Zigbee2mqtt not showing in hardware type
pedemo
- Domoticz version: V 2020.2
I've a flashed CC2531 stick, installed zigbee2mqtt and python plugin on a domoticz@RPi2.
So far so good but I get stuck on the following:
On Domoticz 》hardware I want to select zigbee2mqtt but there's no zigbee type to selected.
What am I doing wrong?
- FireWizard
pedemo
Re: Zigbee2mqtt not showing in hardware type
Yes but it did 't read a solution
- FireWizard
Then just a simple question.
Did you tick the box in Setup > Settings > System > Accept new Hardware Devices.
Or clicked Allow for 5 minutes?
pedemo
I did both
- waaren
After installing a new python plugin a domoticz restart is required. If you already restarted domoticz after the installation of the plugin and still do not see the new plugin as one of the hardware choices when adding a new one, it might be a cache problem.
Please clear cache and appcache (different things) and try again
pedemo
I've tried it on a another RPi (3B+) but with the same result (nothing showed up hardware type). Could it be a defect on the CC2531 stick? How can I check it
pedemo
I solved it and the solution was here (where it always was but I simply ignored it because I thought python was completely installed .... NOT)
https://www.domoticz.com/forum/viewtopi ... pe#p207816
"After running: sudo apt-get install python3-dev everything works fine and Zigbee2MQTT is available in the hardware-types."
Mardie
- Domoticz version: 4.10717
hi, on your youtube chanel, i see it is possible to pair without havint to edit the configuration.yaml file. (you have got a switch wich enables it at the hardware page). How do you get that button. The present plugin does not show this switch.
I had a Similar problem after installing python3-dev zigbee2mqtt plugin start working but in the log i get a error
Offcourse this has something to do with python path envirement but i don't know how to fix this. My knowledge of linux isn't that great!
Any advice would be great.
I'm running domoticz from ubuntu as of zigbee2mqtt
2021-10-14 02:11:34.127 Error: Zigbee2Mqtt: (Zigbee2MQTT) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/zigbee2mqtt/:/usr/lib/python38.zip:/usr/lib/python3.8:/usr/lib/python3.8/lib-dynload:/usr/local/lib/python3.8/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.8/dist-packages'.Any advice would be great.
- Dnpwwo
Did you install it using 'sudo'?
yes installed zigbee with sudo ... after that i removed domoticz and installed also with sudo.
