Konke motion Sensor / Zigate problem
Posted: Sunday 26 January 2020 10:00
by Smintyboy
I have worked the last 3 days to get my Domoticz Raspberry Pi working with the Zigate plugin. now I have 2 lamps ( Gledopto and Trafdri ) and a Konke motion Sensor connected. The lamps are working, the motion sensor not. Every time the sensor detects motion , I get the following message in the log:
2020-01-26 09:57:34.920 Status: (Zigate Zigbee) Device Annoucement ShortAddr: 3acd, IEEE: 14b457fffe077129
2020-01-26 09:57:34.925 Status: (Zigate Zigbee) Device Annoucement ShortAddr: 3acd, IEEE: 14b457fffe077129
2020-01-26 09:57:35.031 Error: (Zigate Zigbee) Decode8030 - Unknown addr mode 3a in d900023acd
2020-01-26 09:57:36.944 Error: (Zigate Zigbee) Decode8030 - Unknown addr mode 3a in db8d023acd
2020-01-26 09:57:38.985 Error: (Zigate Zigbee) Decode8030 - Unknown addr mode 3a in dd00023acd
2020-01-26 09:57:39.940 Error: (Zigate Zigbee) Decode8030 - Unknown addr mode 3a in de00023acd
2020-01-26 09:57:40.944 Error: (Zigate Zigbee) Decode8030 - Unknown addr mode 3a in df8d023acd
But The sensor doesn't turn of or on. Can somebody help me ?
thanks,
Mark
Re: Konke motion Sensor / Zigate problem
Posted: Sunday 26 January 2020 10:16
by Damsee
What is your conf : Zigate firmware ? Plugin version ? Channel used by Zigate ?
Since Konke devices have some requirements regarding the Wiki
Posted: Sunday 26 January 2020 22:13
by pipiche
@damsee is right, from the log here it seems that you have a firmware above 3.1a and on stable branche.
I strongly suggest you to move to the beta branche if you want to successfuly paired the Konke Motion sensor, or wait a bit that we push beta to stable branche.
Posted: Friday 31 January 2020 17:44
by Smintyboy
Sorry for the delay ,
zigate firmware is 3.1c and domoticz is version 4.11666. Channel is 15. Zigate plugin is latest beta version. Still not working. Domoticz sees the sensor as a door sensor. That is not correct ?
Posted: Friday 31 January 2020 19:16
by pipiche
Please do provide as an attachement the logs
Posted: Friday 31 January 2020 23:39
by pipiche
Please provide me a full log as an attachement from the start of the plugin to the time you try the pairing.
Here after is a Pairing of Konke Motion sensor, without problem
Jan 31 23:35:23 rasp domoticz[18945]: Status: (DIN Zigate) Accepting new Hardware: On
Jan 31 23:35:34 rasp domoticz[18945]: Status: (DIN Zigate) Device Announced ShortAddr: 4040, IEEE: 086bd7fffee97a6a REJOIN: 0x00 - join a network through association
Jan 31 23:35:34 rasp domoticz[18945]: (DIN Zigate) --> Adding device 4040 in self.DevicesInPairingMode
Jan 31 23:35:34 rasp domoticz[18945]: (DIN Zigate) --> ['4040']
Jan 31 23:35:35 rasp domoticz[18945]: Status: (DIN Zigate) [-] NEW OBJECT: 4040 Request Simple Descriptor for Ep: 01
Jan 31 23:35:36 rasp domoticz[18945]: Status: (DIN Zigate) [-] NEW OBJECT: 4040 Simple Descriptor EP 01
Jan 31 23:35:36 rasp domoticz[18945]: (DIN Zigate) Decode8043 - Overwrite ProfileID {} with 0104 from Ep: 01
Jan 31 23:35:36 rasp domoticz[18945]: Status: (DIN Zigate) [-] NEW OBJECT: 4040 ProfileID 0104
Jan 31 23:35:36 rasp domoticz[18945]: (DIN Zigate) Decode8043 - Overwrite ZDeviceID {} with 0402 from Ep: 01
Jan 31 23:35:36 rasp domoticz[18945]: Status: (DIN Zigate) [-] NEW OBJECT: 4040 ZDeviceID 0402
