Zigate - Xiaomi Aqara Smoke sensor: Trigger an alarm from Domoticz
Geitje
Post by Geitje »
If I understand correctly, the communication between Zigate and Xiaomi Aqara Smoke Sensors is largely one-way: Only if a sensor is alarming, then Domoticz is triggered. Domoticz itself cannot trigger an alarm at the sensor. This way, sensors cannot be linked to each other without using the hub. When there is a fire, only one smoke sensor will sound the alarm, the others remain silent.
Is there a way to be able to make Domoticz trigger an alarm? This way all sensors can sound the alarm if one is sensing smoke. I prefer not to use the Aqara hub to link the sensors. If possible I will remain out of that cloud.
Zwave, Zigate, RFlink etc.
pipiche
Re: Zigate - Xiaomi Aqara Smoke sensor: Trigger an alarm from Domoticz
Post by pipiche »
Those devices are battery based and indeed are only one way , except during the pairing process.
Geitje
Post by Geitje »
Thanks for your reply. In theory 2-way communication must be possible, since the aqara hub also does this?
Edit: did some research: check out: https://github.com/Koenkk/zigbee2mqtt/issues/420
The alarm package the hub sends to the other sensors is not found after some months yet. Such a shame....
I will reconsider the hub after all...
pipiche
Post by pipiche »
The only way to find what the Hub is doing is to sniff the traffic. But I don’t have it.
So indeed better that you go for the hub if you look for such feature
marktn
Post by marktn »
Is it possible to see the status of the smoke detector?
In Zigate it is alive, but in domoticz it is offline.
The only way to see if the smoke detector is online in domoticz is by pushing the test button.
What i want is, that i can see if it is online in domoticz, and when off line or low battery it gives a warning.
Best regards,
Mark
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
pipiche
Post by pipiche »
Don’t you have the battery level in Domoticz device list ? Don’t you have the last seen updated ?
marktn
Post by marktn »
pipiche wrote: Wednesday 02 December 2020 22:28 Don’t you have the battery level in Domoticz device list ? Don’t you have the last seen updated ?
I do see the battery level, but it is new, I am not sure if that is up to date or working.
And no, I don't have the last seen update in Domoticz.
I want to be sure that it is alive in Domoticz.
Mark
pipiche
Post by pipiche »
Can you go to the Web Ui --> Tools -> Plugin Devices RAW (json) do an export and drop the export here ?
marktn
Post by marktn »
pipiche wrote: Thursday 03 December 2020 10:45 Can you go to the Web Ui --> Tools -> Plugin Devices RAW (json) do an export and drop the export here ?
Yes, this is what you need?
On the date 1-12-2020 i did a manual test.
[{"App Version":"36","Battery":"","ConsistencyCheck":"ok","DeviceType":"FFD","Ep":[{"ClusterList":[{"0010":"Binary Output (Basic)"},{"0006":"On/Off"},{"0004":"Groups"},{"0005":"Scenes"}],"Ep":"02"},{"ClusterList":[{"000a":"Time"},{"000c":"Analog Input (basic)"},{"0000":"Basic"},{"0002":"Unknown"},{"0001":"Power Configuration"},{"0005":"Scenes"},{"0010":"Binary Output (Basic)"},{"0006":"On/Off"},{"0b04":"Electrical Measurement"},{"0405":"Relative Humidity Measurement"},{"0019":"Over-the-Air Upgrade"},{"0004":"Groups"},{"0003":"Identify"},{"0008":"Level Control"}],"Ep":"01"}],"HW Version":"18","Health":"Not Reachable","IEEE":"00158d000444e9e3","LastCmds":[{"CmdCode":"0100","TimeStamps":"02/12/2020 21:30:02"},{"CmdCode":"0100","TimeStamps":"02/12/2020 21:30:02"},{"CmdCode":"0100","TimeStamps":"02/12/2020 21:30:02"},{"CmdCode":"0100","TimeStamps":"02/12/2020 21:30:02"},{"CmdCode":"0100","TimeStamps":"02/12/2020 21:30:02"}],"LastSeen":"28/11/2020 13:05:42","LogicalType":"Router","Manufacturer":"1037","Model":"lumi.relay.c2acn01","PowerSource":"Main","ProfileID":"0104","RSSI":108,"ReceiveOnIdle":"On","Stack Version":"2","Stamp":{"LastSeen":"28/11/2020 13:05:42","MsgType":"8011","Time":"2020-12-02 21:30:08"},"Status":"inDB","Type":"Switch","WidgetList":[{"WidgetName":"$Bewatering achter Planten handmatig","WidgetType":"Switch","_WidgetID":"4547"},{"WidgetName":"$Bewatering achter Haag