Selector switch not sending correct actions
Posted: Friday 24 January 2020 18:43
I have previously configured selector switches to successfully select Fibaro RGBW controller programs, and after creating a new instance of Domoticz the selector switch no longer performs as one might expect. Regardless of which level (action) is selected the same string is sent, with this not reflecting what has actually been configured in each of the selector action levels. The string contains the switch IDX and the set level command, and in no way reflects what should be sent.
Despatched string: http://192.168.0.7:8080/json.htm?type=c ... &passcode=
So, what am I doing wrong ?
