Master v3.3.2 has just been released.
This release contains some breaking changes compared to the previous master v3.1.2.
Most important: In your button definitions you have to rename 'image' to 'btnimage'
For additional update remarks read:
https://dashticz.readthedocs.io/en/mast ... /v320.html
Some highlights of this release:
* Standardization of the html template for most special blocks
* Slider can be enabled on mobile devices
* Improved security panel
* Evohome support
And several fixes.
For the full list of changes check:
https://dashticz.readthedocs.io/en/mast ... ease-notes
v3.3.2 master
Rob67ert
Re: v3.3.2 master
I did a update, it works on my desktop browser.
Bit I get a black screen on my LCD (800x480)
This worked great before.
This is what I have in my CONFIG.js:
screens[max_resolution_tablet] = {}
screens[max_resolution_tablet]['maxwidth'] = 800;
screens[max_resolution_tablet]['maxheight'] = 480;
If i change the value of the screen size to 1920 by 1080 it works on my desktop browser.
Anyone know how I can fix this?
Lokonli
Re: v3.3.2 master
I'll check.
Lokonli
Re: v3.3.2 master
I've tested, but I don't see any issue.Rob67ert wrote: Sunday 19 January 2020 12:27 I did a update, it works on my desktop browser.
I guess your LCD is not connected to your desktop. To what kind of device is your LCD connected?
You might have to refresh your browser cache.
I assume you have defined max_resolution_tablet in your CONFIG.js?
If you still have problems, can you post your CONFIG.js?
Rob67ert
Re: v3.3.2 master
@Lokoni
I have the raspberry Pi LCD connected to the dsi port.
Did some tests, I had more screen config in the CONFIG.js file. When I only have one it works correct.
Guess it has to do with finding the correct window size.