handmatig","WidgetType":"Switch","_WidgetID":"4546"}],"ZDeviceID":"0101","ZDeviceName":"Water schakelaar tuin achter","_NwkId":"cf42"},{"App Version":"3","Battery":59,"ConsistencyCheck":"ok","DeviceType":"","Ep":[{"ClusterList":[{"0006":"On/Off"},{"ffff":"Unknown"},{"0000":"Basic"},{"0001":"Power Configuration"},{"0003":"Identify"}],"Ep":"01"}],"HW Version":"","Health":"Live","IEEE":"00158d0004096d67","LastCmds":[{"CmdCode":"0120","TimeStamps":"21/02/2020 20:14:55"},{"CmdCode":"0120","TimeStamps":"21/02/2020 20:14:55"},{"CmdCode":"0100","TimeStamps":"21/02/2020 20:14:55"},{"CmdCode":"0100","TimeStamps":"21/02/2020 20:14:55"},{"CmdCode":"0100","TimeStamps":"21/02/2020 20:14:55"}],"LastSeen":"03/12/2020 18:04:24","LogicalType":"","Manufacturer":"","Model":"lumi.sensor_magnet.aq2","PowerSource":"","ProfileID":"","RSSI":114,"ReceiveOnIdle":"","Stack Version":"","Stamp":{"LastSeen":"03/12/2020 18:04:24","MsgType":"8102","Time":"2020-12-03 18:04:38"},"Status":"inDB","Type":"Door","WidgetList":[{"WidgetName":"Deur_woonkamer","WidgetType":"Door","_WidgetID":"4536"}],"ZDeviceID":"","ZDeviceName":"Deursensor woonkamer","_NwkId":"40e3"},{"App Version":"35","Battery":"","ConsistencyCheck":"ok","DeviceType":"FFD","Ep":[{"ClusterList":[{"0010":"Binary Output (Basic)"},{"0006":"On/Off"},{"0004":"Groups"},{"0005":"Scenes"}],"Ep":"02"},{"ClusterList":[{"000a":"Time"},{"000c":"Analog Input (basic)"},{"0402":"Temperature Measurement"},{"0000":"Basic"},{"0002":"Unknown"},{"0001":"Power Configuration"},{"0019":"Over-the-Air Upgrade"},{"0010":"Binary Output (Basic)"},{"0006":"On/Off"},{"0b04":"Electrical Measurement"},{"0405":"Relative Humidity Measurement"},{"0005":"Scenes"},{"0004":"Groups"},{"0003":"Identify"},{"0008":"Level Control"}],"Ep":"01"}],"HW Version":"18","Health":"Live","IEEE":"00158d0003f05121","LastCmds":[{"CmdCode":"0100","TimeStamps":"03/12/2020 07:48:46"},{"CmdCode":"0100","TimeStamps":"03/12/2020 07:48:46"},{"CmdCode":"0100","TimeStamps":"03/12/2020 07:48:46"},{"CmdCode":"0100","TimeStamps":"03/12/2020 07:48:46"},{"CmdCode":"0100","TimeStamps":"03/12/2020 07:48:47"}],"LastSeen":"03/12/2020 18:10:48","LogicalType":"Router","Manufacturer":"1037","Model":"lumi.relay.c2acn01","PowerSource":"Main","ProfileID":"0104","RSSI":84,"ReceiveOnIdle":"On","Stack Version":"2","Stamp":{"LastSeen":"03/12/2020 18:10:48","MsgType":"8011","Time":"2020-12-03 18:14:48"},"Status":"inDB","Type":"Switch","WidgetList":[{"WidgetName":"badkamer 2 leeg","WidgetType":"Switch","_WidgetID":"4531"},{"WidgetName":"Badkamerventilatie","WidgetType":"Switch","_WidgetID":"4532"}],"ZDeviceID":"0101","ZDeviceName":"Badkamer relay","_NwkId":"3764"},{"App Version":"3","Battery":61,"ConsistencyCheck":"ok","DeviceType":"RFD","Ep":[{"ClusterList":[{"0001":"Power Configuration"},{"0403":"Pressure measurement"},{"0405":"Relative Humidity Measurement"},{"0402":"Temperature Measurement"},{"0000":"Basic"},{"ffff":"Unknown"},{"0003":"Identify"},{"0006":"On/Off"}],"Ep":"01"}],"HW Version":"30","Health":"Live","IEEE":"00158d00036b5243","LastCmds":[{"CmdCode":"0100","TimeStamps":"26/09/2020 00:00:57"},{"CmdCode":"0100","TimeStamps":"26/09/2020 00:00:57"},{"CmdCode":"0100","TimeStamps":"26/09/2020 00:01:00"},{"CmdCode":"0100","TimeStamps":"26/09/2020 00:01:00"},{"CmdCode":"0100","TimeStamps":"26/09/2020 00:01:00"}],"LastSeen":"03/12/2020 18:02:35","LogicalType":"End Device","Manufacturer":"1037","Model":"lumi.weather","PowerSource":"Battery","ProfileID":"","RSSI":123,"ReceiveOnIdle":"Off","Stack Version":"2","Stamp":{"LastSeen":"03/12/2020 18:02:35","MsgType":"8102","Time":"2020-12-03 18:02:35"},"Status":"inDB","Type":"Temp/Humi/Baro","WidgetList":[{"WidgetName":"Zigate temp","WidgetType":"Temp+Hum+Baro","_WidgetID":"4419"},{"WidgetName":"Zigate - lumi.weather_Baro-00158d00036b5243-01","WidgetType":"Baro","_WidgetID":"4423"},{"WidgetName":"3D printer vocht","WidgetType":"Humi","_WidgetID":"4422"},{"WidgetName":"3D printer temp","WidgetType":"Temp","_WidgetID":"4421"}],"ZDeviceID":"","ZDeviceName":"3D printer","_NwkId":"ec2a"},{"App Version":"5","Battery":56,"ConsistencyCheck":"ok","DeviceType":"","Ep":[{"ClusterList":[{"0400":"Illuminance