Dashticz - v3.3.3 Master
Posted: Wednesday 22 January 2020 20:43
by Lokonli
I've just published Dashticz v3.3.3 master.
Main reason is the bugfix for recurring events in the calendar blocks.
I've migrated to a new PHP ical parser library, which is more up-to-date. This library however requires PHP 7.1 (or higher).
I expect that this will be no issue for most users. If you are still using PHP5, and you can't update to PHP7, then please leave a note here, and I will look for an alternative solution.
The automatic installation scripts uses PHP7 in the Docker image, so that should work without issues.
Re: Dashticz - v3.3.3 Master
Posted: Friday 24 January 2020 5:56
by HansieNL
The version on Raspbian Stretch is still PHP 7.0
Haven’t find a solution yet to get PHP > 7.0 running on Pi without an upgrade to Buster.
Don’t know if more people are still running Stretch on the Raspberry Pi?
Posted: Friday 24 January 2020 10:06
by Lokonli
HansieNL wrote: Friday 24 January 2020 5:56
hmm, that's indeed an issue.
Can you switch to the automatic install option? That would solve it I expect.
Alternative:
What I could do is add the previous ical parser library as well. I was able to patch the recurring events issue. However, the yearly recurring events didn't work properly, and that was a bit too difficult to debug.
So that means you will see incorrect or no yearly recurring events (birthdays etc.). Would that be acceptable?
Posted: Friday 24 January 2020 14:20
by HansieNL
Adding the previous iCal parser would be great. Then I can keep using my current webserver.
Posted: Tuesday 28 January 2020 15:31
by gielie
I have a lot of problems with my Domoticz on Buster, this is the reason im still using Stretch. Is there a workaround?
Posted: Tuesday 28 January 2020 22:11
by Lokonli
gielie wrote: Tuesday 28 January 2020 15:31
I've restored the PHP5 compatible ical library next to the new PHP7.1 library in the latest beta 3.3.5.