Jan 31 23:35:36 rasp domoticz[18945]: Status: (DIN Zigate) [-] NEW OBJECT: 4040 Application Version 0000
Jan 31 23:35:36 rasp domoticz[18945]: Status: (DIN Zigate) [-] NEW OBJECT: 4040 Cluster IN Count: 04
Jan 31 23:35:36 rasp domoticz[18945]: Status: (DIN Zigate) [-] NEW OBJECT: 4040 Cluster In 1: 0000 (Basic)
Jan 31 23:35:36 rasp domoticz[18945]: Status: (DIN Zigate) [-] NEW OBJECT: 4040 Cluster In 2: 0001 (Power Configuration)
Jan 31 23:35:36 rasp domoticz[18945]: Status: (DIN Zigate) [-] NEW OBJECT: 4040 Cluster In 3: 0003 (Identify)
Jan 31 23:35:36 rasp domoticz[18945]: Status: (DIN Zigate) [-] NEW OBJECT: 4040 Cluster In 4: 0500 (IAS Zone)
Jan 31 23:35:36 rasp domoticz[18945]: Status: (DIN Zigate) [-] NEW OBJECT: 4040 Cluster OUT Count: 01
Jan 31 23:35:36 rasp domoticz[18945]: Status: (DIN Zigate) [-] NEW OBJECT: 4040 Cluster Out 1: 0003 (Identify)
Jan 31 23:35:40 rasp domoticz[18945]: Status: (DIN Zigate) [0] NEW OBJECT: 4040 Request Node Descriptor
Jan 31 23:35:40 rasp domoticz[18945]: Status: (DIN Zigate) [0] NEW OBJECT: 4040 0x8043 - IAS Zone controler setting
Jan 31 23:35:45 rasp domoticz[18945]: Status: (DIN Zigate) [1] NEW OBJECT: 4040 Model Name: 3AFE14010402000D
Jan 31 23:36:15 rasp domoticz[18945]: (DIN Zigate) UpdateDevice - (DIN Zigate - Konke_Motion_Motion-086bd7fffee97a6a-01) 0:Off
Jan 31 23:37:08 rasp domoticz[18945]: (DIN Zigate) UpdateDevice - (DIN Zigate - Konke_Motion_Motion-086bd7fffee97a6a-01) 1:On
Jan 31 23:37:40 rasp domoticz[18945]: (DIN Zigate) UpdateDevice - (DIN Zigate - Konke_Motion_Motion-086bd7fffee97a6a-01) 0:Off
Jan 31 23:37:47 rasp domoticz[18945]: (DIN Zigate) UpdateDevice - (DIN Zigate - Konke_Motion_Motion-086bd7fffee97a6a-01) 1:On
Posted: Saturday 01 February 2020 11:02
by Smintyboy
Hello Pipiche,
thank you for your fast response. We are getting a little bit further. The Konke is reconized, but not as motion sensor. It gives the voltage of the battery en it signals one time movement. After that is doesn't response to anything.
2020-02-01 10:54:19.436 Status: (Zigate Zigbee) Request Accepting new Hardware for ever
2020-02-01 10:54:19.744 Status: (Zigate Zigbee) Accepting new Hardware: On
2020-02-01 10:54:26.647 (CV) Temp (Z temperatuur CV)
2020-02-01 10:54:26.659 (CV) Temp (Z temperatuur tap water)
2020-02-01 10:54:26.666 (CV) General/Text (Heater Status)
2020-02-01 10:54:35.052 (P1 meter) P1 Smart Meter (P1 vermogen)
2020-02-01 10:54:35.060 (P1 meter) General/Voltage (Voltage L1)
2020-02-01 10:54:35.066 (P1 meter) General/Voltage (Voltage L2)
2020-02-01 10:54:35.073 (P1 meter) General/Voltage (Voltage L3)
2020-02-01 10:54:35.079 (P1 meter) Usage (Usage L1)
2020-02-01 10:54:35.086 (P1 meter) Usage (Usage L2)
2020-02-01 10:54:35.092 (P1 meter) Usage (Usage L3)
2020-02-01 10:54:35.098 (P1 meter) Usage (Delivery L1)
2020-02-01 10:54:35.104 (P1 meter) Usage (Delivery L2)
2020-02-01 10:54:35.109 (P1 meter) Usage (Delivery L3)
2020-02-01 10:54:36.486 (Zigate Zigbee) --> Adding device 6773 in self.DevicesInPairingMode
2020-02-01 10:54:36.486 (Zigate Zigbee) --> ['4b96', '523b', '4b77', 'b0f8', '1715', '79c9', '6773']
2020-02-01 10:54:36.950 (Zigate Zigbee) Decode8043 - Overwrite ProfileID {} with 0104 from Ep: 01