Measurement"},{"0006":"On/Off"},{"0406":"Occupancy Sensing"},{"0000":"Basic"},{"0001":"Power Configuration"}],"Ep":"01"}],"HW Version":"1","Health":"Live","IEEE":"00158d0003fb0366","LastCmds":[{"CmdCode":"0100","TimeStamps":"22/07/2020 15:16:36"},{"CmdCode":"0100","TimeStamps":"22/07/2020 15:16:36"},{"CmdCode":"0100","TimeStamps":"22/07/2020 15:16:38"},{"CmdCode":"0100","TimeStamps":"22/07/2020 15:16:39"},{"CmdCode":"0100","TimeStamps":"22/07/2020 15:16:39"}],"LastSeen":"03/12/2020 18:15:37","LogicalType":"","Manufacturer":"","Model":"lumi.sensor_motion.aq2","PowerSource":"","ProfileID":"0104","RSSI":159,"ReceiveOnIdle":"","Stack Version":"2","Stamp":{"LastSeen":"03/12/2020 18:15:37","MsgType":"8102","Time":"2020-12-03 18:15:37"},"Status":"inDB","WidgetList":[{"WidgetName":"$PIR-ligt sterkte","WidgetType":"Lux","_WidgetID":"4539"},{"WidgetName":"PIR-voordeur","WidgetType":"Motion","_WidgetID":"4538"}],"ZDeviceID":"0107","ZDeviceName":"Pir voordeur","_NwkId":"557a"},{"App Version":"17","Battery":"","ConsistencyCheck":"ok","DeviceType":"FFD","Ep":[{"ClusterList":[{"0b05":"Diagnostics"},{"0008":"Level Control"},{"0000":"Basic"},{"1000":"Touchlink"},{"0020":"Poll Control"},{"0005":"Scenes"},{"0300":"Colour Control"},{"0006":"On/Off"},{"0019":"Over-the-Air Upgrade"},{"0004":"Groups"},{"0003":"Identify"}],"Ep":"01"}],"HW Version":"1","Health":"Live","IEEE":"000d6ffffe485188","LastCmds":[{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:23:32"},{"CmdCode":"0081","TimeStamps":"03/12/2020 09:23:52"},{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:23:52"},{"CmdCode":"0120","TimeStamps":"03/12/2020 17:31:52"},{"CmdCode":"0120","TimeStamps":"03/12/2020 17:31:52"}],"LastSeen":"03/12/2020 18:11:38","LogicalType":"Router","Manufacturer":"117c","Model":"TRADFRI bulb E27 WS opal 980lm","PowerSource":"Main","ProfileID":"c05e","RSSI":132,"ReceiveOnIdle":"On","Stack Version":"87","Stamp":{"LastSeen":"03/12/2020 18:11:38","MsgType":"8011","Time":"2020-12-03 18:13:11"},"Status":"inDB","Type":"ColorControlWW","WidgetList":[{"WidgetName":"Woonkamer bankstel","WidgetType":"ColorControlWW","_WidgetID":"4540"}],"ZDeviceID":"0220","ZDeviceName":"Woonkamer bankstel","_NwkId":"8b16"},{"App Version":"3","Battery":66,"ConsistencyCheck":"ok","DeviceType":"","Ep":[{"ClusterList":[{"0006":"On/Off"},{"ffff":"Unknown"},{"0000":"Basic"},{"0001":"Power Configuration"},{"0003":"Identify"}],"Ep":"01"}],"HW Version":"2","Health":"Live","IEEE":"00158d00045cfdb5","LastCmds":[{"CmdCode":"0120","TimeStamps":"21/02/2020 21:13:58"},{"CmdCode":"0120","TimeStamps":"21/02/2020 21:14:02"},{"CmdCode":"0100","TimeStamps":"21/02/2020 21:14:06"},{"CmdCode":"0100","TimeStamps":"21/02/2020 21:14:06"},{"CmdCode":"0100","TimeStamps":"21/02/2020 21:14:06"}],"LastSeen":"03/12/2020 17:51:01","LogicalType":"","Manufacturer":"","Model":"lumi.sensor_magnet.aq2","PowerSource":"","ProfileID":"0104","RSSI":123,"ReceiveOnIdle":"","Stack Version":"2","Stamp":{"LastSeen":"03/12/2020 17:51:01","MsgType":"8102","Time":"2020-12-03 17:51:01"},"Status":"inDB","Type":"Door","WidgetList":[{"WidgetName":"Deur_achter","WidgetType":"Door","_WidgetID":"4543"}],"ZDeviceID":"5f01","ZDeviceName":"Deursensor tuin","_NwkId":"caca"},{"App Version":"2","Battery":59,"ConsistencyCheck":"ok","DeviceType":"","Ep":[{"ClusterList":[],"Ep":"03"},{"ClusterList":[],"Ep":"02"},{"ClusterList":[{"0001":"Power Configuration"},{"0402":"Temperature Measurement"},{"0000":"Basic"},{"0405":"Relative Humidity Measurement"},{"0008":"Level Control"}],"Ep":"01"}],"HW Version":"30","Health":"Live","IEEE":"00158d0003cc6bae","LastCmds":[{"CmdCode":"0120","TimeStamps":"21/02/2020 20:12:02"},{"CmdCode":"0100","TimeStamps":"21/02/2020 20:12:06"},{"CmdCode":"0100","TimeStamps":"21/02/2020 20:12:06"},{"CmdCode":"0100","TimeStamps":"21/02/2020 20:12:06"},{"CmdCode":"0100","TimeStamps":"21/02/2020 20:12:06"}],"LastSeen":"03/12/2020 18:02:20","LogicalType":"","Manufacturer":"","Model":"lumi.sensor_ht","PowerSource":"","ProfileID":"","RSSI":84,"ReceiveOnIdle":"","Stack Version":"2","Stamp":{"LastSeen":"03/12/2020 18:02:20","MsgType":"8102","Time":"2020-12-03 