2011%3A45
2022-08-31 11:45:01.847 Error: Error opening url: http://IP/control?cmd=oled,2,1,T_in%3A%2023.1%20*C
2022-08-31 11:45:01.985 Error: Error opening url: http://IP/control?cmd=oled,5,1,T_BBQ%3A%20118.00%20*C
2022-08-31 11:45:05.317 Error: Error opening url: http://IP/control?cmd=oled,6,1,T_Vlees%3A%2020.00%20*C