2020-02-01 10:54:36.950 (Zigate Zigbee) Decode8043 - Overwrite ZDeviceID {} with 0402 from Ep: 01
2020-02-01 10:54:36.486 Status: (Zigate Zigbee) Device Announced ShortAddr: 6773, IEEE: 14b457fffe077129 REJOIN: 0x00 - join a network through association
2020-02-01 10:54:36.746 Status: (Zigate Zigbee) [-] NEW OBJECT: 6773 Request Simple Descriptor for Ep: 01
2020-02-01 10:54:36.950 Status: (Zigate Zigbee) [-] NEW OBJECT: 6773 Simple Descriptor EP 01
2020-02-01 10:54:36.950 Status: (Zigate Zigbee) [-] NEW OBJECT: 6773 ProfileID 0104
2020-02-01 10:54:36.950 Status: (Zigate Zigbee) [-] NEW OBJECT: 6773 ZDeviceID 0402
2020-02-01 10:54:36.950 Status: (Zigate Zigbee) [-] NEW OBJECT: 6773 Application Version 0000
2020-02-01 10:54:36.951 Status: (Zigate Zigbee) [-] NEW OBJECT: 6773 Cluster IN Count: 05
2020-02-01 10:54:36.951 Status: (Zigate Zigbee) [-] NEW OBJECT: 6773 Cluster In 1: 0000 (Basic)
2020-02-01 10:54:36.951 Status: (Zigate Zigbee) [-] NEW OBJECT: 6773 Cluster In 2: 0001 (Power Configuration)
2020-02-01 10:54:36.951 Status: (Zigate Zigbee) [-] NEW OBJECT: 6773 Cluster In 3: 0003 (Identify)
2020-02-01 10:54:36.951 Status: (Zigate Zigbee) [-] NEW OBJECT: 6773 Cluster In 4: 0500 (IAS Zone)
2020-02-01 10:54:36.951 Status: (Zigate Zigbee) [-] NEW OBJECT: 6773 Cluster In 5: fcc0
2020-02-01 10:54:36.951 Status: (Zigate Zigbee) [-] NEW OBJECT: 6773 Cluster OUT Count: 02
2020-02-01 10:54:36.951 Status: (Zigate Zigbee) [-] NEW OBJECT: 6773 Cluster Out 1: 0003 (Identify)
2020-02-01 10:54:36.951 Status: (Zigate Zigbee) [-] NEW OBJECT: 6773 Cluster Out 2: fcc0
2020-02-01 10:54:38.458 Status: (Zigate Zigbee) [0] NEW OBJECT: 6773 Request Node Descriptor
2020-02-01 10:54:38.458 Status: (Zigate Zigbee) [0] NEW OBJECT: 6773 0x8043 - IAS Zone controler setting
2020-02-01 10:54:43.445 Status: (Zigate Zigbee) [1] NEW OBJECT: 6773 Model Name: 3AFE28010402000D
2020-02-01 10:54:43.446 Status: (Zigate Zigbee) [1] NEW OBJECT: 6773 0x8043 - IAS Zone controler setting
2020-02-01 10:54:48.479 Status: (Zigate Zigbee) [2] NEW OBJECT: 6773 Model Name: 3AFE28010402000D
2020-02-01 10:54:48.479 Status: (Zigate Zigbee) [2] NEW OBJECT: 6773 0x8043 - IAS Zone controler setting
2020-02-01 10:54:53.899 (Zigate Zigbee) UpdateDevice - (Zigate Zigbee - 3AFE28010402000D_Voltage-14b457fffe077129-01) 0:30.0;30.0
2020-02-01 10:56:22.130 (Zigate Zigbee) UpdateDevice - (Zigate Zigbee - 3AFE28010402000D_Door-14b457fffe077129-01) 1:Open
Posted: Saturday 01 February 2020 11:49
by pipiche
As mentioned, could you please provide the logs from the startup of the plugin ? I need the full context on how the plugin has been started
Posted: Saturday 01 February 2020 21:57
by Smintyboy
2020-02-01 21:54:08.171 Status: (Zigate zigbee) DomoticzBuildTime: 2020-01-31 08:45:14
2020-02-01 21:54:08.171 Status: (Zigate zigbee) load PluginConf
2020-02-01 21:54:08.172 Status: (Zigate zigbee) allowRemoveZigateDevice set to 1
2020-02-01 21:54:08.173 Status: (Zigate zigbee) channel set to 15
2020-02-01 21:54:08.173 Status: (Zigate zigbee) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-06.json
