Thermostat for central heating (OpenTherm)
MMSoft
Post by MMSoft »
I'm looking for a thermostat for central heating (OpenTherm) via WiFi or LAN cable can work with Domoticz (Raspberry + B3).
And I would read from the room temperature and can change the set temperature both on the thermostat itself, as well as through Domoticz.
Without that there must always be made from a site of the manufacturer.
Which thermostat meets these conditions you think?
Sorry for my bad English.
MMSoft
Re: Thermostat for central heating (OpenTherm)
Post by MMSoft »
I've already chosen the "ThermoSmart"
This works well with the original app, but now I want to link this with Domoticz.
Who has experience with this and can help me a little bit on the way?
MMSoft
Post by MMSoft »
I ThermoSmart working with Domoticz and can now read both the temperature and also pause and write temperature and also pause.
harolds
Post by harolds »
It looks like there is some bug in that module. When I enable the ThermoSmart pluging and change the temperature manually while its still folloging the schedule it will result in ThermoSmart not going to 15 degrees during the night. So it stays on the previously set temperature. I will see if I can contact the owner of the plugin.
MMSoft
Post by MMSoft »
I had the problem that stopped the temperature at 5 degrees after a pause.
I solved this by one large block (standard week) in place ThermoSmart on all days and hours (with a temperature of 10 degrees). And now I have no more trouble.
Do you also have this problem after a break?
ubfssF
Domoticz version: 2.2364
Post by ubfssF »
@MMSoft, did you just use the username and password that you use to log in at https://my.thermosmart.com? I have used that for connecting Domoticz with the Thermosmart server (and have a simple password) but it doesn't work....
MMSoft
Post by MMSoft »
Yes I have the username and password used in Domoticz.
Go to Settings -> Hardware
Naam . . . . : ThermoSmart
Type . . . . : Thermosmart Thermostat
Data. . : Inactive
name. . . . (username)
Password. . (password)
Add
if you look at Settings -> Devices and searches for "ThermoSmart 'you will see this:
-Setpoint
-room temperature
-Outside temperature
-Thermostat Pause
Click the green arrow !!!
ubfssF
Post by ubfssF »
My problem of not being able to connect to the central Thermosmart server is solved by upgrading to the new Domoticz 2020.1 version :D