18:02:20"},"Status":"inDB","Type":"Temp/Humi","WidgetList":[{"WidgetName":"Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01","WidgetType":"Temp+Hum","_WidgetID":"4533"},{"WidgetName":"Badkamer vocht","WidgetType":"Humi","_WidgetID":"4535"},{"WidgetName":"Badkamer temperatuur","WidgetType":"Temp","_WidgetID":"4534"}],"ZDeviceID":"","ZDeviceName":"Sensor badkamer","_NwkId":"c2bb"},{"App Version":"4","Battery":64,"ConsistencyCheck":"ok","DeviceType":"","Ep":[{"ClusterList":[{"0001":"Power Configuration"},{"0000":"Basic"},{"0006":"On/Off"}],"Ep":"01"}],"HW Version":"","Health":"Live","IEEE":"00158d00035801d1","LastCmds":[{"CmdCode":"0100","TimeStamps":"03/04/2020 15:40:10"},{"CmdCode":"0100","TimeStamps":"03/04/2020 15:40:10"},{"CmdCode":"0100","TimeStamps":"03/04/2020 15:40:10"},{"CmdCode":"0100","TimeStamps":"03/04/2020 15:40:13"},{"CmdCode":"0100","TimeStamps":"03/04/2020 15:40:13"}],"LastSeen":"03/12/2020 18:07:26","LogicalType":"","Manufacturer":"","Model":"lumi.sensor_wleak.aq1","PowerSource":"","ProfileID":"0104","RSSI":84,"ReceiveOnIdle":"","Stack Version":"","Stamp":{"LastSeen":"03/12/2020 18:07:26","MsgType":"8102","Time":"2020-12-03 18:07:26"},"Status":"inDB","WidgetList":[{"WidgetName":"Water sensor Wasmachine","WidgetType":"Water","_WidgetID":"4545"}],"ZDeviceID":"0402","ZDeviceName":"Watersensor wasmachine","_NwkId":"9224"},{"App Version":"36","Battery":"","ConsistencyCheck":"ok","DeviceType":"FFD","Ep":[{"ClusterList":[{"0000":"Basic"},{"0001":"Power Configuration"},{"0002":"Unknown"},{"0003":"Identify"},{"0004":"Groups"},{"0005":"Scenes"},{"0006":"On/Off"},{"000a":"Time"},{"000c":"Analog Input (basic)"},{"0010":"Binary Output (Basic)"},{"0019":"Over-the-Air Upgrade"},{"0b04":"Electrical Measurement"},{"0702":"Unknown"},{"0008":"Level Control"},{"0405":"Relative Humidity Measurement"}],"Ep":"01"},{"ClusterList":[{"0004":"Groups"},{"0005":"Scenes"},{"0006":"On/Off"},{"0010":"Binary Output (Basic)"}],"Ep":"02"}],"HW Version":"18","Health":"Live","IEEE":"00158d000444ee2f","LastCmds":[{"CmdCode":"0100","TimeStamps":"03/12/2020 16:12:04"},{"CmdCode":"0100","TimeStamps":"03/12/2020 16:12:04"},{"CmdCode":"0100","TimeStamps":"03/12/2020 16:12:04"},{"CmdCode":"0100","TimeStamps":"03/12/2020 16:12:04"},{"CmdCode":"0100","TimeStamps":"03/12/2020 16:12:04"}],"LastSeen":"03/12/2020 18:15:24","LogicalType":"Router","Manufacturer":"1037","Model":"lumi.relay.c2acn01","PowerSource":"Main","ProfileID":"0104","RSSI":159,"ReceiveOnIdle":"On","Stack Version":"2","Stamp":{"LastSeen":"03/12/2020 18:15:24","MsgType":"8011","Time":"2020-12-03 18:15:24"},"Status":"inDB","Type":"Switch","WidgetList":[{"WidgetName":"Tuinvoor verlichting","WidgetType":"Switch","_WidgetID":"4573"},{"WidgetName":"Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01","WidgetType":"Power","_WidgetID":"4574"},{"WidgetName":"Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01","WidgetType":"Meter","_WidgetID":"4575"},{"WidgetName":"$Bewatering voor handmatig","WidgetType":"Switch","_WidgetID":"4576"}],"ZDeviceID":"0101","ZDeviceName":"Voortuin relay","_NwkId":"d4ad"},{"App Version":"32","Battery":"","ConsistencyCheck":"ok","DeviceType":"FFD","Ep":[{"ClusterList":[{"1000":"Touchlink"},{"0021":"Unknown"}],"Ep":"02"},{"ClusterList":[{"0006":"On/Off"},{"fc7c":"Unknown"},{"0004":"Groups"},{"0000":"Basic"},{"0003":"Identify"},{"0008":"Level Control"},{"0005":"Scenes"},{"0019":"Over-the-Air Upgrade"}],"Ep":"01"}],"HW Version":"1","Health":"Live","IEEE":"680ae2fffe413429","LastCmds":[{"CmdCode":"0100","TimeStamps":"03/12/2020 13:52:27"},{"CmdCode":"0100","TimeStamps":"03/12/2020 14:52:28"},{"CmdCode":"0100","TimeStamps":"03/12/2020 15:52:33"},{"CmdCode":"0100","TimeStamps":"03/12/2020 16:52:36"},{"CmdCode":"0100","TimeStamps":"03/12/2020 17:52:38"}],"LastSeen":"03/12/2020 17:52:38","LogicalType":"Router","Manufacturer":"117c","Model":"TRADFRI control outlet","PowerSource":"Main","ProfileID":"a1e0","RSSI":120,"ReceiveOnIdle":"On","Stack Version":"98","Stamp":{"LastSeen":"03/12/2020 17:52:38","MsgType":"8011","Time":"2020-12-03 17:52:38"},"Status":"inDB","Type":"Plug","WidgetList":[{"WidgetName":"TV boven