2020-02-01 21:54:08.173 Status: (Zigate zigbee) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-02-01 21:54:08.173 Status: (Zigate zigbee) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2020-02-01 21:54:08.173 Status: (Zigate zigbee) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2020-02-01 21:54:08.173 Status: (Zigate zigbee) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2020-02-01 21:54:08.173 Status: (Zigate zigbee) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2020-02-01 21:54:08.173 Status: (Zigate zigbee) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2020-02-01 21:54:08.173 Status: (Zigate zigbee) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2020-02-01 21:54:08.173 Status: (Zigate zigbee) Opening DomoticzDB in raw
2020-02-01 21:54:08.184 Status: (Zigate zigbee) Plugin Database: DeviceList-6.txt
2020-02-01 21:54:08.198 Status: (Zigate zigbee) DeviceConf loaded
2020-02-01 21:54:08.200 Status: (Zigate zigbee) --> Config for SALUS/SPE600
2020-02-01 21:54:08.201 Status: (Zigate zigbee) --> Config for Legrand/Double gangs remote switch
2020-02-01 21:54:08.201 Status: (Zigate zigbee) --> Config for Legrand/Mobile outlet
2020-02-01 21:54:08.202 Status: (Zigate zigbee) --> Config for Legrand/Connected outlet
2020-02-01 21:54:08.202 Status: (Zigate zigbee) --> Config for Legrand/Cable outlet
2020-02-01 21:54:08.202 Status: (Zigate zigbee) --> Config for Legrand/Dimmer switch w/o neutral
2020-02-01 21:54:08.203 Status: (Zigate zigbee) --> Config for Legrand/Shutters central remote switch
2020-02-01 21:54:08.203 Status: (Zigate zigbee) --> Config for Legrand/Shutter switch with neutral
2020-02-01 21:54:08.203 Status: (Zigate zigbee) --> Config for Legrand/Remote switch
2020-02-01 21:54:08.204 Status: (Zigate zigbee) --> Config for Legrand/Micromodule switch
2020-02-01 21:54:08.205 Status: (Zigate zigbee) --> Config for LUMI/lumi.weather
2020-02-01 21:54:08.206 Status: (Zigate zigbee) --> Config for LUMI/lumi.sensor_86sw2
2020-02-01 21:54:08.206 Status: (Zigate zigbee) --> Config for LUMI/lumi.light.aqcn02
2020-02-01 21:54:08.206 Status: (Zigate zigbee) --> Config for LUMI/lumi.remote.b186acn01
2020-02-01 21:54:08.207 Status: (Zigate zigbee) --> Config for LUMI/lumi.sensor_magnet
2020-02-01 21:54:08.207 Status: (Zigate zigbee) --> Config for LUMI/lumi.sensor_cube.aqgl01
2020-02-01 21:54:08.207 Status: (Zigate zigbee) --> Config for LUMI/lumi.sensor_switch.aq3
2020-02-01 21:54:08.207 Status: (Zigate zigbee) --> Config for LUMI/lumi.sensor_magnet.aq2
2020-02-01 21:54:08.208 Status: (Zigate zigbee) --> Config for LUMI/lumi.sensor_cube
2020-02-01 21:54:08.208 Status: (Zigate zigbee) --> Config for LUMI/lumi.ctrl_ln2.aq1
2020-02-01 21:54:08.208 Status: (Zigate zigbee) --> Config for LUMI/lumi.remote.b1acn01
2020-02-01 21:54:08.209 Status: (Zigate zigbee) --> Config for LUMI/lumi.sen_ill.mgl01
2020-02-01 21:54:08.209 Status: (Zigate zigbee) --> Config for LUMI/lumi.sensor_switch
2020-02-01 21:54:08.209 Status: (Zigate zigbee) --> Config for LUMI/lumi.ctrl_neutral2
2020-02-01 21:54:08.210 Status: (Zigate zigbee) --> Config for LUMI/lumi.sensor_ht
2020-02-01 21:54:08.210 Status: (Zigate zigbee) --> Config for LUMI/lumi.relay.c2acn01
2020-02-01 21:54:08.210 Status: (Zigate zigbee) --> Config for LUMI/lumi.remote.b286acn01
2020-02-01 21:54:08.211 Status: (Zigate zigbee) --> Config for LUMI/lumi.sensor_wleak.aq1
2020-02-01 21:54:08.211 Status: (Zigate zigbee) --> Config for LUMI/lumi.sensor_motion
2020-02-01 21:54:08.211 Status: (Zigate zigbee) --> Config for LUMI/lumi.sensor_smoke
