One of my temperature/humidity sensors, an Oregon TGHN 132, suddenly stopped being updated in Domoticz, while the battery was recent, and the LED was still flashing every minute. I tried to move it close to the receiver, without success. Resetting it fixed the issue, but this created a new device ID in Domoticz, as usual, and I had to switch the old device to the new. I put a new battery just in case the old one was defective.
One month later, it happens again. No updates, despite the LED flashes, and radio range issues were ruled out.
Did anybody have similar issues?
Issues with Oregon temperature sensors
WvdM
- Domoticz version: Stable
Re: Issues with Oregon temperature sensors
Somewhat similar. Two no-name temperature/humidity sensors, disappearing at the exact same time, last reporting one second apart. They were on the Viking protocol. The moment I removed the batteries from number one, number two showed up again
. Pretty obvious: They were sending the signal at practically the same time, making it impossible for the RFXcom to read out either one.
The obvious difference is that only one of your sensors stopped, but maybe the problem is related.
