Kaku smoke detector
arjan93
Kaku smoke detector
Post by arjan93 »
I`m looking for some new smoke detectors for my home automation system. I`m using a raspberry pi with domoticz on it. On the raspbarry i`ve add a rfxcom module. I`m already switching some lights with that so its working fine. Now i sow on the internet the kaku smoke detector ZSDR-850 but couldn`t find any information if it`s compatible witch domoticz and rfxcom. It`s working with a Zigbee protocol but i dont know if I can use it with the setup i have.
Does someone know if it`s compatible and how i can add it to domoticz?
pipiche
Re: Kaku smoke detector
Post by pipiche »
Could you kindly clarify which Zigbee Hub you are using .?
Sjonnie2017
Domoticz version: Latest ß
Post by Sjonnie2017 »
ZSDR-850 is a ZigBee device so you will need a bridge to connect it to Domoticz. It will not work with the 433RFXcom.
The smoke sensor itself is an exact copy of the Heiman HS1SA which works with the Conbee II stick (depending on the version of the Heiman sensor you buy ;)). The Heiman sensor is available for a mere € 25,- or such.
If you want a sensor that connects with 433RFXCom you might want to look at the FA21RF (of which I happen to have a few on sale ;))
YouLess Energy meter
domoticson
Post by domoticson »
shorturl.at/sKVZ0
This one is 10 usd, It works on 433, a guy tested it and showed how to add it. I`m waiting for mine to arrive.