2020-02-01 21:54:08.212 Status: (Zigate zigbee) --> Config for LUMI/lumi.ctrl_ln2
2020-02-01 21:54:08.212 Status: (Zigate zigbee) --> Config for LUMI/lumi.sensor_motion.aq2
2020-02-01 21:54:08.212 Status: (Zigate zigbee) --> Config for LUMI/lumi.ctrl_neutral1
2020-02-01 21:54:08.212 Status: (Zigate zigbee) --> Config for LUMI/lumi.vibration.aq1
2020-02-01 21:54:08.213 Status: (Zigate zigbee) --> Config for LUMI/lumi.sensor_86sw1
2020-02-01 21:54:08.213 Status: (Zigate zigbee) --> Config for LUMI/lumi.sensor_switch.aq2
2020-02-01 21:54:08.214 Status: (Zigate zigbee) --> Config for IKEA_TRADFRI/TRADFRI control outlet
2020-02-01 21:54:08.214 Status: (Zigate zigbee) --> Config for IKEA_TRADFRI/TRADFRI bulb E27 WS clear 950lm
2020-02-01 21:54:08.215 Status: (Zigate zigbee) --> Config for IKEA_TRADFRI/FLOALT panel WS 60x60
2020-02-01 21:54:08.215 Status: (Zigate zigbee) --> Config for IKEA_TRADFRI/TRADFRI bulb E14 WS opal 400lm
2020-02-01 21:54:08.215 Status: (Zigate zigbee) --> Config for IKEA_TRADFRI/TRADFRI remote control
2020-02-01 21:54:08.216 Status: (Zigate zigbee) --> Config for TUYA/TS0012
2020-02-01 21:54:08.216 Status: (Zigate zigbee) --> Config for TUYA/TS0013
2020-02-01 21:54:08.216 Status: (Zigate zigbee) --> Config for TUYA/TS0011
2020-02-01 21:54:08.217 Status: (Zigate zigbee) --> Config for LIVOLO/TI0001
2020-02-01 21:54:08.217 Status: (Zigate zigbee) --> Config for Heiman/SmokeSensor-N
2020-02-01 21:54:08.218 Status: (Zigate zigbee) --> Config for Heiman/SmokeSensor-N-3.0
2020-02-01 21:54:08.218 Status: (Zigate zigbee) --> Config for Heiman/SMOK_V16
2020-02-01 21:54:08.218 Status: (Zigate zigbee) --> Config for Heiman/GAS_V15
2020-02-01 21:54:08.219 Status: (Zigate zigbee) --> Config for Schneider/EH-ZB-SPD-V2
2020-02-01 21:54:08.220 Status: (Zigate zigbee) --> Config for Schneider/EH-ZB-HACT
2020-02-01 21:54:08.220 Status: (Zigate zigbee) --> Config for Schneider/EH-ZB-RTS
2020-02-01 21:54:08.221 Status: (Zigate zigbee) --> Config for Schneider/EH-ZB-BMS
2020-02-01 21:54:08.221 Status: (Zigate zigbee) --> Config for OSRAM/Plug Z3
2020-02-01 21:54:08.222 Status: (Zigate zigbee) --> Config for OSRAM/LIGHTIFY Outdoor Flex RGBW
2020-02-01 21:54:08.222 Status: (Zigate zigbee) --> Config for OSRAM/CLA60 TW OSRAM
2020-02-01 21:54:08.222 Status: (Zigate zigbee) --> Config for OSRAM/Plug 01
2020-02-01 21:54:08.223 Status: (Zigate zigbee) --> Config for OSRAM/Lightify Switch Mini
2020-02-01 21:54:08.223 Status: (Zigate zigbee) --> Config for Others/FB56-ZCW08KU1.1
2020-02-01 21:54:08.224 Status: (Zigate zigbee) --> Config for Konke/3AFE140103020000
2020-02-01 21:54:08.224 Status: (Zigate zigbee) --> Config for Konke/3AFE170100510001
2020-02-01 21:54:08.225 Status: (Zigate zigbee) --> Config for Philips/SML002
2020-02-01 21:54:08.225 Status: (Zigate zigbee) --> Config for Philips/SML001
2020-02-01 21:54:08.226 Status: (Zigate zigbee) --> Config for Philips/RWL021
2020-02-01 21:54:08.226 Status: (Zigate zigbee) --> Config for Philips/LST002
2020-02-01 21:54:08.227 Status: (Zigate zigbee) --> Config for CLEODE/ZMOVE
2020-02-01 21:54:08.227 Status: (Zigate zigbee) --> Config for CLEODE/ZPLUG
2020-02-01 21:54:08.227 Status: (Zigate zigbee) --> Config for CLEODE/ZHUM
