Problem Homekit / Homebridge / IOS Shortcuts
Posted: Tuesday 14 January 2020 16:30
I'm have several switches mapped via homebridge / homebridge-edomaticz and mqtt from Domoticz to Home / EVE on my Iphone (IOS 13.3) For Domoticz on my pi I use the last stable version, all pakets are up to date. Mapping with homebridge works. I change a switch in Domoticz and it is changed immediateley in Home, vice versa.
Now I created a shortcut, which changes a specific home switch to on and waits for 30 seconds. Works correct, switch is switched on in Domoticz. The shortcut waits. In the meantime I switch the switch off in Domoticz and it is not changed in homekit. It seems, that if the switch is used in a shortcut, it is locked or anything else. Can anyone verify this and has perhaps a workaround. I can't use this in this way, because I have non correspondig states. Thanks a lot.