schakelaar","WidgetType":"Plug","_WidgetID":"4582"}],"ZDeviceID":"0061","ZDeviceName":" TV boven schakelaar","_NwkId":"f1f1"},{"App Version":"32","Battery":"","ConsistencyCheck":"ok","DeviceType":"FFD","Ep":[{"ClusterList":[{"0000":"Basic"},{"0003":"Identify"},{"0004":"Groups"},{"0005":"Scenes"},{"0006":"On/Off"},{"0008":"Level Control"},{"0019":"Over-the-Air Upgrade"},{"0300":"Colour Control"},{"0b05":"Diagnostics"},{"1000":"Touchlink"}],"Ep":"01"}],"HW Version":"1","Health":"Live","IEEE":"680ae2fffe4a16b8","LastCmds":[{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:23:02"},{"CmdCode":"0081","TimeStamps":"03/12/2020 09:23:27"},{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:23:27"},{"CmdCode":"0081","TimeStamps":"03/12/2020 09:23:49"},{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:23:49"}],"LastSeen":"03/12/2020 18:14:31","LogicalType":"Router","Manufacturer":"117c","Model":"TRADFRI bulb E27 WS opal 1000lm","PowerSource":"Main","ProfileID":"a1e0","RSSI":141,"ReceiveOnIdle":"On","Stack Version":"98","Stamp":{"LastSeen":"03/12/2020 18:14:31","MsgType":"8011","Time":"2020-12-03 18:14:31"},"Status":"inDB","Type":"ColorControlWW","WidgetList":[{"WidgetName":"Woonkamer eethoek achter","WidgetType":"ColorControlWW","_WidgetID":"4584"}],"ZDeviceID":"0061","ZDeviceName":"Woonkamer eethoek achter","_NwkId":"aa16"},{"App Version":"32","Battery":"","ConsistencyCheck":"ok","DeviceType":"FFD","Ep":[{"ClusterList":[{"0000":"Basic"},{"0003":"Identify"},{"0004":"Groups"},{"0005":"Scenes"},{"0006":"On/Off"},{"0008":"Level Control"},{"0019":"Over-the-Air Upgrade"},{"0300":"Colour Control"},{"fc7c":"Unknown"},{"1000":"Touchlink"}],"Ep":"01"}],"HW Version":"1","Health":"Live","IEEE":"ec1bbdfffe986a27","LastCmds":[{"CmdCode":"0100","TimeStamps":"03/12/2020 09:22:46"},{"CmdCode":"0081","TimeStamps":"03/12/2020 09:23:12"},{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:23:12"},{"CmdCode":"0081","TimeStamps":"03/12/2020 09:23:37"},{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:23:37"}],"LastSeen":"03/12/2020 18:12:33","LogicalType":"Router","Manufacturer":"117c","Model":"TRADFRI bulb GU10 WS 400lm","PowerSource":"Main","ProfileID":"a1e0","RSSI":183,"ReceiveOnIdle":"On","Stack Version":"98","Stamp":{"LastSeen":"03/12/2020 18:12:33","MsgType":"8011","Time":"2020-12-03 18:12:33"},"Status":"inDB","Type":"ColorControlWW","WidgetList":[{"WidgetName":"Woonkamer salontafel_1","WidgetType":"ColorControlWW","_WidgetID":"4585"}],"ZDeviceID":"0061","ZDeviceName":"Woonkamer salontafel_1","_NwkId":"7f15"},{"App Version":"32","Battery":"","ConsistencyCheck":"ok","DeviceType":"FFD","Ep":[{"ClusterList":[{"0000":"Basic"},{"0003":"Identify"},{"0004":"Groups"},{"0005":"Scenes"},{"0006":"On/Off"},{"0008":"Level Control"},{"0019":"Over-the-Air Upgrade"},{"0300":"Colour Control"},{"fc7c":"Unknown"},{"1000":"Touchlink"}],"Ep":"01"}],"HW Version":"1","Health":"Live","IEEE":"ec1bbdfffe468a93","LastCmds":[{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:22:46"},{"CmdCode":"0081","TimeStamps":"03/12/2020 09:23:22"},{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:23:22"},{"CmdCode":"0081","TimeStamps":"03/12/2020 09:23:42"},{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:23:42"}],"LastSeen":"03/12/2020 18:12:46","LogicalType":"Router","Manufacturer":"117c","Model":"TRADFRI bulb GU10 WS 400lm","PowerSource":"Main","ProfileID":"a1e0","RSSI":174,"ReceiveOnIdle":"On","Stack Version":"98","Stamp":{"LastSeen":"03/12/2020 18:12:46","MsgType":"8011","Time":"2020-12-03 18:12:46"},"Status":"inDB","Type":"ColorControlWW","WidgetList":[{"WidgetName":"Woonkamer salontafel_2","WidgetType":"ColorControlWW","_WidgetID":"4586"}],"ZDeviceID":"0061","ZDeviceName":"Woonkamer salontafel_2","_NwkId":"9ab3"},{"App Version":"32","Battery":"","ConsistencyCheck":"ok","DeviceType":"FFD","Ep":[{"ClusterList":[{"0000":"Basic"},{"0003":"Identify"},{"0004":"Groups"},{"0005":"Scenes"},{"0006":"On/Off"},{"0008":"Level Control"},{"0019":"Over-the-Air Upgrade"},{"0300":"Colour Control"},{"fc7c":"Unknown"},{"1000":"Touchlink"}],"Ep":"01"}],"HW Version":"1","Health":"Live","IEEE":"680ae2fffe373006","LastCmds":[{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:22:58"},{"CmdCode":"0081","TimeStamps":"03/12/2020 