2020-02-01 21:54:08.228 Status: (Zigate zigbee) --> Config for Eurotronics/SPZB0001
2020-02-01 21:54:08.228 Status: (Zigate zigbee) load ListOfDevice
2020-02-01 21:54:08.271 Status: (Zigate zigbee) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-6.txt : 4
2020-02-01 21:54:08.274 Status: (Zigate zigbee) Transport mode: USB
2020-02-01 21:54:08.276 Status: (Zigate zigbee) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
2020-02-01 21:54:08.276 Status: (Zigate zigbee) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2020-02-01 21:54:08.287 Status: (Zigate zigbee) Configure Permit To Join
2020-02-01 21:54:08.287 Status: (Zigate zigbee) Request Accepting new Hardware for 254 seconds
2020-02-01 21:54:08.287 Status: (Zigate zigbee) Trigger a Topology Scan
2020-02-01 21:54:08.288 Status: (Zigate zigbee) Trigger a Energy Level Scan
2020-02-01 21:54:08.389 Status: (Zigate zigbee) Major Version Num: 0003
2020-02-01 21:54:08.389 Status: (Zigate zigbee) Installer Version Number: 031c
2020-02-01 21:54:08.897 Status: (Zigate zigbee) Accepting new Hardware: On
2020-02-01 21:54:09.016 Status: (Zigate zigbee) Zigate addresses ieee: 00158d00021e2c61 , short addr: 0000
2020-02-01 21:54:09.016 Status: (Zigate zigbee) Network state UP, PANID: 02be extPANID: 0xd1bc6a91efdaa555 Channel: 15
2020-02-01 21:54:09.124 Status: (Zigate zigbee) Number of devices recently active in Zigate = 3
2020-02-01 21:54:18.198 (Zigate zigbee) Switch Blue Led On
2020-02-01 21:54:18.199 Status: (Zigate zigbee) Zigate set to Certification : CE
2020-02-01 21:54:18.229 Status: (Zigate zigbee) Start Web Server connection
2020-02-01 21:54:18.265 Status: (Zigate zigbee) Web backend for Web User Interface started on port: 9440
2020-02-01 21:54:18.265 Status: (Zigate zigbee) Plugin with Zigate firmware 031c correctly initialized
2020-02-01 21:54:18.632 Status: (Zigate zigbee) TxPower Attenuation : 0 dBm
2020-02-01 21:54:33.875 (Zigate zigbee) --> Adding device ca91 in self.DevicesInPairingMode
2020-02-01 21:54:33.875 (Zigate zigbee) --> ['ca91']
2020-02-01 21:54:33.874 Status: (Zigate zigbee) Device Announced ShortAddr: ca91, IEEE: 14b457fffe077129 REJOIN: 0x02 - joining the network using the NWK rejoining procedure.
2020-02-01 21:54:33.980 Status: (Zigate zigbee) [-] NEW OBJECT: ca91 Request Simple Descriptor for Ep: 01
2020-02-01 21:54:34.385 (Zigate zigbee) Decode8043 - Overwrite ProfileID {} with 0104 from Ep: 01
2020-02-01 21:54:34.385 (Zigate zigbee) Decode8043 - Overwrite ZDeviceID {} with 0402 from Ep: 01
2020-02-01 21:54:34.973 (CV) General/Text (Heater Status)
2020-02-01 21:54:34.385 Status: (Zigate zigbee) [-] NEW OBJECT: ca91 Simple Descriptor EP 01
2020-02-01 21:54:34.385 Status: (Zigate zigbee) [-] NEW OBJECT: ca91 ProfileID 0104
2020-02-01 21:54:34.385 Status: (Zigate zigbee) [-] NEW OBJECT: ca91 ZDeviceID 0402
2020-02-01 21:54:34.385 Status: (Zigate zigbee) [-] NEW OBJECT: ca91 Application Version 0000
2020-02-01 21:54:34.385 Status: (Zigate zigbee) [-] NEW OBJECT: ca91 Cluster IN Count: 05
2020-02-01 21:54:34.385 Status: (Zigate zigbee) [-] NEW OBJECT: ca91 Cluster In 1: 0000 (Basic)
2020-02-01 21:54:34.386 Status: (Zigate zigbee) [-] NEW OBJECT: ca91 Cluster In 2: 0001 (Power Configuration)
2020-02-01 21:54:34.386 Status: (Zigate zigbee) [-] NEW OBJECT: ca91 Cluster In 3: 0003 (Identify)
