Zigbee2mqtt firmware reflash
EddyG
Post by EddyG »
I am using firmware Z-Stack_Home_1.2 (20190608) with a CC2531
I would like to use the Z-Stack_Home_1.2 (source_routing 20190619) for the same CC2531
Can I flash the CC2531 without losing the network settings? Or do I have to include all the devices again?
jake
Re: Zigbee2mqtt firmware reflash
Post by jake »
I reflashed it once and I lost my (only one) Ikea light bulb. When I disconnected the lamp from power and put it back in again, it paired again with the stick.
Your network settings are stored on the pi, not on the stick
EddyG
Post by EddyG »
I reflashed the CC2531 and it worked. All devices are still there and working. :)
ben53252642
Post by ben53252642 »
EddyG I recently upgraded to a CC2652R. suggest you look into it.
In my opinion there is a noticeable improvement in device responsiveness and definitely range.
Supports 50 direct children and about 200 total devices.
EddyG
Post by EddyG »
I think I will go for the CC1352P-2 because it has a connection for external antenna.
My Wifi router is close to my raspberry pi setup with the CC2531, and that is not good.
With the CC1352P-2 I can put the antenna further away.
But I do that when Zigbee 3.0 is stable. What is the current status of Zigbee 3.0 with zigbee2mqtt?
ben53252642
I think you mean Zigbee 3.1?
As far as my experience, my home has been fully working on a CC2652 with zero issues for about a week.
https://github.com/Koenkk/Z-Stack-firmw ... oordinator
EddyG
Post by EddyG »
Tnx, I mean https://github.com/Koenkk/Z-Stack-firmw ... oordinator 3th column
I order one and see how it goes.
