Tablet Easytouch (Marmitek)
JeroenL
Domoticz version: 2023.2
Post by JeroenL »
LS,
The Marmitek panel are getting cheap now, and can they be easily integrated into Domoticz. Did not see this yet on the forum, hence below how-to.
I created 16 buttons using the panel and named them P1, P2 etc in Domoticz.
For best results, I also created 16 slave buttons using the CM15Pro, these I named P1_slave, P2_slave etc. etc. The slave-buttons I linked the the regular buttons P1, P2 etc.
Domoticz picks up either the RFXCom or the CM15Pro signal as with X10 a signal gets lost from time-2-time.
I then use a LUA script to switch different devices (Zwave, Sonos, fire place etc). So like this you are not bounded with the panel to only X10 devices.
I created a template in PowerPoint to use as a background in the Panel, see ppt attached in case you like to use it.
Hope it inspires you.
-- Domoticz LUA script to use Marmitek Touchpanel
-- Version 1.0 -- 2019-12-27  -- First version of LUA Script.
local url_play   = 'http://192.168.178.55:5005/Keuken/play'
local url_stop   = 'http://192.168.178.55:5005/Keuken/pause'
local url_preset = 'http://192.168.178.55:5005/preset/touchpanel'
  if (devicechanged['P1'] == 'On') then    commandArray['Multi X Lamp'] = 'On'
    print('MultiX Lamp AAN, door Touchpanel')
  if (devicechanged['P1'] == 'Off') then    commandArray['Multi X Lamp'] = 'Off'
    print('MultiX Lamp UIT, door Touchpanel')
  if (devicechanged['P2'] == 'On') then    commandArray['Schemerlamp'] = 'On'
    print('Schemerlamp AAN, door Touchpanel')
  if (devicechanged['P2'] == 'Off') then    commandArray['Schemerlamp'] = 'Off'
    print('Schemerlamp UIT, door Touchpanel')
  if (devicechanged['P3'] == 'On') then    commandArray['Erker'] = 'On'
    print('Erker AAN, door Touchpanel')
  if (devicechanged['P3'] == 'Off') then    commandArray['Erker'] = 'Off'
    print('Erker UIT, door Touchpanel')
if (devicechanged['P4'] == 'On') then    commandArray['Torchère'] = 'On'
    print('Torchere AAN, door Touchpanel')
  if (devicechanged['P4'] == 'Off') then    commandArray['Torchère'] = 'Off'
    print('Torchère UIT, door Touchpanel')
if (devicechanged['P5'] == 'On') then    commandArray['Eettafel'] = 'On'
    print('Eettafel AAN, door Touchpanel')
  if (devicechanged['P5'] == 'Off') then    commandArray['Eettafel'] = 'Off'
    print('Eettafel UIT, door Touchpanel')
-- Woonkamner button (P6) is directly managed by Group activation
if (devicechanged['P7'] == 'On') then    commandArray['Gordijnen'] = 'On'
    print('Gordijen OPEN, door Touchpanel')
  if (devicechanged['P7'] == 'Off') then    commandArray['Gordijnen'] = 'Off'
    print('Gordijenen DICHT, door Touchpanel')
if (devicechanged['P8'] == 'On') then    commandArray['Keuken'] = 'On'
    print('Keuken AAN, door Touchpanel')
  if (devicechanged['P8'] == 'Off') then    commandArray['Keuken'] = 'Off'
    print('Keuken UIT, door Touchpanel')
if (devicechanged['P9'] == 'On') then    commandArray['Openhaard'] = 'On'
    print('Openhaard AAN, door Touchpanel')
  if (devicechanged['P9'] == 'Off') then    commandArray['Openhaard'] = 'Off'
    print('Openhaard UIT, door Touchpanel')
if (devicechanged['P10'] == 'On') then    commandArray['Hal'] = 'On'
    print('Hal AAN, door Touchpanel')
  if (devicechanged['P10'] == 'Off') then    commandArray['Hal'] = 'Off'
    print('Hal UIT, door Touchpanel')
if (devicechanged['P11'] == 'On') then    commandArray['Overloop'] = 'On'
    print('Overloop AAN, door Touchpanel')
  if (devicechanged['P11'] == 'Off') then    commandArray['Overloop'] = 'Off'
    print('Overloop UIT, door Touchpanel')
if (devicechanged['P12'] == 'On') then    commandArray['Slaapkamer'] = 'On'
    print('Slaapkamer AAN, door Touchpanel')
  if (devicechanged['P12'] == 'Off') then    commandArray['Slaapkamer'] = 'Off'
    print('Slaapkamer UIT, door Touchpanel')
-- Tuinverlichting (P13) directly managed in Group
if (devicechanged['P14'] == 'On') then
    commandArray['OpenURL'] = url_preset
--  state : Opening the preset file from the node_sonos directory, making Sono PLAY the preset file
    print('Sonos geSTART door Touchpanel')
  if (devicechanged['P14'] == 'Off') then
    commandArray['OpenURL'] = url_stop
    print('Sonos geSTOPT door Touchpanel')
Touch panel.part3.rar
(181.7 KiB) Downloaded 87 times
Touch panel.part2.rar
(350 KiB) Downloaded 54 times
Touch panel.part1.rar
(350 KiB) Downloaded 61 times
