For those who don't specifically need the functionality of their Nest or other thermostat, but basically use their thermostat as a on/off switch for the heater based on other temperature readings done by Domoticz:
Take a look at the Shelly 1 smart switch (https://shop.shelly.cloud/shelly-1-wifi ... omation#50). It features separated dry contacts, which can by used to switch your heating on/off, while the Shelly itself is powered by 12v/120v/220v (I currently use 200v, haven't tested the others, so use at your own risk!).
It can be flashed with Tasmota, so it will communicate with Domoticz through MQTT.
Replace Nest/thermostat by smart switch