09:23:25"},{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:23:25"},{"CmdCode":"0081","TimeStamps":"03/12/2020 09:23:47"},{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:23:47"}],"LastSeen":"03/12/2020 18:12:58","LogicalType":"Router","Manufacturer":"117c","Model":"TRADFRI bulb GU10 WS 400lm","PowerSource":"Main","ProfileID":"a1e0","RSSI":186,"ReceiveOnIdle":"On","Stack Version":"98","Stamp":{"LastSeen":"03/12/2020 18:12:58","MsgType":"8011","Time":"2020-12-03 18:12:58"},"Status":"inDB","Type":"ColorControlWW","WidgetList":[{"WidgetName":"Woonkamer salontafel_3","WidgetType":"ColorControlWW","_WidgetID":"4587"}],"ZDeviceID":"0061","ZDeviceName":"Woonkamer salontafel_3","_NwkId":"5a7a"},{"App Version":"32","Battery":"","ConsistencyCheck":"ok","DeviceType":"FFD","Ep":[{"ClusterList":[{"0000":"Basic"},{"0003":"Identify"},{"0004":"Groups"},{"0005":"Scenes"},{"0006":"On/Off"},{"0008":"Level Control"},{"0019":"Over-the-Air Upgrade"},{"0300":"Colour Control"},{"0b05":"Diagnostics"},{"1000":"Touchlink"}],"Ep":"01"}],"HW Version":"1","Health":"Live","IEEE":"680ae2fffe4c5b85","LastCmds":[{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:22:41"},{"CmdCode":"0081","TimeStamps":"03/12/2020 09:23:16"},{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:23:16"},{"CmdCode":"0081","TimeStamps":"03/12/2020 09:23:39"},{"CmdCode":"00C0","TimeStamps":"03/12/2020 09:23:39"}],"LastSeen":"03/12/2020 18:12:41","LogicalType":"Router","Manufacturer":"117c","Model":"TRADFRI bulb E27 WS opal 1000lm","PowerSource":"Main","ProfileID":"a1e0","RSSI":135,"ReceiveOnIdle":"On","Stack Version":"98","Stamp":{"LastSeen":"03/12/2020 18:12:41","MsgType":"8011","Time":"2020-12-03 18:14:20"},"Status":"inDB","Type":"ColorControlWW","WidgetList":[{"WidgetName":"Woonkamer eethoek voor","WidgetType":"ColorControlWW","_WidgetID":"4588"}],"ZDeviceID":"0061","ZDeviceName":"Woonkamer eethoek voor","_NwkId":"8ca0"},{"App Version":"3","Battery":66,"ConsistencyCheck":"ok","DeviceType":"RFD","Ep":[{"ClusterList":[{"0000":"Basic"},{"0006":"On/Off"},{"0003":"Identify"},{"ffff":"Unknown"},{"0001":"Power Configuration"}],"Ep":"01"}],"HW Version":"","Health":"Live","IEEE":"00158d00045c2862","LastCmds":[{"CmdCode":"0100","TimeStamps":"15/05/2020 18:37:02"},{"CmdCode":"0100","TimeStamps":"15/05/2020 18:37:02"},{"CmdCode":"0100","TimeStamps":"15/05/2020 18:37:02"},{"CmdCode":"0100","TimeStamps":"15/05/2020 18:37:02"},{"CmdCode":"0100","TimeStamps":"15/05/2020 18:37:02"}],"LastSeen":"03/12/2020 17:55:18","LogicalType":"End Device","Manufacturer":"","Model":"lumi.sensor_magnet.aq2","PowerSource":"","ProfileID":"","RSSI":132,"ReceiveOnIdle":"","Stack Version":"","Stamp":{"LastSeen":"03/12/2020 17:55:18","MsgType":"8102","Time":"2020-12-03 17:55:18"},"Status":"inDB","Type":"Door","WidgetList":[{"WidgetName":"Deur_schuiftuin","WidgetType":"Door","_WidgetID":"4608"}],"ZDeviceID":"","ZDeviceName":"Deursensor schuifdeur ","_NwkId":"2172"},{"App Version":"11","Battery":54,"ConsistencyCheck":"ok","DeviceType":"","Ep":[{"ClusterList":[{"0001":"Power Configuration"},{"0406":"Occupancy Sensing"},{"0000":"Basic"},{"0006":"On/Off"}],"Ep":"01"}],"HW Version":"","Health":"Live","IEEE":"00158d0004468e86","LastCmds":[{"CmdCode":"0100","TimeStamps":"22/07/2020 20:15:12"},{"CmdCode":"0100","TimeStamps":"22/07/2020 20:15:12"},{"CmdCode":"0100","TimeStamps":"22/07/2020 20:15:14"},{"CmdCode":"0100","TimeStamps":"22/07/2020 20:15:15"},{"CmdCode":"0100","TimeStamps":"22/07/2020 20:15:15"}],"LastSeen":"03/12/2020 17:31:12","LogicalType":"","Manufacturer":"","Model":"lumi.sensor_motion","PowerSource":"","ProfileID":"","RSSI":93,"ReceiveOnIdle":"","Stack Version":"","Stamp":{"LastSeen":"03/12/2020 17:31:12","MsgType":"8702","Time":"2020-12-03 17:31:19"},"Status":"inDB","Type":"Motion","WidgetList":[{"WidgetName":"PIR-achterthuis","WidgetType":"Motion","_WidgetID":"4537"}],"ZDeviceID":"","ZDeviceName":"PIR achterthuis","_NwkId":"db27"},{"App Version":"3","Battery":59,"ConsistencyCheck":"ok","DeviceType":"RFD","Ep":[{"ClusterList":[{"0000":"Basic"},{"0006":"On/Off"},{"0003":"Identify"},{"ffff":"Unknown"},{"0001":"Power