2020-02-01 21:54:34.386 Status: (Zigate zigbee) [-] NEW OBJECT: ca91 Cluster In 4: 0500 (IAS Zone)
2020-02-01 21:54:34.386 Status: (Zigate zigbee) [-] NEW OBJECT: ca91 Cluster In 5: fcc0
2020-02-01 21:54:34.386 Status: (Zigate zigbee) [-] NEW OBJECT: ca91 Cluster OUT Count: 02
2020-02-01 21:54:34.386 Status: (Zigate zigbee) [-] NEW OBJECT: ca91 Cluster Out 1: 0003 (Identify)
2020-02-01 21:54:34.386 Status: (Zigate zigbee) [-] NEW OBJECT: ca91 Cluster Out 2: fcc0
2020-02-01 21:54:38.203 Status: (Zigate zigbee) [0] NEW OBJECT: ca91 Request Node Descriptor
2020-02-01 21:54:38.203 Status: (Zigate zigbee) [0] NEW OBJECT: ca91 0x8043 - IAS Zone controler setting
2020-02-01 21:54:42.211 Status: (Zigate zigbee) (ca91/14b457fffe077129) send a Leave indication and will be outside of the network
2020-02-01 21:54:43.213 Status: (Zigate zigbee) [1] NEW OBJECT: ca91 Model Name: 3AFE28010402000D
2020-02-01 21:54:43.214 Status: (Zigate zigbee) [1] NEW OBJECT: ca91 0x8043 - IAS Zone controler setting
2020-02-01 21:54:43.775 Status: (Zigate zigbee) Device Announced ShortAddr: 5f1f, IEEE: 14b457fffe077129 REJOIN: 0x00 - join a network through association
2020-02-01 21:54:43.979 Status: (Zigate zigbee) Device Announced ShortAddr: 5f1f, IEEE: 14b457fffe077129 REJOIN:
2020-02-01 21:54:43.775 Error: (Zigate zigbee) Decode004d - New Device 5f1f 14b457fffe077129 already exist in IEEE2NWK
2020-02-01 21:54:43.979 Error: (Zigate zigbee) Decode004d - New Device 5f1f 14b457fffe077129 already exist in IEEE2NWK
2020-02-01 21:54:48.195 Status: (Zigate zigbee) [2] NEW OBJECT: ca91 Model Name: 3AFE28010402000D
2020-02-01 21:54:48.196 Status: (Zigate zigbee) [2] NEW OBJECT: ca91 0x8043 - IAS Zone controler setting
Posted: Saturday 01 February 2020 22:50
by pipiche
I do not see any errors in this last logs and the Model Name : 3AFE14010402000D was correctly discovered and so the proper Widget should have been created.
The only issue is a reset happen during the discovery process whcih might create some issue in some settings.
Posted: Monday 17 February 2020 9:05
by Smintyboy
I tried several new pairings , but everytime it connects as a door sensor and not as a motion sensor. The distance between the zigate and the sensor is only 10 cm, so there shouldn't be any communication problems. Can I try something else ? I have the latest beta version.
Posted: Monday 17 February 2020 9:07
by pipiche
Smintyboy wrote: Monday 17 February 2020 9:05
Please provide Logs, without we cannot really help
Posted: Monday 17 February 2020 14:01
by Smintyboy
2020-02-17 13:54:20.159 (Zigate) Start Network status : Success
2020-02-17 13:54:20.158 Status: (Zigate) Start Network: Node is on network. ZiGate is already in network so network is already format
2020-02-17 13:54:20.158 Status: (Zigate) Zigate details IEEE: 00158d00021e2c61, NetworkID: 0000, Channel: 15, Status: 04: Start Network: Node is on network. ZiGate is already in network so network is already format
2020-02-17 13:54:20.261 Status: (Zigate) Accepting new Hardware: Disable
2020-02-17 13:54:20.363 Status: (Zigate) Zigate addresses ieee: 00158d00021e2c61 , short addr: 0000
2020-02-17 13:54:20.363 Status: (Zigate) Network state UP, PANID: b5bd extPANID: 0x8d8bdf7452cdc61c Channel: 15
