Zigate settings
tjabas
Zigate settings
Post by tjabas »
Hi!
i have been adding alot of zigbee devices to my zigate on my rpi3, i have about 30 devices, mostly Aqara sensors and some Ikea trådfri switches and repeaters, but now i am getting some problems, some of the paired devices suddenly disapears after i make a reboot of the rpi, its both the Aqara and Trådfri that disapears, it seems like its the once the are further away from the Zigate, i have to include them again after a reboot.
any suggestion of why it behaves like that?
im using channel 15 on the zigate, should i acitvate polling?
and should i activate OTA in Zigate plugin? does the latest firmware always get installed without any problems?
thanks in advance
pipiche
Re: Zigate settings
Post by pipiche »
Please check the wiki , you should find info there.
https://github.com/pipiche38/Domoticz-Z ... nf.json.md
As regards to your channel for zigbee you need to see what is WiFi 2.4 channel to avoid overlap
https://github.com/pipiche38/Domoticz-Z ... -Zigbee.md
tjabas
Re: Zigate settings
Post by tjabas »
pipiche wrote: Monday 13 January 2020 8:01 Please check the wiki , you should find info there.
thanks for your answer.
i have looked at the github link and there are alot of parameters that i cant find in the webpage for the Zigate, theres ony a few of the settings avalible and i have activated advanced settings.
Damsee
Domoticz version: 4.10717
Re: Zigate settings
Post by Damsee »
Since you're using Zigate on channel 15, it should be better to set your Wifi 2.4Ghz on channel 11 to avoid signal interferences.
You can check the signal overlapping here : https://github.com/pipiche38/Domoticz-Z ... -Zigbee.md
Regarding the Zigate plugin settings, there are :
- Settings available through Domoticz under Settings > Hardware > Your Zigate ID with few parameters but available whatever your version of DZ/Plugin,
- Many more settings available through the Plugin Web Admin Interface as described here : https://github.com/pipiche38/Domoticz-Z ... -Zigbee.md
Regarding that last option (Web Admin Interface), you can have more info here : https://github.com/pipiche38/Domoticz-Z ... terface.md
=> Domoticz mini 4.10900
=> Zigate Plugin mini 4.4
Hope that helps ;)
RPI3 Raspbian Buster + Domoticz v2020.1 stable + RFXtrx433E + Z-Stick Gen5 + Amazon Echo (alexicz)
x5 THGN810 / x5 ZMNHJD1 / x2 Flood sensor FGFS101 / x1 Smoke sensor FGSD002
x1 ZMNHAD1 / x2 FGS213 / x3 Wallplug FGWPE/F / NodOn Soft remote CRC-3-6-0
tjabas
Re: Zigate settings
Post by tjabas »
thank you very much :)