Configuration"}],"Ep":"01"}],"HW Version":"","Health":"Live","IEEE":"00158d0005225f00","LastCmds":[{"CmdCode":"0100","TimeStamps":"06/09/2020 19:46:44"},{"CmdCode":"0100","TimeStamps":"06/09/2020 19:46:44"},{"CmdCode":"0100","TimeStamps":"06/09/2020 19:46:44"},{"CmdCode":"0100","TimeStamps":"06/09/2020 19:46:44"},{"CmdCode":"0100","TimeStamps":"06/09/2020 19:46:44"}],"LastSeen":"03/12/2020 17:38:29","LogicalType":"End Device","Manufacturer":"","Model":"lumi.sensor_magnet.aq2","PowerSource":"","ProfileID":"","RSSI":162,"ReceiveOnIdle":"","Stack Version":"","Stamp":{"LastSeen":"03/12/2020 17:38:29","MsgType":"8102","Time":"2020-12-03 17:43:16"},"Status":"inDB","Type":"Door","WidgetList":[{"WidgetName":"Deur_voor","WidgetType":"Door","_WidgetID":"4664"}],"ZDeviceID":"","ZDeviceName":"Deursensor voordeur","_NwkId":"3478"},{"App Version":"1","Battery":99,"ConsistencyCheck":"ok","DeviceType":"RFD","Ep":[{"ClusterList":[{"0006":"On/Off"},{"0000":"Basic"},{"0500":"IAS Zone"},{"0001":"Power Configuration"}],"Ep":"01"}],"HW Version":"","Health":"Live","IEEE":"00158d000490afab","LastCmds":[{"CmdCode":"0100","TimeStamps":"13/11/2020 21:55:41"},{"CmdCode":"0092","TimeStamps":"13/11/2020 21:55:41"},{"CmdCode":"0092","TimeStamps":"13/11/2020 21:55:45"},{"CmdCode":"0100","TimeStamps":"13/11/2020 21:55:46"},{"CmdCode":"0100","TimeStamps":"13/11/2020 21:55:46"}],"LastSeen":"03/12/2020 17:51:43","LogicalType":"End Device","Manufacturer":"","Model":"lumi.sensor_smoke","PowerSource":"","ProfileID":"","RSSI":117,"ReceiveOnIdle":"","Stack Version":"","Stamp":{"LastSeen":"03/12/2020 17:51:43","MsgType":"8102","Time":"2020-12-03 17:51:43"},"Status":"inDB","Type":"Smoke","WidgetList":[{"WidgetName":"rookmelder","WidgetType":"Smoke","_WidgetID":"4676"}],"ZDeviceID":"","ZDeviceName":"rookmelder","_NwkId":"5554"}]
pipiche
Post by pipiche »
Plugin RAW Devices(Json) this is what I need. here it looks like you did Plugin Devices (json)
marktn
Post by marktn »
pipiche wrote: Thursday 03 December 2020 19:45 Plugin RAW Devices(Json) this is what I need. here it looks like you did Plugin Devices (json)
The right file, to big for the forum in my dropbox
https://www.dropbox.com/s/4pludlb1duoas ... json?dl=0
pipiche
Post by pipiche »
From what I see in the file is that the last battery update was at 19:37:48 today. So there is nothing between the device and the plugin
The issue is that the battery get updated on Domoticz only when there is a state change on the device.
re you sure that the Last Seen on Domoticz is not updated ?
marktn
Post by marktn »
Yes is am, you can see it here. The last seen date was when I pushed the test button on the smoke detector.
pipiche
Post by pipiche »
Which version of Domoticz do you use ?
marktn
Post by marktn »
pipiche wrote: Friday 04 December 2020 6:40 Which version of Domoticz do you use ?
2020.2 stable version
pipiche
Post by pipiche »
I did a test with a Honeywell Smoke detector and I don't have your issue. I get the last seen correctly reported (every time I got a Battery update from the device).
Is that the only device you are having such issue , or all battery devices ? Like the "Deursensor woonkamer" , if you don't open the door during 2 hours, is the lastseen updated ?
I saw that you have few door sensors, water leak check if the lastseen is updated or not.
Make sure that you are on the last plugin version beta is 4.12.075
marktn
Post by marktn »
pipiche wrote: Tuesday 08 December 2020 22:36 I did a test with a Honeywell Smoke detector and I don't have your issue. I get the last seen correctly reported (every time I got a Battery update from the device).
Yes you are right, the waterleak sensor has the same, I didn't notice that. The door are often in use, so I did not see that.
I will update to the latest version! I have an older version at this moment.
Thanks for the support so far.
marktn
Post by marktn »
The last update is running, the water leak sensor is visible now.
The smoke detector not yet, maybe wait a few hours. I don't know how often it will give a signal to domoticz?
Lights, doorsensors and temperature sensors are working fine.
