No devices on devices tab in config Topic is solved
pvklink
Domoticz version: latest b
Post by pvklink »
I do not have devices on the devices tab with the latest beta on a rpi 3b with buster.
Only Chroome has this problem. I tried it with MS Edge, everything OK!
I delete the cache (f12), no solution.
Domoticz is working fine, and all the events are executed….
Jablotron connection, Ikea
pvklink
Re: No devices on devices tab in config
Post by pvklink »
dont know if thi helps
pvklink
Post by pvklink »
pvklink wrote: Monday 27 January 2020 11:45 dont know if this info helps a bit
sancla
Post by sancla »
Is there error in the Domoticz log?
What kind of sensors did you have? If you add the hardware sensor, is that making any difference?
Curious problem though :-)
Check these howto's: https://sancla.com
pvklink
Post by pvklink »
solved it...
Dont now exactly how...
Dit change some advanced chrome site settings....probably to much...
