Problem with auto installer
Scotty
Post by Scotty »
This evening I thought I'd give my Pi a fresh start and install everything from scratch.
I installed the latest Buster release available and proceeded to install Domoticz. All well and good so far.
Then I decided to try the new Auto Installation. It seems to get an error and abort mid way. I can set this up manually but thought I'd post this here and see if we can find a solution.
Here is a copy of my SSH session trying to install Dashticz.
pi@raspberrypi:~ $ . <(wget -qO - https://raw.githubusercontent.com/Dashticz/dashticz/beta/scripts/dashticz_install.sh )
This is the installation script for Dashticz
Using default settings
Dashticz repository: https://github.com/Dashticz/dashticz
Branch: master
Port: 8082
The script will create a folder for Dashticz in the following location:
/home/pi
Enter the folder name [dashticz]: dashticz
Dashticz will be installed in
dashticz
Dashticz has a master branch (=stable) and a beta branch (=most up-to-date)
Which branch to install? [master]: beta
Checking for git: [OK!]
Now cloning the Dashticz repository https://github.com/Dashticz/dashticz
Cloning into 'dashticz'...
remote: Enumerating objects: 202, done.
remote: Counting objects: 100% (202/202), done.
remote: Compressing objects: 100% (120/120), done.
remote: Total 8621 (delta 88), reused 164 (delta 75), pack-reused 8419
Receiving objects: 100% (8621/8621), 38.30 MiB | 1.12 MiB/s, done.
Resolving deltas: 100% (5634/5634), done.
Checking out files: 100% (596/596), done.
Checking for make: [OK!]
Configuring Dashticz.
What is the IP:port address of your Domoticz server? (example: 192.168.178.18:8080): 192.168.0.22:8080
Finding a free port for Dashticz
Port 8082 is available
Setting up Dashticz on port 8082
Starting make process ...
Checking container dtv3-8082
Checking port 8082
sudo docker build --build-arg tz="Europe/London" -t dtv3-8082 .
Sending build context to Docker daemon  72.79MB
Step 1/4 : FROM php:apache
 ---> 3041b4d61e21
Step 2/4 : ARG tz="Europe/Amsterdam"
 ---> Using cache
 ---> 098b8075fa68
Step 3/4 : RUN printf "[PHP]\ndate.timezone = $tz\n" > /usr/local/etc/php/conf.d/tzone.ini
 ---> Running in 2054f064100d
The command '/bin/sh -c printf "[PHP]\ndate.timezone = $tz\n" > /usr/local/etc/php/conf.d/tzone.ini' returned a non-zero code: 139
make: *** [Makefile:51: start] Error 139
Error during Make. Exiting
Connection to 192.168.0.22 closed.
Lokonli
Re: Problem with auto installer
Post by Lokonli »
Thanks for the feedback!
Apparently something goes wrong with setting the correct timezone while building the Docker image. I'll have a look.
danman87
Post by danman87 »
Hi, is there a solution for this problem?
I also have this problem.
Lokonli
Post by Lokonli »
danman87 wrote: Wednesday 15 April 2020 8:40 Hi, is there a solution for this problem?
I was not able to reproduce yet. So, let's try...
You have the same error as Scotty?
What is the result of the following command:
 cat /etc/timezone
Open Makefile.ini (in the Dashticz root folder):
nano Makefile.ini
Add the following to Makefile.ini:
(You don't have to change the lines starting with APP and PORT)
TZ=Europe/Amsterdam
and then try to rebuild the Docker image:
make start
danman87
Post by danman87 »
hi Lokonli,
Yes, i have exactly the same issue.
cat /etc/timezone
Europe/Amsterdam
pi@raspberrypi:~$ nano Makefile.ini
GNU nano 2.7.4 File: Makefile.ini
files was empty. i added ''TZ=Europe/Amsterdam''
i did the ''make start'' command, but i got the same error:
pi@raspberrypi:~/dashticz$ make start
Checking port 8082
sudo docker build --build-arg tz="Europe/Amsterdam" -t dtv3-8082 .
Sending build context to Docker daemon 90.36MB
---> fabd924a2602
---> Using cache
---> 86575eebd038
---> Running in 93f2b3260664
Makefile:49: recipe for target 'start' failed
make: *** [start] Error 139
Lokonli
Post by Lokonli »
ok. Try the following.