Only in domoticz is see these errors in my log:
 2020-12-09 19:31:02.779 Proxy: Error, reconnecting (Connection timed out)
2020-12-09 19:31:02.780 Proxy: Error, reconnecting (Network is unreachable)
2020-12-09 19:32:17.787 Proxy: Error, reconnecting (Connection timed out)
2020-12-09 19:32:17.787 Proxy: Error, reconnecting (Network is unreachable)
And in zigate a :!: with these errors
{"0":{"0":{"Time":"09/12/2020 18:51:07","Module":"TransportTx","nwkid":null,"PluginHealth":"Ready","message":"timeout_cmd_response Error Code: TRANS-TOCMD-01","PermitToJoin":{"Duration":0,"Starttime":1607536237},"context":{"Error code":"TRANS-TOCMD-01","ISQN":10,"TimeStamp":"09/12/2020 18:50:58","Firmware":{"zmode":"zigate31c","with_aps_sqn":false,"with_8012":false,"nPDU":0,"aPDU":0},"Queues":{"8000 Queue":[],"8011 Queue":[],"8012 Queue":[],"Send Queue":[[11,1607536258]],"ListOfCommands":{"10":{"Cmd":"0100","Datas":"02cf420101000000000000010000","ReTransmit":0,"Status":"8000","ReceiveTimeStamp":"12/09/2020, 18:50:58","SentTimeStamp":1607536258,"PDMCommand":false,"ResponseExpected":true,"MessageResponse":33024,"Expected8011":true,"WaitForResponse":false,"Expected8012":false,"APP_SQN":"00","APS_SQN":null,"TYP_SQN":null},"11":{"Cmd":"0100","Datas":"0237640101000000000000010000","ReTransmit":0,"Status":"8XXX","ReceiveTimeStamp":"12/09/2020, 18:50:58","SentTimeStamp":1607536267,"PDMCommand":false,"ResponseExpected":true,"MessageResponse":33024,"Expected8011":true,"WaitForResponse":false,"Expected8012":false,"APP_SQN":"01","APS_SQN":null,"TYP_SQN":null}}},"Sqn Management":{"sqn_ZCL":{"10":26,"00":10,"01":11,"02":12,"03":13,"04":14,"07":17,"08":18,"09":19,"0c":22,"0d":23},"sqn_ZDP":{},"sqn_APS":{"null":26},"current_SQN":12},"inMessage":{"ReqRcv":"bytearray(b'')"}}},"1":{"Time":"09/12/2020 18:51:17","Module":"TransportTx","nwkid":null,"PluginHealth":"Ready","message":"timeout_cmd_response Error Code: TRANS-TOCMD-01","PermitToJoin":{"Duration":0,"Starttime":1607536237},"context":{"Error code":"TRANS-TOCMD-01","ISQN":13,"TimeStamp":"09/12/2020 18:51:08","Firmware":{"zmode":"zigate31c","with_aps_sqn":false,"with_8012":false,"nPDU":0,"aPDU":0},"Queues":{"8000 Queue":[],"8011 Queue":[],"8012 Queue":[],"Send Queue":[[14,1607536270],[15,1607536273],[16,1607536273]],"ListOfCommands":{"13":{"Cmd":"0100","Datas":"02f1f10101000000000000010000","ReTransmit":0,"Status":"8000","ReceiveTimeStamp":"12/09/2020, 18:51:07","SentTimeStamp":1607536268,"PDMCommand":false,"ResponseExpected":true,"MessageResponse":33024,"Expected8011":true,"WaitForResponse":false,"Expected8012":false,"APP_SQN":"03","APS_SQN":null,"TYP_SQN":null},"14":{"Cmd":"0081","Datas":"029ab3010101520010","ReTransmit":0,"Status":"8000","ReceiveTimeStamp":"12/09/2020, 18:51:10","SentTimeStamp":1607536277,"PDMCommand":false,"ResponseExpected":false,"MessageResponse":null,"Expected8011":true,"WaitForResponse":false,"Expected8012":false,"APP_SQN":"04","APS_SQN":null,"TYP_SQN":null},"15":{"Cmd":"0100","Datas":"079ab30101000600000000010000","ReTransmit":0,"Status":"8000","ReceiveTimeStamp":"12/09/2020, 18:51:13","SentTimeStamp":1607536277,"PDMCommand":false,"ResponseExpected":false,"MessageResponse":null,"Expected8011":false,"WaitForResponse":false,"Expected8012":false,"APP_SQN":"05","APS_SQN":null,"TYP_SQN":null},"16":{"Cmd":"0100","Datas":"079ab30101000800000000010000","ReTransmit":0,"Status":"8000","ReceiveTimeStamp":"12/09/2020, 18:51:13","SentTimeStamp":1607536277,"PDMCommand":false,"ResponseExpected":false,"MessageResponse":null,"Expected8011":false,"WaitForResponse":false,"Expected8012":false,"APP_SQN":"06","APS_SQN":null,"TYP_SQN":null}}},"Sqn Management":{"sqn_ZCL":{"10":26,"00":10,"01":11,"02":12,"03":13,"04":14,"07":17,"08":18,"09":19,"0c":22,"0d":23},"sqn_ZDP":{},"sqn_APS":{"null":26},"current_SQN":17},"inMessage":{"ReqRcv":"bytearray(b'')"}}},"LastLog":1,"StartTime":"09/12/2020 18:49:55","FirmwareVersion":"031c","FirmwareMajorVersion":"0003"},"LastLog":0}
pipiche
Post by pipiche »
Ok, let see the errors are more-less ok. don't care too much .
while the Domoticz log I have no clue what is that.
