Zigate - Error: (Zigate) LQI:LQIresp
Posted: Wednesday 29 January 2020 17:56
by Haijes
I have an error when activating the 'permit join time', Error: (Zigate) LQI:LQIresp - Status: c1 for 1fc10100000000
Also, It is not possible to connect Ikea lamps. Is this the cause of the error?
I tried different methods of linking, but the lamp does not connect. Have anyone a suggestion?
System: Synology DS413 with domoticz 4.11597
Regards,
Ton
Re: Zigate - Error: (Zigate) LQI:LQIresp
Posted: Wednesday 29 January 2020 18:06
by pipiche
Do not worry of this error, that is not an issue .
Posted: Wednesday 29 January 2020 18:22
by Haijes
Pipiche, thank you for the quick reply.
Posted: Monday 03 February 2020 18:59
by pfloryann
I have an error in domoticz logs...but i don't know were it come from
2020-02-03 19:53:39.560 (Zigate) Request for IEEE for short address: b82c
2020-02-03 19:53:39.560 Error: (Zigate) Decode8102 - Receiving a message from unknown device : b82c with Data : c3b82c020001002100200001c8
How to fix it?
Posted: Tuesday 04 February 2020 9:09
by pipiche
pfloryann wrote: Monday 03 February 2020 18:59
How to fix it?
This error is telling you that you have a device which is paired with Zigate but is not known from the plugin.
Spo to fix it you need to find which one it is and repair it
Posted: Saturday 08 February 2020 22:04
by marktn
Everything works fine, but this was my log:
2020-02-08 08:10:46.531 Error: (Zigate) 'onMessage' failed 'ValueError':'invalid literal for int() with base 10: 'f4''.
2020-02-08 08:10:46.531 Error: (Zigate) ----> Line 797 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2020-02-08 08:10:46.531 Error: (Zigate) ----> Line 482 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2020-02-08 08:10:46.531 Error: (Zigate) ----> Line 254 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function onMessage
2020-02-08 08:10:46.532 Error: (Zigate) ----> Line 387 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function processFrame
2020-02-08 08:10:46.532 Error: (Zigate) ----> Line 486 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function processFrame
2020-02-08 08:10:46.532 Error: (Zigate) ----> Line 98 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function ZigateRead
2020-02-08 08:10:46.532 Error: (Zigate) ----> Line 1271 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/input.py', function Decode8102
2020-02-08 08:10:46.532 Error: (Zigate) ----> Line 190 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/readClusters.py', function ReadCluster
2020-02-08 08:10:46.532 Error: (Zigate) ----> Line 425 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/readClusters.py', function Cluster0000
2020-02-08 08:10:46.532 Error: (Zigate) ----> Line 969 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/domoticz.py', function MajDomoDevice
Posted: Sunday 09 February 2020 20:59
by pipiche
Please try to update to latest version. Not sure if it will fix that problem.
Could you let me know if you have a water leak detector ?
Posted: Monday 10 February 2020 20:35
by marktn
pipiche wrote: Sunday 09 February 2020 20:59
Yes i have a water leak detector. It's not leaking
Update of the plugin, done!
Posted: Wednesday 12 February 2020 21:08
by Haijes
Haijes wrote: Wednesday 29 January 2020 17:56
Problem solved. Use another USB port to connect Zigate