Create a basic Dockerfile in a new folder somewhere:
mkdir ~/test
cd ~/test
nano Dockerfile
Add the following content to Dockerfile:
FROM php:apache
RUN ls
Build the Docker container:
sudo docker build .
and post the output of the build process here.
danman87
Post by danman87 »
Hi Lokonli,
Thank you for the fast reply.
i did the steps, here the output:
pi@raspberrypi:~/test$ sudo docker build
"docker build" requires exactly 1 argument.
See 'docker build --help'.
Usage: docker build [OPTIONS] PATH | URL | -
Build an image from a Dockerfile
danman87
Post by danman87 »
a new ''make start'' turns with the same error.
Checking port 8082
---> fabd924a2602
---> Using cache
---> 86575eebd038
---> Running in 1c8a7bda7d90
myself i thought it had something to do with r/w rights, but i think i set it right allready.
Lokonli
Post by Lokonli »
Don't forget the dot behind sudo docker build .
danman87
Post by danman87 »
ahh yes, did that now.
i get this output now:
pi@raspberrypi:~/dashticz$ sudo docker build .
---> fabd924a2602
---> Using cache
---> 86575eebd038
---> Running in 8196aad9652a
it's not saying recipe for target 'start' failed anymore
Lokonli
Post by Lokonli »
Please run it in the test folder, so that the new Dockerfile that you created is being used.
danman87
Post by danman87 »
yes you are right idd. here it is:
pi@raspberrypi:~/test$ sudo docker build .
Sending build context to Docker daemon 2.048kB
---> fabd924a2602
---> Using cache
---> 86575eebd038
Step 3/4 : RUN ls
---> Running in daa77d7bec6d
The command '/bin/sh -c ls' returned a non-zero code: 139
Lokonli
Post by Lokonli »
The first real Docker command already throws an error. I've seen some reports on Docker issues.
Can you first upgrade your system with sudo update followed by sudo upgrade?
danman87
Post by danman87 »
did the upgrade with sudp apt update and sudo apt ugrade
but i get the same:
---> fabd924a2602
---> Using cache
---> 86575eebd038
Step 3/4 : RUN ls
---> Running in 6a2c9d739b54
Lokonli
Post by Lokonli »
Ok, good.
Next step is to fix Docker.
How did you install Docker: via the Dashticz auto install script, or did you install Docker yourself?
You use a raspberry pi?
danman87
Post by danman87 »
yes i think docker is not working. i installed it via the auto install script.
And yes i use an raspberry pi
danman87
Post by danman87 »
i am running on buster btw.
i started at jessie, then upgraded to stretch and then to buster.
updated domoticz to the newest version, and that is working fine.
Lokonli
Post by Lokonli »
danman87 wrote: Wednesday 15 April 2020 21:32 i am running on buster btw.
Let's check the docker apache image. What's the output of:
sudo docker images | grep apache
danman87
Post by danman87 »
ill get this now:
pi@raspberrypi:~$ sudo docker images | grep apache
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
pi@raspberrypi:~$ sudo service docker start
Job for docker.service failed because the control process exited with error code.
See "systemctl status docker.service" and "journalctl -xe" for details.
pi@raspberrypi:~$ systemctl status docker
● docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2020-04-15 21:57:27 CEST; 24s ago
Docs: https://docs.docker.com
Process: 1845 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
Main PID: 1845 (code=exited, status=1/FAILURE)
Apr 15 21:57:25 raspberrypi systemd[1]: docker.service: Failed with result 'exit-code'.
Apr 15 21:57:25 raspberrypi systemd[1]: Failed to start Docker Application Container Engine.
Apr 15 21:57:27 raspberrypi systemd[1]: docker.service: Service RestartSec=2s expired, scheduling restart.
Apr 15 21:57:27 raspberrypi systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Apr 15 21:57:27 raspberrypi systemd[1]: Stopped Docker Application Container Engine.
Apr 15 21:57:27 raspberrypi systemd[1]: docker.service: Start request repeated too quickly.
Apr 15 21:57:27 raspberrypi systemd[1]: docker.service: Failed with result 'exit-code'.
Apr 15 21:57:27 raspberrypi systemd[1]: Failed to start Docker Application Container Engine.
Lokonli
Post by Lokonli »
Sounds like a docker problem.
sudo journalctl -xe