2020-02-17 13:54:31.265 (Zigate) Receive NACK from 7c13 clusterId: 0006
2020-02-17 13:54:31.367 (Zigate) Receive NACK from 7c13 clusterId: 0008
2020-02-17 13:54:43.957 Status: (Zigate) Request Disabling Accepting new Hardware
2020-02-17 13:54:45.168 Status: (Zigate) Request Accepting new Hardware for ever
2020-02-17 13:54:45.475 Status: (Zigate) Accepting new Hardware: On
2020-02-17 13:55:03.693 (Zigate) --> Adding device 3f73 in self.DevicesInPairingMode
2020-02-17 13:55:03.694 (Zigate) --> ['3f73']
2020-02-17 13:55:03.693 Status: (Zigate) Device Announcement Addr: 3f73, IEEE: 14b457fffe077129 Join Flag: 0x00 - join a network through association RSSI: 0
2020-02-17 13:55:04.052 Status: (Zigate) [-] NEW OBJECT: 3f73 Active Endpoint Response Ep: 01 RSSI: 156
2020-02-17 13:55:04.052 Status: (Zigate) [-] NEW OBJECT: 3f73 Request Simple Descriptor for Ep: 01
2020-02-17 13:55:04.154 Status: (Zigate) [-] NEW OBJECT: 3f73 Simple Descriptor Response EP: 0x01 RSSI: 111
2020-02-17 13:55:04.155 Status: (Zigate) [-] NEW OBJECT: 3f73 ProfileID 0104
2020-02-17 13:55:04.155 Status: (Zigate) [-] NEW OBJECT: 3f73 ZDeviceID 0402
2020-02-17 13:55:04.155 Status: (Zigate) [-] NEW OBJECT: 3f73 Application Version 0000
2020-02-17 13:55:04.155 Status: (Zigate) [-] NEW OBJECT: 3f73 Cluster IN Count: 05
2020-02-17 13:55:04.155 Status: (Zigate) [-] NEW OBJECT: 3f73 Cluster In 1: 0000 (Basic)
2020-02-17 13:55:04.155 Status: (Zigate) [-] NEW OBJECT: 3f73 Cluster In 2: 0001 (Power Configuration)
2020-02-17 13:55:04.155 Status: (Zigate) [-] NEW OBJECT: 3f73 Cluster In 3: 0003 (Identify)
2020-02-17 13:55:04.155 Status: (Zigate) [-] NEW OBJECT: 3f73 Cluster In 4: 0500 (IAS Zone)
2020-02-17 13:55:04.155 Status: (Zigate) [-] NEW OBJECT: 3f73 Cluster In 5: fcc0
2020-02-17 13:55:04.155 Status: (Zigate) [-] NEW OBJECT: 3f73 Cluster OUT Count: 02
2020-02-17 13:55:04.156 Status: (Zigate) [-] NEW OBJECT: 3f73 Cluster Out 1: 0003 (Identify)
2020-02-17 13:55:04.156 Status: (Zigate) [-] NEW OBJECT: 3f73 Cluster Out 2: fcc0
2020-02-17 13:55:04.409 Status: (Zigate) [0] NEW OBJECT: 3f73 Request Node Descriptor
2020-02-17 13:55:04.410 Status: (Zigate) [0] NEW OBJECT: 3f73 0x8043 - IAS Zone controler setting
2020-02-17 13:55:09.398 Status: (Zigate) [1] NEW OBJECT: 3f73 Model Name: 3AFE28010402000D
2020-02-17 13:55:09.398 Status: (Zigate) [1] NEW OBJECT: 3f73 0x8043 - IAS Zone controler setting
2020-02-17 13:55:14.434 (Zigate) WARNING - ZigateCmd: 0140 023f730101fcc0000000000000FF ZigateQueue: 16
2020-02-17 13:55:14.418 Status: (Zigate) [2] NEW OBJECT: 3f73 Model Name: 3AFE28010402000D
2020-02-17 13:55:14.418 Status: (Zigate) [2] NEW OBJECT: 3f73 0x8043 - IAS Zone controler setting
2020-02-17 13:55:26.319 (Zigate) UpdateDevice - (Zigate - 3AFE28010402000D_Voltage-14b457fffe077129-01) 0:30.0;30.0
2020-02-17 13:57:13.970 (Zigate) UpdateDevice - (Zigate - 3AFE28010402000D_Door-14b457fffe077129-01) 1:Open
Posted: Monday 17 February 2020 14:37
by pipiche
Thanks very much for those information. Looks like the Konke motion sensor is coming with a new Model Name.
Please do update the beta branch to get the latest update and then you can redo the pairing
Posted: Monday 17 February 2020 15:57
by Smintyboy
it is working, thank you
Posted: Monday 17 February 2020 16:11
by pipiche
Thanks to you for your patience
