Having the following situtation. (new here!)
Having a domoticz setup running for a couple of years on Raspberry Pi. Aeotec Z-Stick Gen5.
Now installing a Fibaro FGS 222 Relay 2x1.5 relay switch behind a Jung 225 NVDE.
Works. Installed it with the schema in the manual.
Butttt, they don't dim.
So i would like to have it in a sort of 2 way switch setup. (hotelschakeling in dutch).
http://jung.in.ua/images/passp/225NVDE-4.gif
But i don't know how to this with the Fibaro.
I did try to connect the lamp to the Jung, connect the left side of the Jung to a brown wire. And connecting the right side of the Jung to the Q1 of the fibaro.
S1 is empty, the rest is as described in the manual (2 browns + 1 blue).
But no luck, light turns on in both ways, but turning it off physically. The fibaro turns it on automatically.
I also played a bit with the settings in Domoticz (toggle/ bi-directional etc).
Can it be done? Or should i give up?
Fibaro FGS 222 together with Jung Dimmer
AthomeDomotica
- Domoticz version: 2022.2
Re: Fibaro FGS 222 together with Jung Dimmer
Hello, here the manual for the Fibaro; https://manuals.fibaro.com/double-relay-switch/
I think you need the dimmer version of Fibaro, maybe I'am wrong https://manuals.fibaro.com/dimmer-2/
You could always place a question to https://www.fibaro.com/en/contact/
Cheers,
MIke
Cheers,
MIke
Domoticz, Controlicz, Philips HUE Gateway and bulbs, Z-Wave (Aecotec Stick) and Fibaro Dimmers, RFLink Gateway.
